adjustable number of differential equations
I am trying to model non-radiative energy transfer between a single donor molecule towards a variable number of acceptor molecule that are on periphery of a circle. instead of having a fixed number of acceptor, I am trying to use the IntegrateODE command with a number that can be set by the user.
Function FRET_sphere(pw, tt, yw, dydt) Wave pw // pw[0] = k1, pw[1] = k2, pw[2] = k3 Variable tt // time value at which to calculate derivatives Wave yw // yw[0]-yw[3] containing concentrations of A,B,C,D Wave dydt // wave to receive dA/dt, dB/dt etc. (output) Variable /g na dydt[0] = -pw[0]*exp(-((tt)/0.03)^2)*yw[0]+pw[1]*yw[1] // pw[0]=donor excitation rate, pw[1]=1/(lifetime donor) dydt[1] = pw[0]*exp(-((tt)/0.03)^2)*yw[0]-pw[1]*yw[1] - pw[na+2]*yw[1] //transfer toward na acceptors on a circle line with a total rate = pw[3]+...+pw[na+2] variable i for (i=0;i<(na);i=i+1) dydt[2+i] = pw[3+i]*yw[1]-pw[2]*yw[2+i] endfor End function EFRET_sphere(Rf,Racc,na) variable Rf,Racc,na variable i,j,r,aa,k make /o/n=(na+4) pw pw[0]=6500 pw[1]=0.25 pw[2]=0.33 make /o/d/n=20 FRET SetScale/P x 1,1,"", FRET FRET=0 Make/O/D/N=(200,na+2) ChemKin SetScale/I x 0,50,"", ChemKin Chemkin=0 ChemKin[0][0]= 1 for (k=1;k<2;k=k+1) for (j=0;j<(na);j=j+1) r=sqrt((Racc+k)^2+(Racc)^2-2*(Racc+k)*Racc*cos((pi/2)*(1-j/3))) aa=aa+pw[1]*(Rf/r)^6 pw[3+j]=pw[1]*(Rf/r)^6 endfor pw[na+3]=aa IntegrateODE FRET_sphere, pw, ChemKin variable num=0 wave out for (i=0;i<na;i=i+1) out[]=ChemKin[i+3][p] num=num+pw[2]*(sum(out)) endfor out[]=ChemKin[1][p] variable den=num+pw[1]*sum(out) FRET[k]=num/den endfor end function
here is my code I suppose that IntegrateODE cannot handle a loop in the function defining the set of equations.
the second function EFRET_sphere is the part where I change the relative distance between the donor and the acceptors.
Does anyone tried to use it in that way?
Best regards,
Pascal
The loop is fine. IntegrateODE counts the number of equations based on the number of columns in your matrix Y wave, or the number of Y waves. Once it has counted, it expects a derivative for each column. A derivative of zero should be OK, if that will do what you need.
December 6, 2022 at 11:57 am - Permalink
I just optimized the code but it is now indeed working very well !
Thank for your quick answer.
December 7, 2022 at 03:09 am - Permalink
Great!
December 7, 2022 at 09:35 am - Permalink
