The StatsNPMCTest operation supports a number of comparison tests. The following examples illustrate the tests and the optional flags.
1. Tukey type test analysing the data in the following 5 waves:
data1 | data2 | data3 | data4 | data5 |
36.34 | 58.55 | 50.42 | 41.41 | 47.81 |
52.08 | 57 | 40.04 | 64.21 | 46.28 |
50.09 | 44.9 | 41.77 | 58.33 | 59 |
37.81 | 52.66 | 42.61 | 60.37 | 55.73 |
58.98 | 67.99 | 37.75 | 55.32 | 54.58 |
63.93 | 52.98 | 41.42 | 55.75 | 43.74 |
37.55 | 51.1 | 39.48 | 63.74 | 59.02 |
40.64 | 47.96 | 43.79 | 67.86 | 46.75 |
To run the test execute the command:
StatsNPMCTest/T=1/Q/TUK data1,data2,data3,data4,data5
The results are displayed in the NP Multiple Comparison (Tukey) table:
Pair | Difference | SE | q | qc | Conclusion |
data4_vs_data3 | 163 | 33.0656 | 4.9296 | 3.85766 | 0 |
data4_vs_data1 | 116 | 33.0656 | 3.50818 | 3.85766 | 1 |
data4_vs_data5 | 61 | 33.0656 | 1.84482 | 3.85766 | 1 |
data4_vs_data2 | 40 | 33.0656 | 1.20972 | 3.85766 | 1 |
data2_vs_data3 | 123 | 33.0656 | 3.71988 | 3.85766 | 1 |
data2_vs_data1 | 76 | 33.0656 | 2.29846 | 3.85766 | 1 |
data2_vs_data5 | 21 | 33.0656 | 0.635101 | 3.85766 | 1 |
data5_vs_data3 | 102 | 33.0656 | 3.08478 | 3.85766 | 1 |
data5_vs_data1 | 55 | 33.0656 | 1.66336 | 3.85766 | 1 |
data1_vs_data3 | 47 | 33.0656 | 1.42142 | 3.85766 | 1 |
The Tukey test conclusions indicate that at the 0.05 significance level only they hypothesis that the mean of data4 equals the mean of data3 is rejected. All other means are taken to be the same. If we increase the significance level to 0.1 we have:
StatsNPMCTest/T=1/Q/TUK/ALPH=0.1 data1,data2,data3,data4,data5
The results are displayed in the table:
Pair | Diff | SE | q | qc | Conclusion |
data4_vs_data3 | 163 | 33.0656 | 4.9296 | 3.47828 | 0 |
data4_vs_data1 | 116 | 33.0656 | 3.50818 | 3.47828 | 0 |
data4_vs_data5 | 61 | 33.0656 | 1.84482 | 3.47828 | 1 |
data4_vs_data2 | 40 | 33.0656 | 1.20972 | 3.47828 | 1 |
data2_vs_data3 | 123 | 33.0656 | 3.71988 | 3.47828 | 0 |
data2_vs_data1 | 76 | 33.0656 | 2.29846 | 3.47828 | 1 |
data2_vs_data5 | 21 | 33.0656 | 0.635101 | 3.47828 | 1 |
data5_vs_data3 | 102 | 33.0656 | 3.08478 | 3.47828 | 1 |
data5_vs_data1 | 55 | 33.0656 | 1.66336 | 3.47828 | 1 |
data1_vs_data3 | 47 | 33.0656 | 1.42142 | 3.47828 | 1 |
In this case H0 has to be rejected also when comparing data4 with data1 and when comparing data2 with data1.
2. Student-Newman-Keuls test example.
This is a non-parametric variation on the Student-Newman-Keuls test where the standard error is a function of the parameter p (the rank difference). The test requires that all input waves have the same number of points. To run the test execute:
StatsNPMCTest/T=1/Q/SNK data1,data2,data3,data4,data5
The results are displayed in the NP Multiple Comparison (SNK) table:
Pair | Diff | SE | p | qp | qc | Conclusion |
data4_vs_data3 | 163 | 33.0656 | 5 | 4.9296 | 3.85766 | 0 |
data4_vs_data1 | 116 | 26.533 | 4 | 4.37191 | 3.63316 | 0 |
data4_vs_data5 | 61 | 20 | 3 | 3.05 | 3.31449 | 1 |
data4_vs_data2 | 40 | 13.466 | 2 | 2.97044 | 2.77181 | 0 |
data2_vs_data3 | 123 | 26.533 | 4 | 4.63574 | 3.63316 | 0 |
data2_vs_data1 | 76 | 20 | 3 | 3.8 | 3.31449 | 0 |
data2_vs_data5 | 21 | 13.466 | 2 | 1.55948 | 2.77181 | 1 |
data5_vs_data3 | 102 | 20 | 3 | 5.1 | 3.31449 | 0 |
data5_vs_data1 | 55 | 13.466 | 2 | 4.08436 | 2.77181 | 0 |
data1_vs_data3 | 47 | 13.466 | 2 | 3.49027 | 2.77181 | 0 |
In this test the statistic q depends on the value of p and therefore differences between waves tend to be amplified relative to the Tukey test above.
