How to correctly do a curve fitting
I am trying to do an exponential fit for a x and y dataset (see attached Figure, upper one). I used the exp (or exp_XOffset) function under "Analysis"--"Curve fitting" and got something weird (se attached Figure, lower one). Did I use the wrong function or? Or is there a way to simply draw a line (y=0.4 exp(0.05x)) manually?
Thanks!!
You are trying to fit a growing exponential (an exponential with negative decay constant). The auto-guessing routines can't handle that, you need to select Manual Guesses on the Coefficients tab of the Curve Fit dialog and enter your own guesses in the Coefficients list.
Ok. I thought it was easier. Thank you! Still want to know, is there a way to simply draw a line (y=0.4 exp(0.05x)) manually on the figure?
shen2 wrote: ... Still want to know, is there a way to simply draw a line (y=0.4 exp(0.05x)) manually on the figure?
make/N=160 ewave
SetScale/I x, 0,16, "", ewave
appendtograph ewave
ewave = 0.4*exp(0.05*x)
Is there a way to simply draw a line (y=0.4 exp(0.05x)) manually?
Make/O/N=200 demo
SetScale x 0, 16, "", demo
demo=0.4 * exp(0.05*x)
Display demo
For details execute
DisplayHelpTopic "Function Plotting"
