replace data path in Fit
Hi guys,
i m almost done with writnig my first own larger procedure. In one Function there is still samething, which doesnt work how it should:
Function fitSpotX()   // find and return x-component of maximum
	// read cursor positions
	Variable Ax=xcsr(A)
	Variable Ay=vcsr(A)
	Variable Bx=xcsr(B)
	Variable By=vcsr(B)
	//Fit area between cursors
	CurveFit/Q Gauss2D, :rawData:ONEOUTOFAHUNDRET [Ax,Bx][Ay,By] /D
	Print "Maximum is at x0=" , K2,"y0=",K4
	//return x-coordinate of maximum
	return K2
So the data path needs to be generalized. It shall be always the uppermost Graph, so i tried a little with WinName(0,1)
Till now i couldnt find a solution, can anybody help?
hrodstein
Assuming that I understand what you want to do ...
If cursor A is assumed to be on the source wave for the fit in the top graph:
	Wave waveToFit = CsrWaveRef(A)
If the wave to be fit is assumed to be the first wave in the top graph:
	Wave waveToFit = WaveRefIndexed("", 0, 1)
Then use waveToFit as the source wave in your CurveFit command.
wolf1988
Thanks hrodstein,
works perfectly like this:
Function fitSpotX()   // find and return x-component ox maximum
	Variable Ax=xcsr(A)
	Variable Ay=vcsr(A)
	Variable Bx=xcsr(B)
	Variable By=vcsr(B)
	Wave waveToFit = CsrWaveRef(A)		//Fit will be from graph with cursor
	CurveFit/Q Gauss2D waveToFit [Ax,Bx][Ay,By]
	Print "The center of this spot is at X=" , K2,"Y=",K4
	return K2
