HDF5 Browser
this is what I have stumbled upon when I was exploring into my automation problems regarding the HDF5 files
// The routines in this file implement the HDF5 Browser control panel.
// Version 1.00, May 9, 2005: Initial release.
// Version 1.01, May 10, 2005: Revamped preferences code.
// Version 1.02, May 14, 2005: Revamped preferences code again using
//  the LoadPackagePrefs and SavePackagePrefs operations. This requires
// Igor Pro 5.04B07 or later.
// Version 1.03, January 15, 2010: Now uses HDF5ListGroup/R=2 to deal with
// files that use hard or soft links to include the same group more than one time.
// This version of this procedure file requires HDF5XOP 1.09 or later.
// Version 1.04, May 21, 2015: Defines HDF5 library constants such as
// H5T_ORDER_LE and H5T_ORDER_BE. This version of this procedure file requires
// HDF5XOP 1.14 or earlier.
#pragma version = 1.04
#include <WaveSelectorWidget>
#pragma moduleName=HDF5Browser
Menu "Load Waves"
    "New HDF5 Browser", /Q, CreateNewHDF5Browser()
Constant H5S_MAX_RANK = 32
// Constants for HDF5DataInfo datatype_order field and HDF5DatatypeInfo order field
Constant H5T_ORDER_ERROR = -1       // Error
Constant H5T_ORDER_LE = 0           // Little endian
Constant H5T_ORDER_BE = 1           // Big endian
Constant H5T_ORDER_VAX = 2          // VAX mixed endian
// The following is valid only with HDF5 library 1.8.5 or before because this value was changed in 1.8.6.
#if (Exists("HDF5LibraryInfo") == 3)
    // This is just to create a compile error if you are running with a newer HDF5 XOP
    // and therefore should be using a new "HDF5 Browser.ipf" file.
    #define *** You are using a newer HDF5 XOP which uses a newer HDF5 library. You need a newer "HDF5 Browser.ipf" file - version 1.20 or later. ***
#endif
Constant H5T_ORDER_NONE = 3     // No particular order (strings, bits,..)
// Constants for HDF5DataInfo datatype_sign field and HDF5DatatypeInfo sign field
Constant H5T_SGN_ERROR = -1         // Error
Constant H5T_SGN_NONE = 0           // Unsigned
Constant H5T_SGN_2 = 1              // Two's complement
// Constants for HDF5DataInfo datatype_class field and HDF5DatatypeInfo type_class field
Constant H5T_NO_CLASS = -1          // Error
Constant H5T_INTEGER = 0            // Integer types
Constant H5T_FLOAT = 1          // Floating-point types
Constant H5T_TIME = 2               // Date and time types
Constant H5T_STRING = 3         // Character string types
Constant H5T_BITFIELD = 4           // Bit field types
Constant H5T_OPAQUE = 5         // Opaque types
Constant H5T_COMPOUND = 6           // Compound types
Constant H5T_REFERENCE = 7          // Reference types
Constant H5T_ENUM = 8           // Enumeration types
Constant H5T_VLEN = 9               // Variable-Length types
Constant H5T_ARRAY = 10         // Array types
// Constants for HDF5DataInfo dataspace_type field
Constant H5S_NO_CLASS = -1          // Error
Constant H5S_SCALAR = 0         // Scalar variable
Constant H5S_SIMPLE = 1         // Constant simple data space
Constant H5S_NULL = 2               // Constant null data space
// Constants for HDF5DatatypeInfo strpad field
Constant H5T_STR_ERROR = -1         // Error
Constant H5T_STR_NULLTERM = 0       // Null terminate like in C
Constant H5T_STR_NULLPAD = 1        // Ppad with nulls
Constant H5T_STR_SPACEPAD = 2       // Pad with spaces like in Fortran
// Constants for HDF5DatatypeInfo cset field
Constant H5T_CSET_ERROR = -1            // Error
Constant H5T_CSET_ASCII = 0         // US ASCII
Constant H5T_CSET_UTF8  = 1         // UTF-8 Unicode encoding
Structure HDF5BrowserData
    SVAR browserName
    Wave/T groupsList
    Wave/T groupAttributesList
    Wave/T datasetsList
    Wave/T datasetAttributesList
    Wave/T groupFullPaths
    SVAR groupPath
    SVAR hyperSelectionWavePath
    NVAR fileID
    SVAR fileName
    SVAR path
    SVAR fullPath
    NVAR readOnly
    SVAR datasetInfo            // Panel readout info for currently-selected dataset
EndStructure
static Function CreateHDF5BrowserGlobals(newBrowserName)
    String newBrowserName
    // Create globals that apply to this browser window.
    String savedDataFolder = SetBrowserDataFolder(newBrowserName)
    String/G browserName = newBrowserName
    Make/O/T/N=0 groupsList
    Make/O/T/N=0 groupAttributesList
    Make/O/T/N=0 datasetsList
    Make/O/T/N=0 datasetAttributesList
    Make/O/T/N=0 groupFullPaths                                 // For each group, contains the corresponding full path to that group.
