Category plots: a serious limitation in Igor Pro?
I am facing serious limitation in Igor pro. I have data points on the y-axis going from -15 to 5. The category plot can only be plotted growing up from zero and hence my column is inversed. I tried every single way to try to plot a column growing upwards from -15 to 5 but failed.
Any suggestion?
Kind regards,
Katy
I think the problem is to do with that the base line of category plots is always set to positive number or zero but negative values are not possible! A real challenge!
Thanks
Katy
December 16, 2012 at 05:39 pm - Permalink
December 16, 2012 at 08:56 pm - Permalink
December 16, 2012 at 11:39 pm - Permalink
