Loading TIA files (.emi and .ser)
Hello, we are working on analyses of microscopic images acquired with an FEI Tecnai transmission electron microscope system. The TIA software (TEM Imaging & Analysis) is used in our system, and data are recorded in files such as “xxx.emi” and “xxx.ser”.
We are very happy if we can read these TIA-dedicated files (image data and/or metadata) directly into Igor Pro experiments. We are looking for someone who has experiences on this topic.
Thank you.
I have done something similar with a different vendor in the past.  Could you share a sample of each file?
I used to work with Tecnai image series, mostly from STEM mode, and I found it worked decently to use ImageJ as an intermediary to convert the images into more common formats. There is an ImageJ plugin https://imagej.nih.gov/ij/plugins/tia-reader.html that you can use to make a batch conversion macro. I think if you convert to TIF format, it even keeps some of the metadata like the image scaling.
