Weird wavestats bug..
short version:
function function1(thresh) variable thresh wave wave1,wave2,wave3,wave4,wave5 //preexisting waves in the current experiment do some stuff function2(wave1,wave3) // edits wave1 based on information in wave3 do some more stuff give me nice graphs thanks Igor end function2(wave1,wave3) wave wave1,wave3 wavestats wave1 variable num = V_npntns wavestats wave3 variable num2 = V_npnts// <-- this is the line that gets highlighted in the debugger, the syntax is identical to the lines above. do some stuff to wave1 based on num and num2 end
The actual code is here:
#pragma rtGlobals=3 // Use modern global access method and strict wave access. function Joint_Hist(thresh) variable thresh wave frame, seq_length, intensitych1, intensitych2,ca_conc,amplitudech1,amplitudech2 duplicate/o frame f_key duplicate/o intensitych1 int_1 duplicate/o intensitych2 int_2 duplicate/o int_2 density density /= int_1 matrixop/o density = replace(density, NaN, 0) int_1 = sqrt(intensitych1) sort int_1,int_1,int_2,f_key,density join_frames(f_key,seq_length) wave x_wave = int_1 wave y_wave = f_key wavestats/q/m=1 y_wave variable y_dim_max = ceil(V_max) variable y_dim_min = floor(V_min) print "y_max is" ,y_dim_max print "y_min is", y_dim_min variable y_bins = y_dim_max - y_dim_min + 1 //print y_bins variable num = V_npnts wavestats/q/m=1 x_wave variable x_dim_max = ceil(V_max) print "x_max is",x_dim_max variable x_dim_min = floor(V_min) print "x_min is", x_dim_min variable num_bins = 20 // edit this to play with bin resolution //print num_bins variable x_delta = (x_dim_max - x_dim_min) / num_bins print "x_delta is",x_delta //Build final output waves make/o/d/n=(num_bins,y_bins) size_hist make/o/d/n=(num_bins,y_bins,2) density_hist make/o/d/n=(num_bins,y_bins) density_values make/o/d/n=(0,3) reject_points //print "num =",num //variable thresh = 10 //V_avg + 3*V_sdev //print "threshold density is",thresh variable i,j,n variable x_pos, y_pos variable max_depth = 0 variable max_errors = 0 for (i=0;i<num;i+=1) //print i for (j=0;j<num_bins;j+=1) if (x_wave[i] - x_dim_min >= (j*x_delta) && x_wave[i] - x_dim_min < (j+1)*x_delta) //add a second if-loop to kick out bad data if (density[i]<= thresh) x_pos = j y_pos = y_wave[i] - y_dim_min n = size_hist[x_pos][y_pos] // dont iterate n, it corrects the iterate from zero problem size_hist[x_pos][y_pos]+= 1 //check number of binned points and increase matrix depth if needed if (n > max_depth) insertpoints/m=2 (max_depth + 1), 1, density_values max_depth +=1 endif density_values[x_pos][y_pos][n] = density[i] else max_errors +=1 insertpoints (max_errors),1, reject_points reject_points[max_errors-1][0] = i reject_points[max_errors-1][1] = density[i] reject_points[max_errors-1][2] = frame[i] endif break endif endfor endfor // move thru the data matrix and fill in the final histogram for (i=0;i<num_bins ; i+=1) for(j=0;j<y_bins ;j+=1) //print "(i , j) =", i,",",j n = size_hist[i][j] -1 // if number of counts = 0, the next line duplicates the entire wave. but the whole wave will be zeros so that is ok. for now. //duplicate/o/r=[i,i][j,j][0,n] density_values temp_wave duplicate/o/r=[i,i][j,j][0,max_depth-1] density_values temp_wave redimension/n=(max_depth) temp_wave wavestats/r=[0,n]/q temp_wave density_hist[i][j][0] = V_avg density_hist[i][j][1] = V_sdev endfor endfor newimage/N=density_graph density_hist SetAxis/W=density_graph/A left ModifyImage/w=density_graph density_hist ctab= {*,*,Grays,1} newimage/N=size_graph size_hist setaxis/W=size_graph/a left modifyimage/w=size_graph size_hist ctab= {*,*,Grays,1} end
and the sub function that gets called with the error
#pragma rtGlobals=3 // Use modern global access method and strict wave access. function Join_Frames(frames,seq_lengths) wave frames, seq_lengths wavestats/q/m=1 frames variable i, j variable num = V_npnts wavestats/q/m=1 seq_lengths variable total_seq = V_npnts // <-- this line gets pointed out in debugger variable a, b a=0 for (i=0;i<total_seq;i+=1) b= sum(seq_lengths,0,i) - 1 for (j=0;j<num;j+=1) if (frames[j] >= a && frames[j] <=b) frames[j] = i endif endfor a = b + 1 endfor end
August 19, 2013 at 06:21 am - Permalink
EDIT: not only did numpnts fix the problem, it caused the program to run MUCH faster (basically instantaneously versus 20 to 30 seconds). This is strange, as the wavestats statements were only called twice, not in a loop, and I even used the /m=1 parameter to limit the statistics produced...
August 19, 2013 at 06:36 am - Permalink
August 19, 2013 at 07:11 am - Permalink
Then I run the joint_hist function, which is told that seq_length is a wave, and passes it accordingly to join_frames. Join_frames actually does its job correctly here (or I would know immediately from the output, but ive also tested with print statements), but I still get the error message after the program is done running. Which as I mentioned above, takes a significantly longer amount of time to do so.
I did run it thru the data bugger, but I am brand spanking new to that machine, so other than pointing out the line it says is troublesome, I have no idea what it is telling me yet..
EDIT: On second thought, I think I am forgetting to load seq_length, and am instead using a copy of the treated wave, such that join_frames is probably failing but it doesnt matter since ive already got the data i need. OOPS. Thanks for the headsup, I spent two hours trying to solve this so far. *embarrassed*
August 19, 2013 at 07:42 am - Permalink
When doing development these should be turned on all the time.
August 19, 2013 at 09:32 am - Permalink
August 20, 2013 at 12:55 am - Permalink