    String/G groupPath = "/"            // Path to currently selected group
    String/G hyperSelectionWavePath     // Path to hyperselection wave, if any.
    Variable/G fileID = 0                           // 0 means no file is open for this browser.
    String/G fileName = ""
    String/G path = ""
    String/G fullPath = ""
    Variable/G readOnly = 1
    String/G datasetInfo
    SetDataFolder savedDataFolder
Function/S SetBrowserDataFolder(browserName)        // Pass "" for browserName to set to master browser folder.
    String browserName
    String savedDataFolder = GetDataFolder(1)
    NewDataFolder/O/S root:Packages
    NewDataFolder/O/S HDF5Browser
    if (strlen(browserName) > 0)
        NewDataFolder/O/S $browserName
    return savedDataFolder
static Function SetHDF5BrowserData(browserName, bd)
    String browserName
    STRUCT HDF5BrowserData &bd
    String savedDataFolder = SetBrowserDataFolder(browserName)
    // These statements set the structure fields to reference the corresponding waves and variables in the data folder.
    SVAR bd.browserName
    Wave/T bd.groupsList
    Wave/T bd.groupAttributesList
    Wave/T bd.datasetsList
    Wave/T bd.datasetAttributesList
    Wave/T bd.groupFullPaths
    SVAR bd.groupPath
    SVAR bd.hyperSelectionWavePath
    NVAR bd.fileID
    SVAR bd.fileName
    SVAR bd.path
    SVAR bd.fullPath
    NVAR bd.readOnly
    SVAR bd.datasetInfo
static Function CountSlashes(item)
    String item
    Variable slashes = 0
    Variable pos = 0
    do
        pos = strsearch(item, "/", pos)
        if (pos < 0)
            break
        slashes += 1
        pos += 1
    while (1)
    return slashes
Function/S GetGroupHierarchy(fileID, startPath, level, mode)
    Variable fileID
    String startPath
    Variable level
    Variable mode       // 0 to just get group names; 1 to get full path to each group.
    String result = ""
    String indent = ""          // Used only for mode 0.
    Variable i, j
    // This gives full hierarchy with full paths
    // The /R=2 flag requires HDF5 1.09 or later. If you get an error here, you need to activate a more recent version of HDF5XOP.
    HDF5ListGroup /F /R=2 /TYPE=1 fileID, startPath // REQUIRES HDF5XOP 1.09 or later
    result = S_HDF5ListGroup
    if (mode == 0)              // Want just names, not full paths
        result = ""
        Variable numItems = ItemsInList(S_HDF5ListGroup)
        for(i=0; i<numItems; i+=1)
            String item = StringFromList(i, S_HDF5ListGroup)
            level = CountSlashes(item)
            indent = ""
            for(j=0; j<level; j+=1)
                indent += "    "
            item = ParseFilePath(0, item, "/", 1, 0)            // Get last element
            item = indent + item                // Prepend indentation
            result += item + ";"
    return result
static Function/S GetFileHierarchy(bd, mode)
    if (bd.fileID == 0)                         // No file is open?
        return ""
    String hierarchy, rootName
    if (mode == 1)
        rootName = "/"      // For purposes of storing full path, use true root name
        rootName = "root"       // For display purposes, use "root" as root name
    hierarchy = rootName + ";" + GetGroupHierarchy(bd.fileID, "/", 1, mode)
    return hierarchy
static Function ResetListSelections(bd, resetGroupsList, resetGroupAttributesList, resetDatasetsList, resetDatasetAttributesList)
    Variable resetGroupsList, resetGroupAttributesList, resetDatasetsList, resetDatasetAttributesList
    if (resetGroupsList)
        ListBox GroupsList, win=$bd.browserName, selRow=0
    if (resetGroupAttributesList)
        ListBox GroupAttributesList, win=$bd.browserName, selRow=0
    if (resetDatasetsList)
        ListBox DatasetsList, win=$bd.browserName, selRow=0
    if (resetDatasetAttributesList)
        ListBox DatasetAttributesList, win=$bd.browserName, selRow=0
Function/S HDF5GetObjectFullPath(groupPath, objectName)
    String groupPath                    // Path to parent group
    String objectName               // Name of dataset or group in parent group
    String fullPath
    if (CmpStr(groupPath, "/") == 0)
        fullPath = "/" + objectName
        fullPath = groupPath + "/" + objectName
    return fullPath
Function/S GetTextPreviewString(tw)
    Wave/T tw                   // tw has already been flattened to 1D.
