Instead of creating a new wave with Make and filling it with values, you could use Duplicate/R=[][ic]. That will also automatically copy the SetScale information.
I assume you want the graph of the Image Profile for display purposes? This is currently not possible. These tools a meant for processing data, so the idea is to close it when you are done and then build your own graphs. Do you just want the image with a vertically attached profile (like the example in the attachment)? This is easily done with one of my other packages:
Could you please also tell me how (in which way) you want to normalize the data and what is not working here? Basically, you have three options for normalization:
- Each Maximum: Find the maximum in each row (horizontal mode) or column (vertical mode) and normalize to this value
- Div. by Profile: Simply divide by the current profile, so that the selected region (between the red lines) is normalized on average
- Custom user code: You can also write your own normalization function, which is invoked via the user button.
This function will extract the line profiles. It works on an image wave in the current data folder. Input the wave name.
July 7, 2023 at 06:51 am - Permalink
In reply to This function will extract… by jjweimer
Thank you
July 7, 2023 at 07:14 am - Permalink
July 7, 2023 at 07:20 am - Permalink
Ah. Clever. I've updated accordingly.
July 7, 2023 at 07:37 am - Permalink
You could also install my Spectra Image Profile tools, which can do this and a million other things:
https://www.wavemetrics.com/node/21549
The particular function would be under Spectra Tools -> Split Horizontal
July 7, 2023 at 07:49 am - Permalink
Thank you Chozo,
Your spectra tools works very well!
I have a question:
How can I use the image in the format generated by your app?
It is not possible with the duplicate command
Here is an example
Best regards
July 12, 2023 at 05:07 am - Permalink
https://www.wavemetrics.com/node/21562
The steps are as follows:
If you don't want to use yet another package, you could also build such a graph manually. Let me know if you rather want to go this route.
July 12, 2023 at 07:14 am - Permalink
In reply to I assume you want the graph… by chozo
Thank you for your help
July 12, 2023 at 11:41 pm - Permalink
Dear Chozo,
I have another question:
I have been normalizing this image (enclosed here) with your package without success.
Do you know any way to do it?
Best,
Luis
July 18, 2023 at 06:17 am - Permalink
July 18, 2023 at 09:19 am - Permalink
