Parsing ErrorBar wave information
I tried hard to parse out the name of the error-bar wave and displayed range, but so far I haven't found a general solution. I am banging my head against this wall for quite a while now. Anybody has an idea how to parse a string which might look like this (Which is part of TraceInfo()):
"ErrorBars 'Peak[30],results'#1 XY,pct=0.01,wave=('Peak[30],error'[12,20;2][%loc_err],'Peak[30],error 2'[13,17][15])"
The range might be complicated or easy or not present at all. What I want to get out is:
Peak[30],error 12,20;2 // may not be present %loc_err // may not be present
This problem may get considerably easier if there was a way to obtain the name of the error wave from somewhere else.
OK, I might have found a solution (that is some serious rubber duck debugging today). It is ugly but it seems to work (don't ask me about the regex details too much). If anybody has a simpler solution I am all ears:
October 16, 2024 at 02:15 am - Permalink
Lots of REGEX. Pulling off the ERRORBARS string from TraceInfo using StringByKey might eliminate the first REGEX. You have one of these (with options for additional [] for the q indices)
wave=('liberal name X'#N[...],'liberal name Y'#N[...])
wave=('liberal name X'[...],'liberal name Y'[...])
wave=(nameX#N[...],nameY#N[...])
wave=(nameX[...],nameY[...])
Rather than separating between liberal and standard names, zap the ' characters and replace spaces by double __ using ReplaceString. This removes the need for two different REGEX expressions. You now get this ...
wave=(liberal__name__X#N[...][...],liberal__name__Y#N[...][...])
The REGEX to capture the ranges (if they exist) should now become an easier expression. It may even be possible to avoid REGEX using ListMatch(list,"[*]").
Capture the wave names (standardized) and convert back to liberal as needed by replacing double __ with space.
Caveat: Fear for those who use double __ in their file names at the outset.
October 16, 2024 at 09:06 am - Permalink
JJ, thanks for your input! I will look into your idea of replacing the ' with another special symbol, but I am not seeing how this helps me handle exotic liberal names better. Here are a few issues which complicate these things further:
I think there is surely a more elegant regex, which would shorten this considerably. My regex-fu is very weak, and I couldn't even figure out how to parse something like "[STUFF]" repeated 1-4 times with a repeating pattern into different groups, hence the unwieldy optional matching thing going on there.
October 16, 2024 at 09:54 am - Permalink
I was able to reduce this to two paths for the regex at least, one for liberal names and one for strict names (EDIT: I also could get rid of one of the SplitString lines):
October 16, 2024 at 10:51 am - Permalink
A Herculean effort for sure!
October 16, 2024 at 01:14 pm - Permalink
It has been certainly a good learning experience, for sure.
With this I hope to finally offer the full feature set (and more) of the official Quick Fit in my Super Quick Fit package.
October 16, 2024 at 10:23 pm - Permalink
