anyone use the functions bat lbat?
The functions bat and batl look DARN useful for batch operations. Last maintained by Geoff Dutton in 2004.
You can get it from here:
ftp://ftp.wavemetrics.net/IgorPro/User_Contributions/BatchStringUtilsDu…
I had to edit the following lines, turning pipes "|" to forward slashs to get the code to compile.
offset2= strlen(lst) | so that trailing separator is not needed
offset = strsearch(separator+tempLst,separator+item+separator,offset) | search for ";item;"
I am still trying to figure how to input arguments for this code, however.
For example, this command should subtract wave1 from all waves prefixed by corr_, but no cigar.
 bat(" at -= wave1", "corr_*")
Any suggestions? Does anyone else use this procedure?
I don't use this code and it looks pretty old (from the use of "|" for comments). The bat function seems to work for me. You should use the "@" symbol to indicate the place to substitute waves selected with wildcards. For example
 bat(" @ -= wave1", "corr_*")
When "at" is used as shown in the quote above, you should receive an error from Igor.
Also, as far as I can tell, you can safely eliminate the function GetStrFromListNOAH() by substituting calls to it with the built in function StringFromList(). For example in the function bat substitute
com = genCom("@", op, GetStrFromListNOAH(lst, inc, ";"))
with
com = genCom("@", op, StringFromList(inc, lst, ";"))
