Speeding up StringFromList on a lengthy string
Hello all,
We are trying to convert samples provided by oscilloscope as a string of concatenated ASCII values separated by a comma. The number of samples are over 60K.
To convert the values in this string to a wave of floating values we are using `StringFromList`, as described in the manual.
// This function processes a string (read buffer in this case) and // returns a wave of floating numbers Function Wave_from_StringFromList ( sample_str ) String sample_str // A semicolon-separated string list String separator = "," Variable separatorLen = strlen(separator) Variable numItems = ItemsInList( sample_str , ",") Variable offset = 0 Variable i print "\t number of items in the list : ", numItems Variable timerRefNum variable microSeconds timerRefNum = StartMSTimer make /FREE /d /n=(numItems) temp string item for(i=0; i<numItems; i+=1) // When using offset, the index parameter is always 0 item = StringFromList(0, sample_str , separator, offset) temp [i] = str2num(item) offset += strlen(item) + separatorLen endfor microSeconds = StopMSTimer(timerRefNum) Print /d microSeconds /1e6 , " seconds " duplicate /o temp out End ////////////////////////////////////////////////////////////////////////
This operation takes very long time compared to the actual measurement and data transfer which typically takes <0.1 s. Hence, the iterative conversion process takes considerably long time.
How can we improve the speed of this conversion.
// output when running the above function Wave_from_StringFromList ( root:RTO_str ) number of items in the list : 61954 22.6564711 seconds
See the attached pxp file for the sample_string saved as a global_variable for testing purpose.
How are you capturing the string? Can you capture it into a string wave rather than a string list? Can you force the conversion to a number at the input reading?
In the meantime, I tested an implicit versus explicit for loop.
Perhaps the str2num conversion is the slow step.
May 30, 2023 at 10:05 am - Permalink
No, definitely StringFromList() is the bottleneck here. I guess because this function searches through the whole thing each step. Do this instead:
May 30, 2023 at 10:41 am - Permalink
In Igor Pro 7 or later, StringFromList has an optional offset parameter that can dramatically speed up iterating through lists of many strings. See the DemoQuickStringFromList function in the help for StringFromList.
ListToTextWave is also a good solution.
May 30, 2023 at 05:47 pm - Permalink
As described by Chozo, StringFromList() is the slow step in this issue. String to number conversion is not the bottleneck.
Converting to text wave `ListToTextWave` is extremely fast, and practically solves the issue.
Thank you all, in particular chozo, for the great inputs.
May 30, 2023 at 10:33 pm - Permalink