    String preview, temp
    Variable len
    Variable row, numRows, totalLength
    totalLength = 0
    numRows = numpnts(tw)
    if (numRows == 0)
        return ""
    preview = ""
    row = 0
    do
        temp = tw[row]
        temp = ReplaceString("\r", temp, "<CR>", 1) // Convert CR to "\r"
        temp = ReplaceString("\n", temp, "<LF>", 1) // Convert LF to "\n"
        len = strlen(temp)
        if (len > 128)
            if (numRows == 1)
                sprintf preview, "\"%s\" . . . (%d characters total)", temp[0,127], len
                preview += " . . . <Strings too long to display here>"
            row = numRows               // To prevent extra . . .
            break
        preview += "\"" + temp + "\""
        row += 1
        totalLength += len
        if (row >= numRows)
            break
        if (totalLength >= 256)             // Enough is enough
            break
        preview += ", "
    while(1)
    if (row < numRows)
        preview += " . . ."
    return preview
Function/S GetNumericPreviewString(w)
    Wave w                      // w has already been flattened to 1D.
    totalLength = 0
    numRows = numpnts(w)
    if (numRows == 0)
        return ""
    preview = ""
    row = 0
    do
        sprintf temp, "%g", w[row]
        preview += temp
        row += 1
        totalLength += strlen(temp)
        if (row >= numRows)
            break
            break
        preview += ", "
    while(1)
    if (row < numRows)
        preview += " . . ."
    return preview
Function/S GetPreviewString(locationID, objectType, di, fullPath, attributeName)
    Variable locationID
    Variable objectType                     // 1 = group, 2 = dataset
    STRUCT HDF5DataInfo &di
    String fullPath                     // Full path to group or dataset
    String attributeName                // "" if this is a dataset, not an attribute
    String value = "<Can't display here>"
    String temp
    Variable rank = di.ndims
    Variable dim, numElements
    if (rank == 0)
        numElements = 1
        numElements = di.dims[0]
        for(dim=1; dim<rank; dim+=1)
            numElements *= di.dims[dim]
    strswitch(di.datatype_class_str)
        case "H5T_INTEGER":
        case "H5T_FLOAT":
        case "H5T_ENUM":
        case "H5T_OPAQUE":
        case "H5T_BITFIELD":
            if (numElements > 100)
                value = "<Too big to display here>"// It would take too long to load.
                break
            HDF5LoadData /A=attributeName /N=tempNumericAttributeWave /O /Q /TYPE=(objectType) /VAR=0 /Z locationID, fullPath
            if (V_flag != 0)
                value = "ERROR!"
                Wave tempNumericAttributeWave
                if (rank > 1)
                    // So we can treat multi-dimensional wave as one big row.
                    Redimension/N=(numElements)/E=1 tempNumericAttributeWave
                value = GetNumericPreviewString(tempNumericAttributeWave)
            KillWaves/Z tempNumericAttributeWave
            break
        case "H5T_REFERENCE":
            if (numElements > 10)
                value = "<Too big to display here>" // It would take too long to load.
                break
            HDF5LoadData /A=attributeName /N=tempTextAttributeWave /O /Q /TYPE=(objectType) /VAR=0 /Z locationID, fullPath
            if (V_flag != 0)
                value = "ERROR!"
                if (rank > 1)
                    Redimension/N=(numElements)/E=1 tempTextAttributeWave
                // Remove the prefix (e.g., "D:" for a dataset, which is there for
                // programmatic use but would confuse in a preview.
                Wave/T references = tempTextAttributeWave           // Created by HDF5LoadData
                String tmp
                Variable npnts=numpnts(references), len
                Variable i
                for(i=0; i<npnts; i+=1)
                    tmp = references[i]
                    len = strlen(tmp)
                    references[i] = tmp[2,len]
                value = GetTextPreviewString(references)
            KillWaves/Z tempTextAttributeWave
            break
        case "H5T_STRING":
                break
            if (V_flag != 0)
                value = "ERROR!"
                if (rank > 1)
                value = GetTextPreviewString(tempTextAttributeWave)
            break
        case "H5T_TIME":
        case "H5T_COMPOUND":
        case "H5T_VLEN":
        case "H5T_ARRAY":
            value = "<Can't display this type here>"
            break
    endswitch
    return value
static Function FillDatasetsList(bd)
    HDF5ListGroup /TYPE=2 bd.fileID, bd.groupPath
    Variable numItemsInList = ItemsInList(S_HDF5ListGroup)
    if (numItemsInList == 0)
        Redimension/N=0 bd.datasetsList
        Redimension/N=(numItemsInList, 5) bd.datasetsList
        SetDimLabel 1, 0, Dataset, bd.datasetsList
        SetDimLabel 1, 1, Rank, bd.datasetsList
        SetDimLabel 1, 2, 'Dim Sizes', bd.datasetsList
        SetDimLabel 1, 3, Type, bd.datasetsList
        SetDimLabel 1, 4, Value, bd.datasetsList
        bd.datasetsList[][0] = StringFromList(p, S_HDF5ListGroup)
        String dataset
        Variable i, numDatasets
        numDatasets = ItemsInList(S_HDF5ListGroup)
        for(i=0; i<numDatasets; i+=1)
            dataset = StringFromList(i, S_HDF5ListGroup)
            String fullPath = HDF5GetObjectFullPath(bd.groupPath, dataset)
            STRUCT HDF5DataInfo di
            InitHDF5DataInfo(di)            // Set input fields.