3. Multi-Comparison when waves do not have the same number of points
The Student-Newman-Keuls test above requires that all waves have the same number of points. The Dunn-Holland-Wolfe test supports unequal number of points as well as ties in ranks. In this example we analyze the following waves:
data2 | data3 | data4 | data5 | data6 | data7 |
58.55 | 50.42 | 41.41 | 47.81 | 38.17 | 50.55 |
57 | 40.04 | 64.21 | 46.28 | 36.96 | 49.63 |
44.9 | 41.77 | 58.33 | 59 | 38.28 | 49.57 |
52.66 | 42.61 | 60.37 | 55.73 | 33.13 | 53.92 |
67.99 | 37.75 | 55.32 | 54.58 | 39.97 | 54.4 |
52.98 | 41.42 | 55.75 | 43.74 | 47.99 | 39.62 |
51.1 | 39.48 | 63.74 | 59.02 | 49.66 | |
47.96 | 43.79 | 67.86 | 46.75 | 42.51 |
StatsNPMCTest/T=1/Q/DHW data2,data3,data4,data5,data6,data7
The results are displayed in the NP Multiple Comparison (DHW) table:
Pair | Diff | SE | Q | Qc | Conclusion |
data4_vs_data6 | 26.5 | 6.71131 | 3.94856 | 2.9352 | 0 |
data4_vs_data3 | 24.375 | 6.71131 | 3.63193 | 2.9352 | 0 |
data4_vs_data7 | 12.5 | 7.24904 | 1.72437 | 2.9352 | 1 |
data4_vs_data5 | 8.875 | 6.71131 | 1.32239 | 2.9352 | 1 |
data4_vs_data2 | 5.625 | 6.71131 | 0.838138 | 2.9352 | 1 |
data2_vs_data6 | 20.875 | 6.71131 | 3.11042 | 2.9352 | 0 |
data2_vs_data3 | 18.75 | 6.71131 | 2.79379 | 2.9352 | 1 |
data2_vs_data7 | 6.875 | 7.24904 | 0.948401 | 2.9352 | 1 |
data2_vs_data5 | 3.25 | 6.71131 | 0.484257 | 2.9352 | 1 |
data5_vs_data6 | 17.625 | 6.71131 | 2.62616 | 2.9352 | 1 |
data5_vs_data3 | 15.5 | 6.71131 | 2.30953 | 2.9352 | 1 |
data5_vs_data7 | 3.625 | 7.24904 | 0.500066 | 2.9352 | 1 |
data7_vs_data6 | 14 | 7.24904 | 1.93129 | 2.9352 | 1 |
data7_vs_data3 | 11.875 | 7.24904 | 1.63815 | 2.9352 | 1 |
data3_vs_data6 | 2.125 | 6.71131 | 0.31663 | 2.9352 | 1 |
In this case, the test indicates that we should reject H0 (equality of means) for the pairs data4 and data6, data4 and data3, data2 and data6.
4. Multi-Comparison to a control.
Using the waves data1-data6 above, we can test the hypothesis of equal means (default /TAIL) of each wave compared with the control wave designated as data4. To execute the test, select the blue line below and type Ctrl-Enter:
StatsNPMCTest/T=1/Q/CIDX=3 data1,data2,data3,data4,data5,data6
The results are displayed in NP Multiple Comparison to Control table:
Pair | Diff | SE | q | q' | conclusion |
data4_vs_data6 | 205 | 56 | 3.66071 | 2.51146 | 0 |
data4_vs_data3 | 183 | 56 | 3.26786 | 2.51146 | 0 |
data4_vs_data1 | 135 | 56 | 2.41071 | 2.51146 | 1 |
data4_vs_data5 | 66 | 56 | 1.17857 | 2.51146 | 1 |
data4_vs_data2 | 41 | 56 | 0.732143 | 2.51146 | 1 |
The test concludes that H0 (equal means) has to be rejected for the wave data3 and the wave data6 when compared with the control wave data4.
We can modify the test for H0: μc≤μa using /TAIL=1. Here μc represents the mean of the control wave while μa is the mean of any other wave in the input group.
StatsNPMCTest/T=1/Q/CIDX=3/TAIL=1 data1,data2,data3,data4,data5,data6
Pair | Diff | SE | q | q' | Conclusion |
data4_vs_data6 | 205 | 56 | 3.66071 | 2.23382 | 0 |
data4_vs_data3 | 183 | 56 | 3.26786 | 2.23382 | 0 |
data4_vs_data1 | 135 | 56 | 2.41071 | 2.23382 | 0 |
data4_vs_data5 | 66 | 56 | 1.17857 | 2.23382 | 1 |
data4_vs_data2 | 41 | 56 | 0.732143 | 2.23382 | 1 |
Clearly the mean of the control wave is greater than the means of the waves data1, data3 and data6.
Testing for the other possible tail (H0: μc≥μa ):
StatsNPMCTest/T=1/Q/CIDX=3/TAIL=2 data1,data2,data3,data4,data5,data6
data4_vs_data6 | 205 | 56 | 3.66071 | 2.23382 | 1 |
data4_vs_data3 | 183 | 56 | 3.26786 | 2.23382 | 1 |
data4_vs_data1 | 135 | 56 | 2.41071 | 2.23382 | 1 |
5. Multiple Contrasts
Suppose we wanted to test the hypothesis H0: μ1+μ2+μ3=μ4+μ5+μ6.
You can create the contrast wave using the command:
Make/O/N=6 contrastW={1,1,1,2,2,2}
StatsNPMCTest/T=1/Q/CONW=contrastW data1,data2,data3,data4,data5,data6
The results are displayed in the NP Multiple Contrasts table (shown here transposed):
Contrast | 3.66667 |
SE | 4.04145 |
S | 0.907265 |
Critical_Chai | 3.32724 |
Conclusion | 1 |
