Panel with 'Enter' as default Ok button action.
I'm trying to build a small panel, that is supposed to resemble a dialog. Purpose is to enter a numeric value and store it in a global variable. The panel has for this purpose a SetVariable field and two buttons (OK and Cancel).
I'm handling the button actions via proc calls. Entering a value in the field and using the mouse to cancel or confirm the set value works fine.
What I miss is having the Return/Enter Buttons on the keyboard act as if clicking the corresponding button. I can't help but find no way to handle this?
With best regards, Lars Sölter
Function /S UI_NVarInput( varname, panelname ) : Panel String varname String panelname String windowname String usrdat = "" String tmpvarname = varname+"_DNVI" NVAR numvar = $(varname) NVAR tmpnumvar = $(tmpvarname) usrdat = ReplaceStringByKey( "NVARNAME", usrdat, varname, "=" ) if( NVAR_Exists( tmpnumvar ) == 0 ) Variable/G/D $(tmpvarname) = 0 NVAR tmpnumvar = $(tmpvarname) endif if( NVAR_Exists( numvar ) == 1 ) tmpnumvar = numvar endif usrdat = ReplaceStringByKey( "TMPNVARNAME", usrdat, tmpvarname, "=" ) PauseUpdate; Silent 1 // building window... NewPanel /FLT=2 /K=1 /N=UI_NVarInput /W=(267,122,586,236) as panelname windowname = S_name SetDrawLayer UserBack SetDrawEnv fname= "Segoe UI" DrawText 15, 30, "Name" SetDrawEnv fname= "Andale Mono" DrawText 60, 30, varname SetDrawEnv fname= "Segoe UI" DrawText 15, 55, "Value" SetVariable PanVar1 value=tmpnumvar, title=" ", pos={60,40}, size={240,10}, limits={-inf,inf,0}, font="Andale Mono" Button ButtonOk, pos={140,78}, size={70,22}, userdata=usrdat, proc=UI_NVarInput_Ok, title="Ok" Button ButtonOk,font="Segoe UI" Button ButtonCancel, pos={230,78}, size={70,22}, font="Segoe UI", userdata=usrdat, proc=UI_NVarInput_Cancel, title="Cancel" Button ButtonCancel,font="Segoe UI" return windowname End Function UI_NVarInput_Ok( s ) : ButtonControl STRUCT WMButtonAction &s String varname varname = StringByKey( "NVARNAME", GetUserData( s.win, s.ctrlName, "" ), "=" ) NVAR numvar = $(varname) String tmpvarname tmpvarname = StringByKey( "TMPNVARNAME", GetUserData( s.win, s.ctrlName, "" ), "=" ) NVAR tmpnumvar = $(tmpvarname) switch( s.eventCode ) case 2: // mouse up if( NVAR_Exists( tmpnumvar ) == 1 ) if( NVAR_Exists( numvar ) == 0 ) Variable/G/D $(varname) = 0 NVAR numvar = $(varname) endif numvar = tmpnumvar KillVariables /Z $tmpvarname endif KillWindow $s.win break endswitch End Function UI_NVarInput_Cancel( s ) : ButtonControl STRUCT WMButtonAction &s String tmpvarname tmpvarname = StringByKey( "TMPNVARNAME", GetUserData( s.win, s.ctrlName, "" ), "=" ) switch( s.eventCode ) case 2: // mouse up KillVariables /Z $tmpvarname KillWindow $s.win break endswitch End
First, run Panel0(). Then try clicking the button or pressing Enter.
Read about window hooks:
DisplayHelpTopic "Window Hook Functions"
My example uses a named hook function, which is preferred:
DisplayHelpTopic "Named Window Hook Functions"
March 13, 2013 at 12:52 pm - Permalink
I added the setvariable hook to John's Panel
March 13, 2013 at 02:36 pm - Permalink
Regards, Lars
March 14, 2013 at 07:05 am - Permalink