            HDF5DatasetInfo(bd.fileID, fullPath, 0, di)
            bd.datasetsList[i][1] = num2istr(rank)
            String dimsStr=""
            Variable dim
            for(dim=0; dim<rank; dim+=1)
                dimsStr += num2istr(di.dims[dim]) + ";"
            bd.datasetsList[i][2] = dimsStr
            bd.datasetsList[i][3] = di.datatype_str
            String preview = GetPreviewString(bd.fileID, 2, di, fullPath, "")
            bd.datasetsList[i][4] = preview
static Function FillGroupAttributesList(bd)
    Variable numAttributes = 0
    String groupPath = bd.groupPath
    if (strlen(groupPath) > 0)
        HDF5ListAttributes/TYPE=1 bd.fileID, groupPath
        numAttributes = ItemsInList(S_HDF5ListAttributes)
    if (numAttributes == 0)
        Redimension/N=0 bd.groupAttributesList
        Redimension/N=(numAttributes, 5) bd.groupAttributesList
        SetDimLabel 1, 0, Attribute,bd.groupAttributesList
        SetDimLabel 1, 1, Rank,bd.groupAttributesList
        SetDimLabel 1, 2, 'Dim Sizes',bd.groupAttributesList
        SetDimLabel 1, 3, Type,bd.groupAttributesList
        SetDimLabel 1, 4, Value,bd.groupAttributesList
        bd.groupAttributesList[][0] = StringFromList(p, S_HDF5ListAttributes)
        String attribute
        Variable i
        for(i=0; i<numAttributes; i+=1)
            attributeName = StringFromList(i, S_HDF5ListAttributes)
            attribute = attributeName
            HDF5AttributeInfo(bd.fileID, groupPath, 1, attribute, 0, di)
            bd.groupAttributesList[i][1] = num2istr(rank)
            String dimsStr=""
            Variable dim
            bd.groupAttributesList[i][2] = dimsStr
            bd.groupAttributesList[i][3] = di.datatype_str
            String preview = GetPreviewString(bd.fileID, 1, di, groupPath, attributeName)
            bd.groupAttributesList[i][4] = preview
static Function FillDatasetAttributesList(bd)
    String datasetPath = SelectedDatasetPath(bd)
    if (strlen(datasetPath) > 0)
        HDF5ListAttributes/TYPE=2 bd.fileID, datasetPath
        Redimension/N=0 bd.datasetAttributesList
        Redimension/N=(numAttributes, 5) bd.datasetAttributesList
        SetDimLabel 1, 0, Attribute,bd.datasetAttributesList
        SetDimLabel 1, 1, Rank,bd.datasetAttributesList
        SetDimLabel 1, 2, 'Dim Sizes',bd.datasetAttributesList
        SetDimLabel 1, 3, Type,bd.datasetAttributesList
        SetDimLabel 1, 4, Value,bd.datasetAttributesList
        bd.datasetAttributesList[][0] = StringFromList(p, S_HDF5ListAttributes)
        String attribute
        Variable i
            HDF5AttributeInfo(bd.fileID, datasetPath, 2, attribute, 0, di)
            bd.datasetAttributesList[i][1] = num2istr(rank)
            String dimsStr=""
            Variable dim
            bd.datasetAttributesList[i][2] = dimsStr
            bd.datasetAttributesList[i][3] = di.datatype_str
            String preview = GetPreviewString(bd.fileID, 2, di, datasetPath, attributeName)
            bd.datasetAttributesList[i][4] = preview
static Function FillLists(bd)
        Redimension/N=(0) bd.groupsList
        Redimension/N=(0) bd.groupAttributesList
        Redimension/N=(0) bd.datasetsList
        Redimension/N=(0) bd.datasetAttributesList
        return -1
    String hierarchy
    // Show entire hierarchy in Groups list.
    hierarchy = GetFileHierarchy(bd, 0)
    numItemsInList = ItemsInList(hierarchy)
    Redimension/N=(numItemsInList) bd.groupsList
    bd.groupsList = StringFromList(p, hierarchy)
    // The groupFullPaths wave stores the full path to each group
    hierarchy = GetFileHierarchy(bd, 1)
    Redimension/N=(numItemsInList) bd.groupFullPaths
    bd.groupFullPaths = StringFromList(p, hierarchy)
    // Show datasets in current group in Datasets list.
    // Show attributes of currently-selected group.
    // Show attributes of currently-selected dataset.
