adjustable number of differential equations
pascal.didier
I am trying to model non-radiative energy transfer between a single donor molecule towards a variable number of acceptor molecule that are on periphery of a circle. instead of having a fixed number of acceptor, I am trying to use the IntegrateODE command with a number that can be set by the user.
Function FRET_sphere(pw, tt, yw, dydt)
Wave pw // pw[0] = k1, pw[1] = k2, pw[2] = k3
Variable tt // time value at which to calculate derivatives
Wave yw // yw[0]-yw[3] containing concentrations of A,B,C,D
Wave dydt // wave to receive dA/dt, dB/dt etc. (output)
Variable /g na
dydt[0] = -pw[0]*exp(-((tt)/0.03)^2)*yw[0]+pw[1]*yw[1] // pw[0]=donor excitation rate, pw[1]=1/(lifetime donor)
dydt[1] = pw[0]*exp(-((tt)/0.03)^2)*yw[0]-pw[1]*yw[1] - pw[na+2]*yw[1] //transfer toward na acceptors on a circle line with a total rate = pw[3]+...+pw[na+2]
variable i
for (i=0;i<(na);i=i+1)
dydt[2+i] = pw[3+i]*yw[1]-pw[2]*yw[2+i]
function EFRET_sphere(Rf,Racc,na)
variable Rf,Racc,na
variable i,j,r,aa,k
make /o/n=(na+4) pw
pw[0]=6500
pw[1]=0.25
pw[2]=0.33
make /o/d/n=20 FRET
SetScale/P x 1,1,"", FRET
FRET=0
Make/O/D/N=(200,na+2) ChemKin
SetScale/I x 0,50,"", ChemKin
Chemkin=0
ChemKin[0][0]= 1
for (k=1;k<2;k=k+1)
for (j=0;j<(na);j=j+1)
r=sqrt((Racc+k)^2+(Racc)^2-2*(Racc+k)*Racc*cos((pi/2)*(1-j/3)))
aa=aa+pw[1]*(Rf/r)^6
pw[3+j]=pw[1]*(Rf/r)^6
pw[na+3]=aa
IntegrateODE FRET_sphere, pw, ChemKin
variable num=0
wave out
for (i=0;i<na;i=i+1)
out[]=ChemKin[i+3][p]
num=num+pw[2]*(sum(out))
out[]=ChemKin[1][p]
variable den=num+pw[1]*sum(out)
FRET[k]=num/den
end function
Variable /g na
variable i
variable Rf,Racc,na
variable i,j,r,aa,k
make /o/n=(na+4) pw
pw[0]=6500
pw[1]=0.25
pw[2]=0.33
make /o/d/n=20 FRET
FRET=0
Chemkin=0
ChemKin[0][0]= 1
for (k=1;k<2;k=k+1)
pw[na+3]=aa
variable num=0
wave out
out[]=ChemKin[1][p]
FRET[k]=num/den
end function
here is my code I suppose that IntegrateODE cannot handle a loop in the function defining the set of equations.
the second function EFRET_sphere is the part where I change the relative distance between the donor and the acceptors.
Does anyone tried to use it in that way?
Best regards,
Pascal
The loop is fine. IntegrateODE counts the number of equations based on the number of columns in your matrix Y wave, or the number of Y waves. Once it has counted, it expects a derivative for each column. A derivative of zero should be OK, if that will do what you need.
December 6, 2022 at 11:57 am - Permalink
I just optimized the code but it is now indeed working very well !
Thank for your quick answer.
December 7, 2022 at 03:09 am - Permalink
Great!
December 7, 2022 at 09:35 am - Permalink
