Replace NAN for V_avg
I am writing a procedure that will replace my NaN values for an average value of my data. So far, the program I have written simply copies the previous wave that I had into my new string. This is what my procedure looks like, hopefully someone can tell me if they see anything wrong:
Function replace_nan(data_wave)
Wave data_wave
Variable i
String destName = NameofWave(data_wave)[0,11]+"_modified"
Make/O/N=(numpnts(data_Wave))/D $destName
Wave/D dest = $destName
dest = NaN
Wavestats/q data_wave
    For (i=0; i<(numpnts(data_wave)); i+=1)
            If (data_wave[i]!=NaN)
            dest[i]=data_wave[i]
            Elseif (data_wave[i]== NaN)
            dest[i]=V_avg
        Endif
    Endfor
appendtotable dest
First of all, instead of data_wave[i]!=NaN and data_wave[i]== NaN, use the numtype function. That would give you this:
    Wave data_wave
    Variable i
    dest = NaN
        If (numtype(data_wave[i]) != 2)
        Else
            dest[i]=V_avg
        Endif
    Endfor
    appendtotable dest
Second, you don't need an explicit for loop here. Instead, you could use waveform assignment. Waveform assignment is much faster than explicit for loops. That leaves you with this:
    Wave data_wave
    Duplicate/O data_wave, $destName
    dest = (numtype(data_wave[p]) != 2) ? data_wave[p] : V_avg
    appendtotable dest
Note that I also replaced the Make command with a simpler Duplicate command.
Third, in many cases, there's a way to use MatrixOp to give you improved performance and often simpler syntax. That's true in your case, giving you this:
    Wave data_wave
    MatrixOp/O  $destName = replaceNaNs(data_wave, V_avg)
    appendtotable dest
The expression: "data_wave[i]== NaN" is not doing what you expect. Have a look at DisplayHelptopic "NumType".
Instead of a loop you can use:
Function replace_nan1(data_wave)
    Wave data_wave
    Variable i
    dest = NaN
    print V_avg
    dest = numtype(data_wave) == 2 ? V_avg : data_wave
Check out DisplayHelptopic "? :" to see what is happening.
EDIT: Too late ;-)
You could also use poor mans isNaN
Function isNaN(val)
    return !(val == val)
and exploit the fact that comparing NaN to everything is false. But I must strongly support Adams suggestions, especially the matrixOP solution. Which is faster, better readable and shorter.