Function/S SelectedGroupName(bd)
    if (numpnts(bd.groupsList) == 0)
        return ""
    ControlInfo/W=$bd.browserName GroupsList
    Variable selRow = V_value
    String groupName = bd.groupsList[selRow]
    // Group names may have leading spaces at this point. The spaces are used to create
    // indentation in the list to show the hierarchy. We must remove the leading spaces.
    sscanf groupName, " %s", groupName
    if (strlen(groupName) > 0)
        return groupName
    return ""
Function/S SelectedGroupPath(bd)
    return groupPath
Function/S SelectedDatasetName(bd)
    if (numpnts(bd.datasetsList) == 0)
        return ""
    ControlInfo/W=$bd.browserName DatasetsList
    String datasetName = bd.datasetsList[selRow][0]
    if (strlen(datasetName) > 0)
        return datasetName
    return ""
Function/S SelectedDatasetPath(bd)
    String datasetName = SelectedDatasetName(bd)
    if (strlen(datasetName) == 0)
        return ""                       // Nothing is selected
    String datasetPath = bd.groupPath
    if (CmpStr(datasetPath[strlen(datasetPath)-1],"/") != 0)
        datasetPath += "/"
    datasetPath += datasetName
    return datasetPath
Function/S SelectedAttributeName(bd, isGroupAttribute)
    Variable isGroupAttribute
    String controlName
    if (isGroupAttribute)
        controlName = "GroupAttributesList"
        Wave/T list = bd.groupAttributesList
        controlName = "DatasetAttributesList"
        Wave/T list = bd.datasetAttributesList
    if (numpnts(list) == 0)
        return ""
    ControlInfo/W=$bd.browserName $controlName
    String attributeName = list[selRow][0]
    if (strlen(attributeName) > 0)
        return attributeName
    return ""
Function/S SelectedAttributePath(bd, isGroupAttribute)
    String attributeName = SelectedAttributeName(bd, isGroupAttribute)
    if (strlen(attributeName) == 0)
    String path
        path = SelectedGroupPath(bd)
        path = SelectedDatasetPath(bd)
    path += "/" + attributeName
    return path
StrConstant kLoadAllMembersString = "_Load_All_Members_"
static Function SetMembersPopupMenu(bd)
    Variable hideMembers
    String memberList
    hideMembers = 1
    memberList = kLoadAllMembersString + ";"
    if (bd.fileID != 0)             // File is open for this browser?
        String fullPath
        fullPath = SelectedDatasetPath(bd)
        if (strlen(fullPath) > 0)
            if (CmpStr(di.datatype_class_str, "H5T_COMPOUND") == 0)
                hideMembers = 0
                ControlInfo /W=$bd.browserName Members
                Variable selectedItemNumber = V_Value
                STRUCT HDF5DatatypeInfo dti
                InitHDF5DatatypeInfo(dti)
                if (HDF5TypeInfo(bd.fileID, fullPath, "", "", 1, dti))
                    memberList += "HDF5TypeInfo Error!"
                    memberList += dti.names
                    if (selectedItemNumber > dti.nmembers+1)    // +1 because of "_Load_All_Members_" item.
                        selectedItemNumber = 1      // Force menu selection to be in bounds.
                PopupMenu Members, win=$bd.browserName, mode=selectedItemNumber
    PopupMenu Members, win=$bd.browserName, disable=hideMembers
    String cmd              // What a pain. Can't use local variable with PopupMenu value=
    sprintf cmd, "PopupMenu Members, win=%s, value=\"%s\"", bd.browserName, memberList
    Execute cmd
Function HDF5GetReadOnlySetting(browserName)
    String browserName
    Variable result
    ControlInfo /W=$browserName ReadOnly
    result = V_value
    return result
Function HDF5GetCompLoadInfo(bd, isCompound, compMode, memberName)
    Variable &isCompound                    // Output: If non-zero, a compound dataset is selected.
    Variable &compMode                      // Output: Value suitable for passing to HDF5LoadData /COMP flag.
    String &memberName                      // Output: If "" load all members.
    isCompound = 0
    memberName = ""
    if (V_disable == 0)
        isCompound = 1
        memberName = S_value
        if (CmpStr(memberName, kLoadAllMembersString) == 0)
            memberName = ""
    compMode = isCompound && strlen(memberName)>0
Function HDF5GetTranspose2DSetting(browserName)
    String browserName
    Variable result
    ControlInfo /W=$browserName Transpose2DDatasets
    result = V_value
    return result
static Function HDF5GetLoadDatasetOptions(browserName, tableDisplayMode, graphDisplayMode)
    String browserName
    Variable &tableDisplayMode, &graphDisplayMode
    ControlInfo /W=$browserName DisplayInTable
    tableDisplayMode = V_value - 1                      // 0=no; 1=display; 2=append
    ControlInfo /W=$browserName DisplayInGraph
    graphDisplayMode = V_value - 1                      // 0=no; 1=display; 2=append
    return tableDisplayMode || graphDisplayMode
static Function MembersPopupProc(ctrlName,popNum,popStr) : PopupMenuControl
    String ctrlName
    Variable popNum
    String popStr
    String browserName = HDF5GetTopBrowserName()
    STRUCT HDF5BrowserData bd
    HDF5DisplaySelectedDataset(bd)
static Function SetButtonStates(bd)
    if (bd.fileID == 0)             // No file is open for this browser?
