Integration for x minutes in a timeseries
Hi everyone,
I have two dataset that I will like to compare but they were taken under different conditions.
Dataset A is a timeseries of concentration (y-wave) against time (x-wave), where a data point was taken every 30 seconds.
Dataset B is also a concentration against time but the data was summed up over 5 minutes and taken every 4 hours for one-half of the time and 3 hours for the second half.
The best strategy I can come up with for comparing is to integrate dataset A for 5 minutes through the timeseries
I want to note that I am not looking to do a rolling average, so I want the integrated sum for each of the 5-minute block. For example, 16:00 to 16:05 should output a y-value, and 16:06 to 16:10 should be integrated to output another y-value that is independent of the previous value. For each y-value, x = the integration start time.
Is there an in-built procedure/macro in Igor that can help me do this? I am familiar with rolling averages but not integration. Happy to clarify any questions!
Thank you.
Look for command help on the area function and the Integrate operation.
September 23, 2024 at 01:29 pm - Permalink
Variable startTime, endTime, resultCountVariable i, jVariable area, startIdx, endIdxwave integrationResult// Calculate the number of integration intervalsresultCount = floor(totalDuration / xInterval)// Create a new wave to store integration results. N should be equal to the resultCountMake /N=(resultCount) integrationResults = 0// Perform integration for each interval. More like define start and end times for x waves with intervalsfor (i = 0; i < resultCount; i++)startTime = x1 + i * xIntervalendTime = startTime + 300 //300 in seconds, ie 5 minutes integration time// Ensure we stay within the bounds of the yWavestartIdx = round(startTime)endIdx = round(endTime)if (startIdx < 0 || endIdx >= numpnts(yWave))Print "Time interval out of bounds."edit integrationResultsendif// Perform trapezoidal integration of yWavearea = 0for (j = startIdx; j < endIdx - 1; j++)area += 0.5 * (yWave[j] + yWave[j + 1]) * (1) // Assuming x increments by 1 secondendforintegrationResults[i] = areaendforedit integrationResultsOctober 11, 2024 at 12:30 pm - Permalink
