replace data path in Fit
i m almost done with writnig my first own larger procedure. In one Function there is still samething, which doesnt work how it should:
Function fitSpotX() // find and return x-component of maximum // read cursor positions Variable Ax=xcsr(A) Variable Ay=vcsr(A) Variable Bx=xcsr(B) Variable By=vcsr(B) //Fit area between cursors CurveFit/Q Gauss2D, :rawData:ONEOUTOFAHUNDRET [Ax,Bx][Ay,By] /D Print "Maximum is at x0=" , K2,"y0=",K4 //return x-coordinate of maximum return K2 End
So the data path needs to be generalized. It shall be always the uppermost Graph, so i tried a little with WinName(0,1)
Till now i couldnt find a solution, can anybody help?
If cursor A is assumed to be on the source wave for the fit in the top graph:
If the wave to be fit is assumed to be the first wave in the top graph:
Then use waveToFit as the source wave in your CurveFit command.
August 7, 2014 at 10:02 pm - Permalink
works perfectly like this:
August 8, 2014 at 12:13 am - Permalink
