This test examines the equality of variances for multiple waves.
data1 | data2 | data3 | data4 |
44.43 | 26.84 | 49.56 | 44.48 |
47.34 | 16.93 | 33.51 | 37.59 |
55.17 | 30.02 | 37.66 | 38.68 |
62.91 | 27.21 | 49.57 | 48.1 |
49.28 | 24.86 | 38.06 | 44.23 |
47.01 | 27.61 | 50.09 | 44.43 |
43.15 | 23.62 | 36.02 | |
64.85 | 17.3 | 34.62 |
To execute Bartlett's version of the test, use the following command:
StatsVariancesTest/T=1/Q data1,data2,data3,data4
The results are displayed in the Variances Test table:
N | 30 |
PooledVariance | 42.0284 |
Bartlett_T | 3.00346 |
critical | 7.81473 |
Bartlett's statistic is smaller than the critical value and so we can't reject the equality of the variances of the waves. To execute Levene's test using the means of the waves select the blue line below and type Ctrl-Enter:
StatsVariancesTest/T=1/Q/METH=1 data1,data2,data3,data4
N | 30 |
zBar | 5.32225 |
W_statistic | 2.77329 |
critical | 2.97515 |
Levene's test statistic is also smaller than the critical value and so H0 can't be rejected. To execute Levene's test using the medians of the waves select the blue line below and type Ctrl-Enter:
StatsVariancesTest/T=1/Q/METH=2 data1,data2,data3,data4
N | 30 |
zBar | 5.119 |
W_statistic | 1.11643 |
To execute Levene's test using 10% trimmed means of the waves select the blue line below and type Ctrl-Enter:
StatsVariancesTest/T=1/Q/METH=3 data1,data2,data3,data4
N | 30 |
zBar | 5.26138 |
W_statistic | 1.37371 |
Both modified Levene's tests agree with the original and with Bartlett's test -- H0 can't be rejected. If we replace the wave data4 with data5:
data5 |
46.25 |
46.25 |
38.65 |
56.82 |
69.51 |
62.65 |
28.6 |
28.92 |
Perform Bartlett's test:
StatsVariancesTest/T=1/Q/METH=0 data1,data2,data3,data5
N | 30 |
PooledVariance | 96.5199 |
Bartlett_T | 8.51987 |
In this case the Bartlett's test statistic is larger than the critical value and H0 is rejected. You will get similar results if you execute any of the modified tests as shown below:
Levene's Test
StatsVariancesTest/T=1/Q/METH=1 data1,data2,data3,data5
N | 30 |
zBar | 7.33533 |
W_statistic | 3.7164 |
Modified Levene's test using the median
StatsVariancesTest/T=1/Q/METH=2 data1,data2,data3,data5
N | 30 |
zBar | 7.06833 |
W_statistic | 2.64065 |
Modified Levene's test using 10% trimmed mean
StatsVariancesTest/T=1/Q/METH=3 data1,data2,data3,data5
N | 30 |
zBar | 7.35938 |
W_statistic | 3.38862 |
