Condensing Code for Similar Functions
CheckBox Series,pos={151,70},size={64,14},proc=CheckProc,title="Series 1"
CheckBox Series,fStyle=17,variable= V
Function CheckProc(ctrlName, x) : CheckBoxControl
String ctrlName
Variable x
Another_function ()
So for example,
CheckBox Series_1,pos={151,70},size={64,14},proc=CheckProc_1,title="Series 1"
CheckBox Series_1,fStyle=17,variable= V_1
CheckBox Series_2,pos={151,95},size={64,14},proc=CheckProc_2,title="Series 2"
CheckBox Series_2,fStyle=17,variable= V_2
Function CheckProc_1(ctrlName, x) : CheckBoxControl
String ctrlName
Variable x
Another_function ()
Function CheckProc_2(ctrlName, x) : CheckBoxControl
String ctrlName
Variable x
Another_function ()
Many thanks!
May 26, 2011 at 09:39 am - Permalink
May 31, 2011 at 09:44 am - Permalink
It makes a panel and condenses the creation of as many checkboxes as you like in a loop. Checkboxes and their control variables share common base names with a numeric extension.
In this example a single, very simple example procedure is called when the boxes are "clicked".
May 31, 2011 at 01:57 pm - Permalink
(EDIT)
Oh. My apologies. Now I understand. You want to have a code create a panel for you. For that, use the code by jtigor, however the procedure name can just be CheckProc with the above code to automatically call depending on check box name.
May 31, 2011 at 03:18 pm - Permalink
You *do* have to have a different action procedure for different types of controls because they each carry different kinds of information.
June 1, 2011 at 09:30 am - Permalink
June 10, 2011 at 10:19 am - Permalink
