I am writing a procedure that will replace my NaN values for an average value of my data. So far, the program I have written simply copies the previous wave that I had into my new string. This is what my procedure looks like, hopefully someone can tell me if they see anything wrong:
Function replace_nan(data_wave)Wave data_wave
VariableiString destName = NameofWave(data_wave)[0,11]+"_modified"Make/O/N=(numpnts(data_Wave))/D $destNameWave/D dest = $destName
dest = NaNWavestats/q data_wave
For(i=0; i<(numpnts(data_wave)); i+=1)If(data_wave[i]!=NaN)
dest[i]=data_wave[i]Elseif(data_wave[i]== NaN)
dest[i]=V_avg
EndifEndforappendtotable dest
First of all, instead of data_wave[i]!=NaN and data_wave[i]== NaN, use the numtype function. That would give you this:
For(i=0; i<(numpnts(data_wave)); i+=1)If(numtype(data_wave[i])!= 2)
dest[i]=V_avg
Second, you don't need an explicit for loop here. Instead, you could use waveform assignment. Waveform assignment is much faster than explicit for loops. That leaves you with this:
String destName = NameofWave(data_wave)[0,11]+"_modified"Duplicate/O data_wave, $destNameWave/D dest = $destNameWavestats/q data_wave
dest = (numtype(data_wave[p])!= 2) ? data_wave[p] : V_avg
appendtotable dest
Note that I also replaced the Make command with a simpler Duplicate command.
Third, in many cases, there's a way to use MatrixOp to give you improved performance and often simpler syntax. That's true in your case, giving you this:
String destName = NameofWave(data_wave)[0,11]+"_modified"Wavestats/q data_wave
MatrixOp/O $destName = replaceNaNs(data_wave, V_avg)Wave/D dest = $destNameappendtotable dest
and exploit the fact that comparing NaN to everything is false. But I must strongly support Adams suggestions, especially the matrixOP solution. Which is faster, better readable and shorter.
data_wave[i]!=NaNanddata_wave[i]== NaN, use thenumtypefunction. That would give you this:Second, you don't need an explicit for loop here. Instead, you could use waveform assignment. Waveform assignment is much faster than explicit for loops. That leaves you with this:
March 3, 2016 at 08:17 am - Permalink
DisplayHelptopic "NumType".Instead of a loop you can use:
Check out
DisplayHelptopic "? :"to see what is happening.EDIT: Too late ;-)
March 3, 2016 at 08:22 am - Permalink
matrixOPsolution. Which is faster, better readable and shorter.March 3, 2016 at 09:08 am - Permalink
March 3, 2016 at 10:34 am - Permalink
