Displaying FuncFit in a loop
All I want is to get a batch of graphs where a single subrange of data and a fit for it whould be on a one separate graph. Can you please help me? Here is my code:
Function myFit(w,x) Wave w Variable x Variable bm= w[0] Variable kd= w[1] return w[0]*x/ (w[1]+x) End Function Ex (m) Variable m Variable n, a,i,s a=0 n=0 Make/O/N = (61)kd_global do Display DNAbound_Protein[n,n+11] vs DNAfree[n,n+11] ModifyGraph mode=3, marker=19 SetAxis left 0,1.2 SetAxis bottom 0, 35000 label bottom "(DNAfree)" label left "(DNAbound/Protein)" Make/D/O/N=2 W_coef W_coef= {1.2,1} FuncFit/H="10"/NTHR=0/Q/TBOX=64 myFit W_coef DNAbound_Protein[n,n+11] /X=DNAfree[n,n+11]/D kd_global[a]= (W_coef[1]+477.1)/37.379 n+=12 a+=1 while (n < m) Display kd_global AppendToTable /W=Table0 kd_global End
Just write after the funcfit command:
duplicate/o fit_DNAbound_Protein, $("fit"+num2istr(a)+"_"+"DNAbound_Protein")And if you want to display the fits together with your data add the following:
Andreas
June 2, 2010 at 05:14 am - Permalink
This is indicated by the parameter /D at the end of FuncFit (look into the help of 'CurveFit') which just writes the result in a wave named 'fit_' + inputname. Since the Wave you are fitting has the same name (only the subrange is different) the result has the same name, too. I think to solve your problem you can just try to define a new output name with /D='newname' (e.g.
"FitResult"+num2str(n)) every iteration, so you don't even have to duplicate waves.June 2, 2010 at 05:25 am - Permalink
It has the possible advantage that you can do each of your fits using the same destination wave. You could write:
June 2, 2010 at 11:20 am - Permalink
June 3, 2010 at 02:42 am - Permalink
Everything seem to be correct and makes sense. But still does not work properly. Mainly the plotting part.
when I'm trying to add lines
as chozo suggested, it displays the right fit but with the another fit (fit_DNAbound_Protein). and then I've tried to modify it on:
it displays the fit_num2str(a) properly but puts all the the data points (DNAbound_Protein[n,n+11]) at x=0 and not as it should be at x=DNAfree[n,n+11].
Can I modify it somehow to work properly?
Thank you,
Alina.
June 3, 2010 at 05:44 am - Permalink
The problem is probably related to the SetAxis commands. Unfortunaltey I don't know how your data look like, so I can't test it, but please give the following a try:
As I do not know what the reason is for the original SetAxis commands, I commentized them. You can reactivate them if you know what you're doing.
I hope this helps,
Andreas
June 10, 2010 at 12:09 am - Permalink
Your corrected code works just perfect!
Even uncommented SetAxis does not change the correctness of the plots.
Thank you.
Alina
June 9, 2010 at 02:26 am - Permalink
