Print date and time header on layouts
aclight
As of this writing, Igor Pro does not have the capability to automatically print a header or footer on every printed page. However, using a bit of code, you can simulate this behavior.
For example, if you create a layout and execute the following lines you will have a text box at the upper left corner of the layout which contains the date and time. When you select File | Print to print the layout, the time and date will be updated before the layout is printed (assuming you also have copied the function below into a procedure file that is opened in your current experiment).
String infoBox
infoBox = "\{\"%s %s\", Secs2Date(DateTime, 0), Secs2Time(DateTime, 3)}"
TextBox/C/N=infoBox/F=0/A=LT/X=0/Y=0 infoBox
The code that creates this text box uses dynamic escape codes. For more information on how to use dynamic escape codes, execute the following command from the Igor Pro command window:
DisplayHelpTopic "Other Dynamic Escape Codes"
In order for this text box to be updated every time the layout is printed, the function below should be copied into a procedure file in each experiment you want to be able to print this information. You can also copy the function into a procedure file and save that file (or a shortcut to it) in your Igor Pro Folder:Igor Procedures folder/directory. This function only updates any annotations on a layout when the layout is printed. You need to first add an annotation to the layout with the information you want (as in the example above).
Function IgorMenuHook(isSel, menuStr, itemStr, itemNo, topWindowName, wt)
Variable isSel
String menuStr, itemStr
Variable itemNo
String topWindowName
Variable wt
if (cmpstr(menuStr, "File") == 0 && cmpstr(itemStr, "Print") == 0)
if (wt == 3) // only respond if a layout is about to be printed
String annotations = AnnotationList(topWindowName)
Variable n, numAnnotations = ItemsInList(annotations, ";")
String currentAnnotation, currentAnnotationInfo, annotationType
For (n=0; n<numAnnotations; n+=1)
currentAnnotation = StringFromList(n, annotations, ";")
currentAnnotationInfo = AnnotationInfo(topWindowName, currentAnnotation)
annotationType = StringByKey("TYPE", currentAnnotationInfo, ":", ";")
StrSwitch (annotationType)
Case "Tag":
Tag/W=$(topWindowName)/C/N=$(currentAnnotation)
break
Case "Textbox":
Textbox/W=$(topWindowName)/C/N=$(currentAnnotation)
break
Case "ColorScale":
ColorScale/W=$(topWindowName)/C/N=$(currentAnnotation)
break
Case "Legend":
Legend/W=$(topWindowName)/C/N=$(currentAnnotation)
break
EndSwitch
EndFor
Variable isSel
Variable itemNo
Variable wt
Case "Tag":
break
Case "Textbox":
break
Case "ColorScale":
break
Case "Legend":
break
EndSwitch
EndFor
If you want to add text boxes to graphs and you also want those to be updated before printing, you need to make a minor modification to the function above. Find the line that reads:
and change it to this line:
if (wt == 3 || wt == 2) // only respond if a layout or a graph is about to be printed
November 23, 2011 at 08:29 pm - Permalink
