anyone use the functions bat lbat?
You can get it from here:
ftp://ftp.wavemetrics.net/IgorPro/User_Contributions/BatchStringUtilsDu…
I had to edit the following lines, turning pipes "|" to forward slashs to get the code to compile.
offset2= strlen(lst) | so that trailing separator is not needed
offset = strsearch(separator+tempLst,separator+item+separator,offset) | search for ";item;"
I am still trying to figure how to input arguments for this code, however.
For example, this command should subtract wave1 from all waves prefixed by corr_, but no cigar.
bat(" at -= wave1", "corr_*")
Any suggestions? Does anyone else use this procedure?
I don't use this code and it looks pretty old (from the use of "|" for comments). The bat function seems to work for me. You should use the "@" symbol to indicate the place to substitute waves selected with wildcards. For example
bat(" @ -= wave1", "corr_*")
When "at" is used as shown in the quote above, you should receive an error from Igor.
December 30, 2011 at 08:38 am - Permalink
com = genCom("@", op, GetStrFromListNOAH(lst, inc, ";"))
with
com = genCom("@", op, StringFromList(inc, lst, ";"))
December 30, 2011 at 09:04 am - Permalink
December 30, 2011 at 12:15 pm - Permalink