        Button CreateFile, win=$bd.browserName, disable=0       // Enable Create
        Button OpenFile, win=$bd.browserName, disable=0     // Enable Open
        Button CloseFile, win=$bd.browserName, disable=2        // Disable Close
        Button LoadGroup, win=$bd.browserName, disable=2        // Disable Load Group
        Button SaveDataFolder, win=$bd.browserName, disable=2   // Disable Save Data Folder
        Button LoadDataset, win=$bd.browserName, disable=2  // Disable Load Dataset
        Button SaveWaves, win=$bd.browserName, disable=2        // Disable Save Waves
        Button CreateFile, win=$bd.browserName, disable=2       // Disable Create
        Button OpenFile, win=$bd.browserName, disable=2     // Disable Open
        Button CloseFile, win=$bd.browserName, disable=0        // Enable Close
        String groupName = SelectedGroupName(bd)
        Variable code = strlen(groupName) > 0 ? 0:2
        Button LoadGroup, win=$bd.browserName, disable=code // Enable Load Group
        code = bd.readOnly == 0 ? 0:2
        Button SaveDataFolder, win=$bd.browserName, disable=code    // Enable Save Data Folder
        code = strlen(datasetName) > 0 ? 0:2
        Button LoadDataset, win=$bd.browserName, disable=code   // Enable Load Dataset
        Button SaveWaves, win=$bd.browserName, disable=code     // Enable Save Waves
    SetGraphButtonTitle(bd.browserName)
    SetTableButtonTitle(bd.browserName)
    SetDumpButtonTitle(bd.browserName)
    SetVariable HyperSelectionWave, win=$bd.browserName, value= bd.hyperSelectionWavePath
static Function DrawFilePath(bd)
    // TitleBox FilePath, win=$bd.browserName, title=bd.fullPath            // This is limited to 63 characters.
    TitleBox FilePath, win=$bd.browserName, variable=bd.fullPath
static Function DrawGroupPath(bd)
    TitleBox GroupPath, win=$bd.browserName, variable=bd.groupPath
static Function DrawDatasetInfo(bd)
    TitleBox Dataset, win=$bd.browserName, variable=bd.datasetInfo
static Function UpdateAfterFileCreateOrOpen(isCreate, browserName, fileID, path, fileName)
    Variable isCreate
    String browserName
    Variable fileID
    String path, fileName
    ResetListSelections(bd, 1, 1, 1, 1)
    bd.fileID = fileID
    bd.fileName = fileName
    bd.path = path
    bd.fullPath = path + fileName
    DrawFilePath(bd)
    bd.readOnly = isCreate ? 0 : HDF5GetReadOnlySetting(browserName)
    bd.groupPath = "/"
    DrawGroupPath(bd)
    SetButtonStates(bd)
    FillLists(bd)
    UpdateAfterGroupSelected(bd, "/")
        SelectDataset(bd, datasetName)
static Function CreateFileButtonProc(ctrlName) : ButtonControl
    String ctrlName
    Variable fileID
    HDF5CreateFile /I /O fileID  as ""
    if (V_flag == 0)        // Create OK?
        UpdateAfterFileCreateOrOpen(1, browserName, fileID, S_path, S_fileName)
static Function OpenFileButtonProc(ctrlName) : ButtonControl
    String ctrlName
    Variable readOnly = HDF5GetReadOnlySetting(browserName)
    Variable locFileID
    if (readOnly)
        HDF5OpenFile/R locFileID as ""
        HDF5OpenFile locFileID as ""
    if (V_flag == 0)                    // Open OK?
        UpdateAfterFileCreateOrOpen(0, browserName, locFileID, S_path, S_fileName)
// This detects if the file is no longer open, such as if you save the experiment, quit Igor and then reopen the experiment.
Function FileWasUnexpectedlyClosed(bd)
    if (bd.fileID == 0)
        return 0                // File is closed but not unexpectedly.
    HDF5ListAttributes/Q /TYPE=1 /Z bd.fileID , "/"     // Try to list the attributes of the root of the file.
    if (V_flag != 0)
        return 1                                // Error: Assume file was closed.
static Function FileWasClosed(bd)           // Does cleanup after a file is closed.
    bd.fileID = 0
    Redimension/N=(0) bd.groupFullPaths
    bd.groupPath = ""
    bd.fileName = ""
    bd.path = ""
    bd.fullPath = ""
    bd.datasetInfo = ""
    DrawFilePath(bd)
    SetButtonStates(bd)
    FillLists(bd)
static Function CloseFileButtonProc(ctrlName) : ButtonControl
    String ctrlName
    HDF5CloseFile bd.fileID
    CloseSavePanels()
    FileWasClosed(bd)
static Function LoadDatasetButtonProc(ctrlName) : ButtonControl
    String ctrlName
    String slabWaveStr = ""
    ControlInfo /W=$bd.browserName UseHyperSelection
    if (V_value)                                // Use Hyperselection is checked?
        slabWaveStr = bd.hyperSelectionWavePath
    WAVE/Z slabWave = $slabWaveStr          // It is OK if wave does not exist and slabWave is NULL. HDF5LoadData will simply ignore /SLAB.
