Image profile
alcarar
Dear all,
I would like to get a multiple automatic horizontal profile (line by line) for the enclosed image
Do you know of the existence of such a procedure?
Dear all,
This function will extract the line profiles. It works on an image wave in the current data folder. Input the wave name.
July 7, 2023 at 06:51 am - Permalink
In reply to This function will extract… by jjweimer
Thank you
July 7, 2023 at 07:14 am - Permalink
Instead of creating a new wave with Make and filling it with values, you could use Duplicate/R=[][ic]. That will also automatically copy the SetScale information.
July 7, 2023 at 07:20 am - Permalink
Ah. Clever. I've updated accordingly.
July 7, 2023 at 07:37 am - Permalink
You could also install my Spectra Image Profile tools, which can do this and a million other things:
https://www.wavemetrics.com/node/21549
The particular function would be under Spectra Tools -> Split Horizontal
July 7, 2023 at 07:49 am - Permalink
Thank you Chozo,
Your spectra tools works very well!
I have a question:
How can I use the image in the format generated by your app?
It is not possible with the duplicate command
Here is an example
Best regards
July 12, 2023 at 05:07 am - Permalink
I assume you want the graph of the Image Profile for display purposes? This is currently not possible. These tools a meant for processing data, so the idea is to close it when you are done and then build your own graphs. Do you just want the image with a vertically attached profile (like the example in the attachment)? This is easily done with one of my other packages:
https://www.wavemetrics.com/node/21562
The steps are as follows:
If you don't want to use yet another package, you could also build such a graph manually. Let me know if you rather want to go this route.
July 12, 2023 at 07:14 am - Permalink
In reply to I assume you want the graph… by chozo
Thank you for your help
July 12, 2023 at 11:41 pm - Permalink
Dear Chozo,
I have another question:
I have been normalizing this image (enclosed here) with your package without success.
Do you know any way to do it?
Best,
Luis
July 18, 2023 at 06:17 am - Permalink
Could you please also tell me how (in which way) you want to normalize the data and what is not working here? Basically, you have three options for normalization:
- Each Maximum: Find the maximum in each row (horizontal mode) or column (vertical mode) and normalize to this value
- Div. by Profile: Simply divide by the current profile, so that the selected region (between the red lines) is normalized on average
- Custom user code: You can also write your own normalization function, which is invoked via the user button.
July 18, 2023 at 09:19 am - Permalink
