Loading .csv
I am trying to load a .csv file. This is a straight forward file with only numbers and it appears to be tab delimited. The load is working well until the 16 column of the data matrix. At this point the load just copies the data in column 16 to the end of the matrix load (n= 175).
I have copied an example file as well as the code that I am using.
I have been playing around with the load wave function but I can not seem to get it to work.
Any suggestions are very welcome.
Thank you.
Function Loadsmps() // Loads smps data // Prompts to select folder into which data is loaded String PathToFldr="",CtrlName="",PromptStr="Select folder to load smps data into:",CurrentFldr=getdatafolder(1) // variables for Browse4Folder Browse4Folder(PathToFldr,CtrlName,PromptStr,CurrentFldr) // prompts user to select an experiment // Get folder with data in it NewPath/M="Select folder containing smps data:"/O/Q pathname // prompts user to select path to data folder PathInfo pathname // Abort if cancel is pressed If(V_flag==0) Abort "proceedure cancelled" EndIf // Make matrix for smps data Make/o/n=(0,175) smpsDataMatrix // Strings and Variables Variable numfolders,n, subdirs, numfiles, filenum, refnum // variables String folderlist, filename, name, currentfolder // strings // Counts number of files in folder NumFiles=ItemsInList(IndexedFile(pathname,-1,".csv")) // # files in folder , specify extensions e.g. ".txt" For(filenum=0;filenum<numfiles;filenum+=1) // loops through each file name filename=s_path+StringFromList(filenum,IndexedFile(pathname,-1,".csv")) // get full path to data file , specify extensions e.g. ".txt" If(Stringmatch(FileName,"*pdd*")==1) Open /R/P=pathname/Z refNum as filename // open FStatus refNum // check there is data in file If(V_logEOF>10) // specify minimum file size to load e.g. >10bytes Load_smps_File(filename, refnum) // calls function to load file // unique function for specific file format Wave Temp_smpsDataMatrix0 // add loaded waves to loaded data InsertPoints DimSize(smpsDataMatrix,0),DimSize(Temp_smpsDataMatrix0,0), smpsDataMatrix smpsDataMatrix[DimSize(smpsDataMatrix,0)-DimSize(Temp_smpsDataMatrix0,0),*][]=Temp_smpsDataMatrix0[p-DimSize(smpsDataMatrix,0)+DimSize(Temp_smpsDataMatrix0,0)][q] currentfolder=GetDataFolder(1) // root folder for experiment Endif // end data to folder allocation EndIf EndFor // end loop through files of a dp Close/A // close open files Killwaves Temp_smpsDataMatrix0 // Do additional analytsis on smps data Processsmps() // adds a time wave End Function Load_smps_File(filename, refnum) // load single smps file String filename Variable refnum print "Loading: " + filename loadwave/v={"\t ","",0,1}/q/a/n=Temp_smpsDataMatrix/m/o/j/k=1/l={0,4,0,0,0} filename // loads smps data as a matrix End Function Browse4Folder(PathToFldr,CtrlName,PromptStr,CurrentFldr) // based on mg code from htdma toolkit String PathToFldr // path to data folder String PromptStr // Prompt text in data browser String CurrentFldr // current data folder String CtrlName variable exit=0 // stops trying when exit reaches 6 do string/g BrowserList string /g TempFldr=CurrentFldr variable/g Flag execute "CreateBrowser prompt=\""+PromptStr+"\", select=tempfldr" // prompt for file killstrings/z tempfldr svar BrowserList=s_browserlist nvar Flag=V_Flag // print browser_list if (!Flag) PathToFldr="cancelled" break endif if (itemsinlist(BrowserList)==1) if (stringmatch("root:ROOT;", BrowserList)) //data browser returns strange path if root is selected BrowserList="root" endif PathToFldr=stringfromlist(0,BrowserList)+":" if(DataFolderExists(PathToFldr)) break else doalert 0, "you must select a data folder, not a wave, string or variable! => try again" endif else doalert 0, "none or multiple data folders were selected => try again" endif exit+=1 while (exit<6) //maximum six attempts End
I don't see any attachment.
October 18, 2018 at 08:31 pm - Permalink
Apologies...here is the file
October 18, 2018 at 09:52 pm - Permalink
Hello LaMP,
I was able to read your example file with the following LoadWave command (Igor 8.02, 64bit, Windows 10):
It appears that some of the columns are tab delimited while others are space delimited.
Hope this helps,
Klaus
October 19, 2018 at 01:01 am - Permalink
The file's data starts on line 5 (zero-based).
The file is tab-delimited, but columns 8 and 11 (zero-based) have a space between the preceding tab and the number.
To make it easier to see if I was getting the right results, I created a version of the file where the first data line contains zero-based column numbers from 0 to 175 for a total of 176 columns. I will attach my version of the file which I called Test.csv.
This command:
LoadWave/J/D/E=1/K=0/V={"\t, "," $",0,0}/L={0,6,0,0,0}has two errors. The 6 should be 5 because the data starts on line 5 (zero-based).
Also, including space as a delimiter (/V flag) is incorrect because it causes LoadWave to create two extra columns.
I get the right result with this command:
LoadWave/J/D/E=1/K=0/L={0,5,0,0,0}/A/P=Data "Test.csv"The preceding command uses a symbolic path named Data which you must create. To learn about symbolic paths, execute:
Since the file contains just numbers (no strings, dates, or times), you can use the simpler LoadWave/G instead of LoadWave/J. I get the correct results with this command:
LoadWave/G/D/E=1/A/P=Data "Test.csv"I recommend using LoadWave/G. To learn about it, execute:
DisplayHelpTopic "Loading General Text Files"October 19, 2018 at 08:32 am - Permalink
