Moving Panels without Changing Their Size
What is the best way programmatically to reposition a panel without changing absolutely anything about its width and height?
MoveWindow uses points. Panels are dimensioned in pixels. GetWindow returns pixels or points. Points and pixels are related by the screen resolution.
To offset a window by loffset and toffset, for any other (non-panel) window, I would do
GetWindow winname wsize
MoveWindow winname V_left+loffset, V_top+toffset, V_right+loffset, V_bottom+toffset
For a panel, I could do the same, however I am concerned that translations between points <-> pixels might cause the panel to shrink/expand, even if only to an imperceptible degree.
Comments would be appreciated.
This is of concern only on Windows where the screen resolution isn't presumed to be 1 pixel = 1 point.
Because GetWindow and MoveWindow work with fractional points, you're okay.
Here's a demo that should reassure you: a "drunkard's walk" demo of a moving panel.
Macro MovePanelAbout()
    Variable iterations= 1000
    DoWindow Panel0
    if( V_Flag == 0 )
        NewPanel/N=Panel0/K=1
    fMovePanelAbout(iterations)
Function fMovePanelAbout(iterations)
    Variable iterations
    Variable loffset,toffset, i
    for(i=1;i<=iterations;i+=1)
        loffset= enoise(3)
        toffset= enoise(3)
        GetWindow Panel0 wsize
        if( i == 1 || i == iterations )
            Print i, "width= ", V_right-V_left, ", height=", V_bottom-V_Top
        MoveWindow/W=Panel0 V_left+loffset, V_top+toffset, V_right+loffset, V_bottom+toffset
Run the macro and observe the initial and final window sizes. Resize the panel manually (chances are it'll be a fractional point size) and run the demo again.
JimProuty wrote:
This is of concern only on Windows ... [however because] GetWindow and MoveWindow work with fractional points, you're okay.
Good to know. I'll modify my ScreenSizer package accordingly to work with fractional points rather than rounded values.
