Condensing Code for Similar Functions
Ken
CheckBox Series,pos={151,70},size={64,14},proc=CheckProc,title="Series 1"
CheckBox Series,fStyle=17,variable= V
Function CheckProc(ctrlName, x) : CheckBoxControl
String ctrlName
Variable x
Another_function ()
So for example,
CheckBox Series_1,pos={151,70},size={64,14},proc=CheckProc_1,title="Series 1"
CheckBox Series_1,fStyle=17,variable= V_1
CheckBox Series_2,pos={151,95},size={64,14},proc=CheckProc_2,title="Series 2"
CheckBox Series_2,fStyle=17,variable= V_2
Function CheckProc_1(ctrlName, x) : CheckBoxControl
String ctrlName
Variable x
Another_function ()
Function CheckProc_2(ctrlName, x) : CheckBoxControl
String ctrlName
Variable x
Another_function ()
Many thanks!
STRUCT WMCheckboxAction &cba
switch( cba.eventCode )
case 2: // mouse up
Variable checked = cba.checked
strswitch(cba.ctrlName)
case "checkbox01":
// do checkbox01 actions
break
case "checkbox02":
// do checkbox02 actions
break
endswitch
break
break
endswitch
May 26, 2011 at 09:39 am - Permalink
May 31, 2011 at 09:44 am - Permalink
It makes a panel and condenses the creation of as many checkboxes as you like in a loop. Checkboxes and their control variables share common base names with a numeric extension.
In this example a single, very simple example procedure is called when the boxes are "clicked".
String sCB_Name
String sCB_BaseName = "CB_check"
String sCB_VariableName
String sCB_VariableBaseName = "vCBval"
String sDataFolder = "root:CheckBoxPanel"
String sProcName
String sProcBaseName = "cbProc"
Variable vCB_Position = 0
Variable vIndex = 0
NewDataFolder/O $sDataFolder //for checkbox variables
PauseUpdate; Silent 1 // building window...
NewPanel /W=(403,135,777,485)
Do
sCB_Name = sCB_BaseName + num2str(vIndex)
sCB_VariableName = sDataFolder + ":" + sCB_VariableBaseName + num2str(vIndex)
sProcName = sProcBaseName //+ num2str(vIndex) //use this if there's a proc for each checkbox
vCB_Position += 20 //y position of checkbox
Variable/G $(sCB_VariableName) = 1 //create global variable for each checkbox, initial value is checked
CheckBox $sCB_Name,pos={1,vCB_Position},size={40,14},variable= $sCB_VariableName
CheckBox $sCB_Name,title=sCB_Name, proc=$sProcName
vIndex += 1
While(vIndex<5)
Function cbProc(cba) : CheckBoxControl
String sCtrlName = cba.ctrlName
case 2: // mouse up
print cba.ctrlName
print cba.checked
break
break
endswitch
May 31, 2011 at 01:57 pm - Permalink
variable x
Function check02(x)
variable x
Function CheckProc(cba) : CheckBoxControl
variable x = 2
case 2: // mouse up
FUNCREF myprotofunc f = $cba.ctrlName
f(x)
break
break
endswitch
(EDIT)
Oh. My apologies. Now I understand. You want to have a code create a panel for you. For that, use the code by jtigor, however the procedure name can just be CheckProc with the above code to automatically call depending on check box name.
May 31, 2011 at 03:18 pm - Permalink
You *do* have to have a different action procedure for different types of controls because they each carry different kinds of information.
June 1, 2011 at 09:30 am - Permalink
June 10, 2011 at 10:19 am - Permalink
