Moving Panels without Changing Their Size
MoveWindow uses points. Panels are dimensioned in pixels. GetWindow returns pixels or points. Points and pixels are related by the screen resolution.
To offset a window by loffset and toffset, for any other (non-panel) window, I would do
GetWindow winname wsize MoveWindow winname V_left+loffset, V_top+toffset, V_right+loffset, V_bottom+toffset
For a panel, I could do the same, however I am concerned that translations between points <-> pixels might cause the panel to shrink/expand, even if only to an imperceptible degree.
Comments would be appreciated.
Because GetWindow and MoveWindow work with fractional points, you're okay.
Here's a demo that should reassure you: a "drunkard's walk" demo of a moving panel.
Run the macro and observe the initial and final window sizes. Resize the panel manually (chances are it'll be a fractional point size) and run the demo again.
July 2, 2008 at 11:27 am - Permalink
Good to know. I'll modify my ScreenSizer package accordingly to work with fractional points rather than rounded values.
July 2, 2008 at 12:52 pm - Permalink
