Simple Text/Font Question:: How to make overbars?
Can someone tell me how to make an overbar when I am editing the legend of a graph? An Overbar is a horizontal line over a letter for example. It is like the opposite of underlining a letter.
BIG Thanks,
n-x-inelastic
This has four escape sequences introduced by double-backslashes:
\\[1 means "store the current text info (font, size, style, X position, y position) in text info variable 1
\\y+40 means move up 80 percent of the height of the current font
\\L1500 means draw a line from the current X position to the X position stored in text info variable 1
\\y-40 means move down 80 percent of the height of the current font
Double-backslashes are used in literal text to represent a single backslash. If you were entering this in the Add Annotation dialog, you would use a single backslash and the dialog would convert it to double backslashes.
To learn more about this arcane subject, execute:
To see all of the codes available in a textbox or legend, execute:
and scroll down to the Details section.
June 13, 2011 at 11:14 pm - Permalink
Thanks again.
June 13, 2011 at 11:39 pm - Permalink
