    VDT2: Read from ComPort
I tried to read from a specific Comport which can be choosen from an popup menu. But unfortently if I try to specify the port by S_Value no access to this port is possible. Instead if I write COM1 everything is fine.
Function initPem()
Variable num
controlInfo PopCom
VDTOperationsPort2 S_Value
VDTWrite2 "W\r"
Sleep/T 10
VDTRead2/O=0.5 num
Thanks a lot
You need to convert the contents of S_value into a name. That is what the $ operator does. So use:
You need to use $S_value. For details execute:
VDTOperationsPort2 $S_ValueOctober 4, 2013 at 05:12 pm - Permalink
October 4, 2013 at 10:39 pm - Permalink
