help to remove NaN points in text waves
I have a bundle of text waves which have Nan values randomly. I want to delete these Nan points, but wavetranform's zapnans only support data wave. So any way to delete these points without using the "delete points" dialog?
proland
You can't have NaNs in a textwave, so i'm assuming you mean empty strings.
Unfortunately, I don't think the conditional operator works on text waves so you'll have to write a little function that uses a for loop to evaluate each element in wave. Something like this should accomplish what you want
wave/t w
variable i
         do
  	 if(strlen(w[i])==0)
  	     deletepoints i, 1, w
  	 i+=1
	while(i<numpnts(w))
Igor
If your text waves contain numbers and NaNs as text, e.g.,
make/t/o ttt={"1","2","nan","3"}
then you can use the following function to clean them up:
Function zapTextNaNs(inWave)
	Wave/T inWave
	Make/Free/N=(numpnts(inWave)) tmp
	tmp=str2num(inWave)
	WaveTransform zapNaNs tmp
	Make/o/T/N=(numpnts(tmp)) cleanText
	cleanText=num2str(tmp)
If your waves contain something else then please give us more details.
tkessler
Without scripting as mentioned above the only way to do this is to edit them followed by selecting sections of empty cells and pressing Command/Control-X to cut them from the wave, though this is usually easiest for a smaller number of waves.
jtigor
wwzhang2 wrote: Thank you. proland is right, it is empty strings.
Depending on the nature of the text values in your wave (if they are numbers, as AG guessed), AG's solution may still be useful as str2num translates an empty string to NAN.
PeterR
This is a function I am using to get rid of TRAILING Nans in TextWaves:
// Handy Function to delete trailing NaNs from TextWaves:
Function DeleteNaNTextwave(W)
Wave /T W
Variable i=0, NOP
	Do
	NOP = numpnts(W)
	if((strlen(W [i]) == 0)||(cmpstr("",W [i]) == 0))
		DeletePoints i, 1, W
		i = 0 // Start over again
	i = i+1
	while(strlen(w[NOP])==0)
hrodstein
This works without starting over, by starting from the end and working toward the beginning.
Function DeleteEmptyCellsFromTextWave(tw)
	Wave/T tw
	Variable numPoints = numpnts(tw)
	Variable i
	for(i=numPoints-1; i>=0; i-=1)
		if (strlen(tw[i]) == 0)
			DeletePoints i, 1, tw
