no child data folder of that name exists
For example, if i want to invoke these operations( i know they dont mean nothing to you);
MES 40,0,1,0 or SPT 0,0 igor shows me the error.
What kind of error is "no child data folder of that name exists"? Why am i getting it?
I'm not sure why you are getting this error, as I do not know your code, however it may be how you are searching for this child folder. For instance, if you have three folders within the root folder, they are each children of root. So long as your current data folder is root, you can find these children. However, if you set the current data folder to child1 and then search for child2, you will not find it as it is not a child of your current data folder.
Take a look through your code focusing on sections which set the current data folder.
When it comes down to it, the most likely causes for this error are as follows:
1. The folder does not exist
2. The folder has the wrong name
3. The folder is not a child of the current data folder
August 30, 2011 at 09:25 am - Permalink
