base64 - base64 and URL encoding and decoding + md5hashing
This XOP does several useful encoding of strings.
1) It does base64 encoding and decoding of strings (useful for network utilities).
2) It does URL encoding of strings (useful for network utilities).
3) It does an md5 hash of a string.
Usage:
//base64
string testing = "test"
testing = base64encode(testing)
testing = base64decode(testing)
//URLencoding
string testing = "test test"
print URLencode(testing)
//md5 hashing
string testing = "The quick brown fox jumps over the lazy dog"
print md5hash(testing)
//should print 9e107d9d372bb6826bd81d3542a419d6
Usage:
//base64
//URLencoding
//md5 hashing
| Project CVS: | http://svn.igorexchange.com/viewvc/packages/base64/ |
base64 IGOR.5.00.x-1.0.x-dev
| Release File: | base64-IGOR.5.00.x-1.0.x-dev.zip (556.93 KB) |
| Version: | IGOR.5.00.x-1.0.x-dev |
| Version Date: | |
| Version Major: | 1 |
| Version Extra: | dev |
| Release Notes: | Encodes and Decodes strings into base64 |
Thank you very much for making this XOP that I've been using for several years now. Unfortunately I appears that base64 is not compatible with Igor7.
Is there any plan to upgrade this XOP.
Best regards,
Alex
December 18, 2018 at 02:15 am - Permalink
Alex:
I can't say whether Andy plans to update the XOP, but I believe the XOP is mostly or completely obsolete as Igor 7 and Igor 8 have built-in functions to do these things.
URLEncode/URLDecode are used for URL encoding/decoding.
The Hash function can be used for multiple kinds of hashes of string data, including MD5. Igor 8 adds the WaveHash function, which can be used to hash a wave.
Base64 encoding/decoding is provided by the "secret" Base64_Encode and Base64_Decode functions in Igor 7. For Igor 8, these were made official and their names were changed to Base64Decode and Base64Encode to match the names used by this XOP. In this case, "secret" means that you can use the function in your code but it isn't documented in the Help Browser. If you need to see the documentation, you can find it in http://wavemetrics.net/doc/igorman/IgorMan.pdf. This is the Igor 8 documentation, but the functions work the same way in Igor 7, just with different names. Search for "Base64Encode" or "Base64Decode".
If you want to write code so that it can be used with Igor 8 also, do something like this:
These wrapper functions will allow you to use the proper Igor 8 names for the functions in your code if you're using Igor 7.
December 18, 2018 at 04:56 am - Permalink
In reply to Alex: I can't say whether… by aclight
Thank you very much for your reply. I didn't know that the base64Decode functions were now available in Igor 7. I'll use the wrapper functions.
Reagrds,
Alex
December 21, 2018 at 12:25 am - Permalink
