using LoadWave without breaking down the columns into individual waves
vishivishi
Hello all,
I have two (for example) datasets in 64 x 250 form in .txt files. I want to use LoadWave to browse and load the whole files as waves so that I end up with just those two waves in the data folder. I am trying to modify the code below (which is so far breaking my individual files into 64 individual waves). Any help is much appreciated!
Vishi
Function CustomWaveSelect(fileName, pathName) String fileName // Name of file to load or "" to get dialog String pathName // Name of path or "" to get dialog Variable numwaves Variable indexwaves = 0 Prompt numwaves, "Enter number of waves to be plotted" // Set prompt for number of waves DoPrompt "Enter number of waves", numwaves if (V_Flag) return -1 // User canceled endif for (indexwaves=0;indexwaves <numwaves;indexwaves+=1) // Load the waves and set the local variables. LoadWave/J/D/O/P=$pathName fileName if (V_flag==0) // No waves loaded. Perhaps user canceled. return -1 endif endfor End
February 13, 2012 at 03:36 pm - Permalink
February 13, 2012 at 04:07 pm - Permalink
February 13, 2012 at 04:19 pm - Permalink
February 13, 2012 at 05:48 pm - Permalink
