Complex numbers and MatrixOp
While working on some code that utilizes complex numbers in matrices, I noticed that the MatrixOp/c operation doesn't always seem to work properly. To simplify an example, I made two complex matrices (B and A, 2x2) and performed MatrixOp/o/c C=B x A to perform matrix multiplication.
Afterwards, I changed one number in matrix B and repeated the operation. In some cases, matrix C was calculated correctly, while in other cases it did not update at all, even after repeatedly issuing the command.
I've compiled a word document showing the matrices used, changes made, and resulting calculated matrix C.
Any thoughts to this problem? Am I performing the matrix multiplication incorrectly?
Thank you.
[quote=proland]
[/quote]
If you think that MatrixOP does not give you the correct results please send an *IGOR* experiment containing the necessary information to support@wavemetrics.com
October 21, 2011 at 09:38 am - Permalink
In addition, when doing the test described in my original post, it seems that if you do not click outside of the cell that was changed in the table, it isn't actually updated. So while I saw a new matrix in the table, the previous values were used in the calculations since the actual wave hadn't been updated. Sorry for the confusion.
October 24, 2011 at 01:23 pm - Permalink
