Correlated Gaussian Random Variables
The function gnoise1 returns a nsample copies of m correlated random variables with mean = 0 and specified covariance matrix var. The algorithm uses the standard Cholesky decomposition (see section on Monte Carlo simulation at http://en.wikipedia.org/wiki/Cholesky_decomposition ). The matrix var must be symmetric and positive definite.
Function gnoise1(var,n)                                    // n draws of m-dim vector of corr. noise
	wave var; variable n                               // var must be sym, pos-def. matrix
	variable m=dimsize(var,0)
	MatrixOp /free cholesky=chol(var)                    // compute Cholesky decomposition
	make /d/free/n=(n,m) uncorr=gnoise(1)             // uncorrelated N(0,1) data
	MatrixOp /o corrdat = uncorr x cholesky
Here is a driver routine to demonstrate how it works (for 2d noise of specified correlation coefficient rho):
Function Demo2d(s1,s2,rho,nsamples,)
	variable s1,s2,rho,nsamples				       // correlation coeff:  -1 < rho < 1
	make /d/o/n=(2,2) var={{s1^2, rho*s1*s2},{rho*s1*s2,s2^2}}	   // make 2x2 covariance matrix
	gnoise1(var,nsamples);		wave corrdat
	Display corrdat[*][1] vs corrdat[*][0]
	ModifyGraph height={Plan,1,left,bottom}, mode=2, lSize=2
You can call it with
Demo2d(1,1,0.9,1e4)
and it should look like the attached graph.
Bech's code snippet can be used to visualise covariance matrices obtained from a Curvefitting algorithm, typically
Funcfit
It needs to be adapted a bit in this case, as the covariance matrix has NaN entries for the parameters that are being held. The following code snippet takes the fitted coefficients from Funcfit, along with the covariance matrix, and the holdstring (specifying which parameters are being held), and creates 2D wave called M_montecarlo.
This wave has howmany rows, and numpnts(coefs) columns.
Each of the rows contains a set of parameters which could be fed to the fit function used. Futhermore, for a given (parameter) column the mean and standard deviation of that column is equal to the fitted parameter and it's uncertainty. Moreover, different columns possess the correct covariance as specified by the input covariance matrix.
Function gen_synthMCfmCovar(coefs, M_covar, holdstring, howmany)
        //coefs from the curvefitting
        //M_covar from the curvefitting output
        //holdstring - the holdstring used for the fit.
        //how many samples you want to synthesize.
	wave coefs, m_covar
	string holdstring
	variable howmany
	variable varying = 0, ii, whichcol
	duplicate/free coefs, tempcoefs
	duplicate/free M_covar, tempM_covar
	varying = strlen(holdstring)
	for(ii = dimsize(coefs, 0)-1 ; ii >= 0 ; ii-=1)
		if(str2num(holdstring[ii]))
			deletepoints/M=0 ii, 1, tempcoefs, tempM_covar
			deletepoints/M=1 ii, 1, tempM_covar
			varying -=1
	//create some gaussian noise
	make /free/d/n=(varying, howmany) noises = gnoise(1., 2)
	//and create the correlated noise from the covariance matrix.
	matrixop/free correlatedNoises = (chol(tempm_covar) x noises)^t
	make/n=(howmany, dimsize(coefs, 0))/d/o M_montecarlo
	Multithread M_montecarlo[][] = coefs[q]
	//now add the correlated noise back to the parameters
	whichcol = dimsize(correlatedNoises, 1) - 1
		if(!str2num(holdstring[ii]))
			M_montecarlo[][ii] += correlatedNoises[p][whichCol]
			whichCol -= 1
Very nice snippet!
I couldn't resist the temptation to try it in 3D. The new command line, demo function and Gizmo macro are:
•Demo3d(1,1,1,0.9,1e4)
Function Demo3d(s1,s2,s3,rho,nsamples,)
	variable s1,s2,s3,rho,nsamples				       // correlation coeff:  -1 < rho < 1
	make /d/o/n=(3,3) var2={{s1^2, rho*s1*s2, rho^2*s1*s3},{rho*s1*s2,s2^2, rho*s2*s3}, {rho^2*s1*s3,rho*s2*s3,s3^2}}	   // make 3x3 covariance matrix
	gnoise1(var2,nsamples);
	wave corrdat
	Execute "Gizmo0()"
Window Gizmo0() : GizmoPlot
	PauseUpdate; Silent 1	// Building Gizmo 6 window...
