How to use Function in ipf file for raw data?
1. I have 2 rows data set (Scattering vector vs. Intensity) and trying to fit this with already written function in ipf script.
Where I should start from? I know this question is really obscure but I think just one comment will help me to start with.
2. In addition, I have a set of script (ipf file) How I can make a Table from this ipf script?
Function Make3GaussPoints(w3,z3)
Wave w3,z3
// printf "in make Gauss Pts\r"
z3[0] = -.993128599185095
z3[1] = -.963971927277914
z3[2] = -.912234428251326
w3[0] = .0176140071391521
w3[1] = .0406014298003869
w3[2] = .062672048334109
// printf "w[0],z[0] = %g %g\r", w3[0],z3[0]
3. I couldn't make it with Procedure window and I just typed in the Command window and it worked....
Make/D/N=4 wave1, wave2
Printf "in make Gauss Pts\r"
in make Gauss Pts
Wave1[0] = -.993128599185095
Wave1[1] = -.963971927277914
Wave1[2] = -.912234428251326
Wave1[3] = -.839116971822219
Wave2[0] = .0176140071391521
Wave2[1] = .0406014298003869
Wave2[2] = .0626720483341091
Wave2[3] = .0832767415767047
Printf "wave1[0],wave2[0] = %g %g\r", wave1[0],wave2[0]
wave1[0],wave2[0] = -0.993129 0.017614
Display wave2 vs wave1
Print wave1, wave2
wave1[0]= {-0.993129,-0.963972,-0.912234,-0.839117}
wave2[0]= {0.017614,0.0406014,0.062672,0.0832767}
Thanks for your comment.
Execute the following in the command line:
DisplayHelpTopic "Curve Fitting Using the Curve Fitting Dialog"
and be sure to click on "User-Defined Fitting Function: Detailed Description".
Use the
Edit
operation. Remember that you can get help on any built-in operation or function by typing its name in the command line (or procedure window), right-clicking on it, and selecting the help item from the contextual menu.If you have a set of Igor commands then chances are quite good that you can automate them by putting them into a function. Here's an example:
Then execute "MyFunction()" on the command line. Experiment from there, and also try reading
DisplayHelpTopic "User-Defined Functions"
.November 18, 2012 at 11:26 am - Permalink
November 19, 2012 at 09:37 am - Permalink
November 20, 2012 at 09:01 am - Permalink