    Variable isCompound
    String memberName
    Variable compMode
    // If isFormalImage is true, we are loading an image written
    // according to the HDF5 Image and Palette Specification.
    Variable isFormalImage = 0
    if (!isCompound)
        String savedDataFolder = SetBrowserDataFolder("")           // tempClassAttribute goes in master HDF5Browser data folder
        HDF5LoadData /Z /O /N=tempClassAttribute /A="CLASS" /Q /VAR=1 bd.fileID, datasetPath
        if (V_flag == 0)
            WAVE/T tempClassAttribute           // HDF5LoadData will have created this string
            if (CmpStr(tempClassAttribute[0],"IMAGE") == 0)
                isFormalImage = 1
            KillWaves/Z tempClassAttribute
    Variable tableDisplayMode, graphDisplayMode     // 0=no; 1=display; 2=append
    HDF5GetLoadDatasetOptions(bd.browserName, tableDisplayMode, graphDisplayMode)
    if (isFormalImage)
        HDF5LoadImage /O /GRPH=(graphDisplayMode) /T=(tableDisplayMode) bd.fileID, datasetPath
        Variable transpose2D = HDF5GetTranspose2DSetting(bd.browserName)
        HDF5LoadData /O /SLAB=slabWave /TRAN=(transpose2D) /COMP={compMode,memberName} /GRPH=(graphDisplayMode) /T=(tableDisplayMode) bd.fileID, datasetPath
static Function LoadGroupButtonProc(ctrlName) : ButtonControl
    String ctrlName
    String groupPath = SelectedGroupPath(bd)
    ControlInfo /W=$bd.browserName LoadGroupsRecursively
    if (V_value)                                    // Use LoadGroupsRecursively is checked?
        HDF5LoadGroup /O /R /T /IMAG=1 :, bd.fileID, groupPath
        HDF5LoadGroup /O /T /IMAG=1 :, bd.fileID, groupPath
    // For debugging
    Variable numItems
    Variable debug = 1
    if (debug)
        Wave/Z/T groupPaths = root:groupPaths
        if (WaveExists(groupPaths))
            numItems = ItemsInList(S_groupPaths)
            Redimension/N=(numItems) groupPaths
            groupPaths = StringFromList(p, S_groupPaths)
        Wave/Z/T dataFolderPaths = root:dataFolderPaths
        if (WaveExists(dataFolderPaths))
            numItems = ItemsInList(S_dataFolderPaths)
            Redimension/N=(numItems) dataFolderPaths
            dataFolderPaths = StringFromList(p, S_dataFolderPaths)
        Wave/Z/T wavePaths = root:wavePaths
        if (WaveExists(wavePaths))
            numItems = ItemsInList(S_objectPaths)
            Redimension/N=(numItems) wavePaths
            wavePaths = StringFromList(p, S_objectPaths)
Function AttachListWaves(bd)
    ListBox GroupsList win=$bd.browserName, listWave=bd.groupsList
    ListBox GroupAttributesList win=$bd.browserName, listWave=bd.groupAttributesList
    ListBox DatasetsList win=$bd.browserName, listWave=bd.datasetsList
    ListBox DatasetAttributesList win=$bd.browserName, listWave=bd.datasetAttributesList
Function HDF5BrowserPanelHook(infoStr)
    String infoStr
    String browserName= StringByKey("WINDOW",infoStr)
    String event= StringByKey("EVENT",infoStr)
    strswitch(event)
        case "activate":                // We do not get this on Windows when the panel is first created.
            if (FileWasUnexpectedlyClosed(bd))
                Printf "The file \"%s\" is no longer open.\r", bd.fileName
                FileWasClosed(bd)
            SetGraphButtonTitle(browserName)
            SetTableButtonTitle(browserName)
            SetDumpButtonTitle(browserName)
            break
        case "resize":
            HDF5ResizeBrowser(browserName)
            break
        case "moved":           // This message was added in Igor Pro 5.04B07.
            // If this is the last HDF5 browser, save the browser window size and position.
            if (strlen(HDF5GetIndexedBrowserName(1)) == 0)
                SetPrefWindowCoords(browserName)
            break
        case "kill":
            if (bd.fileID != 0)
                bd.fileID = 0
                CloseSavePanels()
            KillDataFolder root:Packages:HDF5Browser:$browserName
            break
    endswitch
Function SelectDataset(bd, datasetName)
    String datasetName
    String info
        info = ""
        String fullPath
        fullPath = HDF5GetObjectFullPath(bd.groupPath, datasetName)
        // Print s
        sprintf info, "%s, class=%s", datasetName, di.datatype_class_str
    bd.datasetInfo = info
    DrawDatasetInfo(bd)
    SetButtonStates(bd)
Function UpdateAfterGroupSelected(bd, fullGroupPath)
    String fullGroupPath
    Variable selectedGroupChanged = CmpStr(bd.groupPath, fullGroupPath) != 0
    bd.groupPath = fullGroupPath
    DrawGroupPath(bd)
    if (selectedGroupChanged)
        ResetListSelections(bd, 0, 1, 1, 1)
        String datasetName = ""
        if (numpnts(bd.datasetsList) > 0)
            datasetName = bd.datasetsList[0][0]
    SetButtonStates(bd)
static Function GroupsListActionProc(s, bd) : ListboxControl
    STRUCT WMListboxAction &s
    String browserName = s.win
    Variable result = 0                                 // As of now, the return value must always be zero.
