subtract element (n-1) from element n
I have a date/time wave and I want to create a new wave that has the difference between adjacent time points.  Is there a clever way to do this without an explicit loop?  Related to this, as always when I've been away from Igor for awhile, I've forgotten how to call a set of waves that have names that change each time through the loop.  See below.
do
	n=0
	string temp_string="degF_t"+num2str(i)
	string time_string="igor_time_t"+num2str(i)
	string time_string_temp="igor_time_t"+num2str(i)+"temp"
	Extract/O degF,$temp_string,thermistor==i
	Extract/O igor_time,$time_string,thermistor==i
	SetScale d 0, 0, "dat", $time_string
	duplicate $time_string $time_string_temp
	for(n=1;n<dimsize($time_string_temp,0);n+=1)	// Initialize variables;continue test
		$time_string_temp[0]==0
		$time_string_temp[n]=$time_string[n]-$time_string[n-1]			// Condition;update loop variables
	endfor						// Execute body code until continue test is FALSE
		$time_string_temp[n]= //??? want to set something so that on the final loop we do not have an index out of range error...
	i+=1
while(i-1<thermistor_max)
This is one approach to create a difference wave using implicit indexing:
duplicate source newwave
newwave[1,numpnts(newwave) - 1] -= source[p-1]
newwave[0] = 0 // set first point to whatever is desired (or just remove it)
The first point in the new wave has no meaning here.
I also suggest that a better approach to avoid using "$" throughout is to use wave declarations immediately after the waves are created:
wave tswave = $time_string
wave ttswave = $time_string_temp
Finally, you might consider replacing the main do-while loop with a for-endfor loop:
for (jc=0;jc<thermistor_max;jc+=1)
Just a small thing- on the left side of a wave assignment, you can simply leave out the last point number. That's a shortcut for "up to and including the last point":
newwave[1,] -= source[p-1]    // through the last point in newwave
