Time based data spliting
Hi, all.
I have two 1D waves named "timewave" and "SP2wave", timewave is in Date/time format and SP2 is numeric, and they have the same numbers of rows. And the time range in wave "timewave" is 1 month. Now I would like to split the SP2wave into some small waves(30 minutes per wave) to better manage them. I met problems when I write the loop. I am using "Extract" to split the timeline and get the numbers of rows every 30 minutes and use "Duplicate" to split the SP2wave. But it doesn't work.
Function splitandsave(wave timewave) wave timeTemp,SP2wave String DestwaveName variable index,maxindex,n maxindex = numpnts(timewave) for(index=1;index<maxindex;index += numpnts(timeTemp)) Extract/O timewave,timeTemp,timewave>=timewave[index] && timewave< (timewave[index] + 60*30) Duplicate/FREE/R = [index, index + numpnts(timeTemp)] SP2wave, DestWave //Save/J DestWave as DestwaveName //DestWavename = "BT_"+secs2date(timewave[index],-2)+" "+replacestring(":","sec2Time(timewave[index],3)","") endfor end
I'm new to Igor and new to programming. Any help would be greatly appreciated.
May 24, 2022 at 06:59 am - Permalink
In reply to function splitandsave(wave… by tony
Thank you very much, Tony! And I have a new problem now. I need to save these waves in .txt format and in different folders. Each folder has 1 file. I generated some codes before you reply to me and save the waves. But I still don't know how to put in in different folders.
The followings are my code. If you find somewhere incorrect, please let me know.
Regards,
mortoo
May 24, 2022 at 10:49 am - Permalink
You need to create new folder for each data set, something like:
Newpath /O SP2_PATH, $("C:\Zixuanphd\Osca2022\BT tower winter flux\Raw data\DataSet"+num2str(index))
This will create new folder on your disk for each data set called DataSetX, where X is value of index converted to string. This will then save each txt file in its own folder on drive.
May 25, 2022 at 12:04 am - Permalink
In reply to You need to create new… by ilavsky
I think you need NewPath with the /C flag to create a folder:
NewPath/Q/C SP2_PATH, $("C:\Zixuanphd\Osca2022\BT tower winter flux\Raw data\DataSet"+num2str(index))
May 25, 2022 at 12:17 am - Permalink
