Replace NAN for V_avg
I am writing a procedure that will replace my NaN values for an average value of my data. So far, the program I have written simply copies the previous wave that I had into my new string. This is what my procedure looks like, hopefully someone can tell me if they see anything wrong:
Function replace_nan(data_wave)
Wave data_wave
Variable i
String destName = NameofWave(data_wave)[0,11]+"_modified"
Make/O/N=(numpnts(data_Wave))/D $destName
Wave/D dest = $destName
dest = NaN
Wavestats/q data_wave
	For (i=0; i<(numpnts(data_wave)); i+=1)
			If (data_wave[i]!=NaN)
			dest[i]=data_wave[i]
			Elseif (data_wave[i]== NaN)
			dest[i]=V_avg
		Endif
	Endfor
appendtotable dest
First of all, instead of
data_wave[i]!=NaN
and
data_wave[i]== NaN
, use the
numtype
function. That would give you this:
	Wave data_wave
	Variable i
	dest = NaN
		If (numtype(data_wave[i]) != 2)
		Else
			dest[i]=V_avg
		Endif
	Endfor
	appendtotable dest
Second, you don't need an explicit for loop here. Instead, you could use waveform assignment. Waveform assignment is much faster than explicit for loops. That leaves you with this:
	Wave data_wave
	Duplicate/O data_wave, $destName
	dest = (numtype(data_wave[p]) != 2) ? data_wave[p] : V_avg
	appendtotable dest
Note that I also replaced the Make command with a simpler Duplicate command.
Third, in many cases, there's a way to use MatrixOp to give you improved performance and often simpler syntax. That's true in your case, giving you this:
	Wave data_wave
	MatrixOp/O  $destName = replaceNaNs(data_wave, V_avg)
	appendtotable dest
The expression: "data_wave[i]== NaN" is not doing what you expect. Have a look at
DisplayHelptopic "NumType"
Instead of a loop you can use:
Function replace_nan1(data_wave)
	Wave data_wave
	Variable i
	dest = NaN
 	print V_avg
 	dest = numtype(data_wave) == 2 ? V_avg : data_wave
Check out
DisplayHelptopic "? :"
to see what is happening.
EDIT: Too late ;-)
You could also use poor mans isNaN
Function isNaN(val)
    return !(val == val)
and exploit the fact that comparing NaN to everything is false. But I must strongly support Adams suggestions, especially the
matrixOP
solution. Which is faster, better readable and shorter.
