I am trying to do an exponential fit for a x and y dataset (see attached Figure, upper one). I used the exp (or exp_XOffset) function under "Analysis"--"Curve fitting" and got something weird (se attached Figure, lower one). Did I use the wrong function or? Or is there a way to simply draw a line (y=0.4 exp(0.05x)) manually?
You are trying to fit a growing exponential (an exponential with negative decay constant). The auto-guessing routines can't handle that, you need to select Manual Guesses on the Coefficients tab of the Curve Fit dialog and enter your own guesses in the Coefficients list.
August 12, 2013 at 08:54 am - Permalink
August 12, 2013 at 10:02 am - Permalink
SetScale/I x, 0,16, "", ewave
appendtograph ewave
ewave = 0.4*exp(0.05*x)
August 12, 2013 at 10:51 am - Permalink
SetScale x 0, 16, "", demo
demo=0.4 * exp(0.05*x)
Display demo
For details execute
August 12, 2013 at 10:55 am - Permalink
August 12, 2013 at 11:56 am - Permalink