	// Do nothing if the Gizmo XOP is not available.
	if(exists("NewGizmo")!=4)
		DoAlert 0, "Gizmo XOP must be installed"
		return
	NewGizmo/N=Gizmo0/T="Gizmo0"
	ModifyGizmo startRecMacro
	MoveWindow 17.25,53.75,317.25,289.25
	AppendToGizmo Scatter=root:corrdat,name=scatter0
	ModifyGizmo ModifyObject=scatter0 property={ scatterColorType,3}
	ModifyGizmo ModifyObject=scatter0 property={ markerType,0}
	ModifyGizmo ModifyObject=scatter0 property={ sizeType,0}
	ModifyGizmo ModifyObject=scatter0 property={ rotationType,0}
	ModifyGizmo ModifyObject=scatter0 property={ Shape,1}
	ModifyGizmo ModifyObject=scatter0 property={ size,1}
	ModifyGizmo ModifyObject=scatter0 property={ markerCTab,Rainbow}
	ModifyGizmo ModifyObject=scatter0 property={ CTABScaling,16}
	AppendToGizmo Axes=boxAxes,name=axes0
	ModifyGizmo ModifyObject=axes0,property={0,axisRange,-1,-1,-1,1,-1,-1}
	ModifyGizmo ModifyObject=axes0,property={1,axisRange,-1,-1,-1,-1,1,-1}
	ModifyGizmo ModifyObject=axes0,property={2,axisRange,-1,-1,-1,-1,-1,1}
	ModifyGizmo ModifyObject=axes0,property={3,axisRange,-1,1,-1,-1,1,1}
	ModifyGizmo ModifyObject=axes0,property={4,axisRange,1,1,-1,1,1,1}
	ModifyGizmo ModifyObject=axes0,property={5,axisRange,1,-1,-1,1,-1,1}
	ModifyGizmo ModifyObject=axes0,property={6,axisRange,-1,-1,1,-1,1,1}
	ModifyGizmo ModifyObject=axes0,property={7,axisRange,1,-1,1,1,1,1}
	ModifyGizmo ModifyObject=axes0,property={8,axisRange,1,-1,-1,1,1,-1}
	ModifyGizmo ModifyObject=axes0,property={9,axisRange,-1,1,-1,1,1,-1}
	ModifyGizmo ModifyObject=axes0,property={10,axisRange,-1,1,1,1,1,1}
	ModifyGizmo ModifyObject=axes0,property={11,axisRange,-1,-1,1,1,-1,1}
	ModifyGizmo ModifyObject=axes0,property={-1,axisScalingMode,1}
	ModifyGizmo ModifyObject=axes0,property={-1,axisColor,0,0,0,1}
	ModifyGizmo modifyObject=axes0 property={Clipped,0}
	AppendToGizmo freeAxesCue={0,0,0,1},name=freeAxesCue0
	ModifyGizmo setDisplayList=0, opName=ortho0, operation=ortho, data={-2.5,2.5,-2,2,-2,2}
	ModifyGizmo setDisplayList=1, object=freeAxesCue0
	ModifyGizmo setDisplayList=2, object=scatter0
	ModifyGizmo setDisplayList=3, object=axes0
	ModifyGizmo SETQUATERNION={-0.197844,0.141310,0.028073,0.969590}
	ModifyGizmo autoscaling=1
	ModifyGizmo currentGroupObject=""
	ModifyGizmo compile
	ModifyGizmo userString={wmgizmo_df,"Gizmo0"}
	ModifyGizmo endRecMacro
The Gizmo plot should resemble the attached figure. (The Gizmo Macro and figure have been updated to include a display enhancement suggested by WaveMetrics' AG.)
Gizmo0ExportedNew.pdf (15.28 KB)