    switch(s.eventCode)
        case 4:                     // Cell selection
            String fullGroupPath = bd.groupFullPaths[s.row]
            // Printf "Row=%d, column=%d, path=%s\r", s.row, s.col, fullGroupPath
            if (HDF5BrowserDumpIsVisible())
                HDF5DisplayDumpOfSelectedGroup(bd)
            break
    endswitch
    return result
static Function GroupAttributesListActionProc(s, bd) : ListboxControl
    switch(s.eventCode)
        case 3:                     // Double-click
            break;
            // Printf "Row=%d, column=%d\r", s.row, s.col
            HDF5DisplaySelectedAttribute(bd,  1)                // Update various windows if they are displayed
            break
    endswitch
    return result
Function HandleDatasetDoubleClick(s, bd)
    if (strlen(datasetPath) == 0)
        return -1
    HDF5DatasetInfo(bd.fileID, datasetPath, 0, di)
    switch(di.datatype_class)
        default:
            // Load dataset here.
            break
    endswitch
static Function DatasetsListActionProc(s, bd) : ListboxControl
    switch(s.eventCode)
            break;
            String name = bd.datasetsList[s.row][0]
            SelectDataset(bd, name)
            // Printf "Row=%d, column=%d, name=%s\r", s.row, s.col, name
            HDF5DisplaySelectedDataset(bd)                  // Update various windows if they are displayed
            break
    endswitch
    return result
static Function DatasetAttributesListActionProc(s, bd) : ListboxControl
    switch(s.eventCode)
            break;
            HDF5DisplaySelectedAttribute(bd,  0)                // Update various windows if they are displayed
            break
    endswitch
    return result
static Function ListBoxActionProc(s) : ListboxControl
    strswitch(s.ctrlName)
        case "GroupsList":
            result = GroupsListActionProc(s, bd)
            break
        case "GroupAttributesList":
            result = GroupAttributesListActionProc(s, bd)
            break
        case "DatasetsList":
            result = DatasetsListActionProc(s, bd)
            break
        case "DatasetAttributesList":
            result = DatasetAttributesListActionProc(s, bd)
            break
    endswitch
    return result
static Function SetGraphButtonTitle(browserName)
    String browserName
    if (HDF5BrowserGraphIsVisible())
        Button Graph, win=$browserName, title="Hide Graph"
        Button Graph, win=$browserName, title="Show Graph"
static Function GraphButtonProc(ctrlName) : ButtonControl
    String ctrlName
        DoWindow/K HDF5BrowserGraph
        HDF5CreateBrowserGraph()                // Create if it does not exist.
static Function SetTableButtonTitle(browserName)
    String browserName
    if (HDF5BrowserTableIsVisible())
        Button Table, win=$browserName, title="Hide Table"
        Button Table, win=$browserName, title="Show Table"
static Function TableButtonProc(ctrlName) : ButtonControl
    String ctrlName
        DoWindow/K HDF5BrowserTable
        HDF5CreateBrowserTable()                // Create if it does not exist.
static Function SetDumpButtonTitle(browserName)
    String browserName
        Button Dump, win=$browserName, title="Hide Dump"
        Button Dump, win=$browserName, title="Show Dump"
static Function DumpButtonProc(ctrlName) : ButtonControl
    String ctrlName
        Notebook HDF5DumpNotebook, visible=0
        HDF5CreateDumpWindow()                      // Create if it does not exist.
        DoWindow/F HDF5DumpNotebook         // Show it.
static Function HelpButtonProc(ctrlName) : ButtonControl
    String ctrlName
    DisplayHelpTopic "The HDF5 Browser"
static Function CreateHDF5BrowserPanel(browserName)
    String browserName
    Variable isMacintosh = 0
    if (CmpStr(IgorInfo(2),"Macintosh") == 0)
        isMacintosh = 1
    // Determine panel size and position
    Variable left, top, right, bottom
    GetPrefWindowCoords("HDF5Browser", left, top, right, bottom)    // See if prefs set.
    if (right-left<200 || bottom-top<200)
        // These values are calculated to fill a typical 17 inch screen (832x624) on Macintosh.
        left = 5
        top = 50
        right = 820
        bottom = 625
    Variable readOnly, loadGroupsRecursively, transpose2DDatasets
    GetPrefBrowserSettings(readOnly, loadGroupsRecursively, transpose2DDatasets)
    NewPanel /W=(left, top, right, bottom)/K=1 as "HDF5 Browser"
    DoWindow/C $browserName
    DoWindow/T $browserName, browserName
    // This marks this control panel as an HDF5 browser.
    SetWindow kwTopWin, userdata(HDF5BrowserName)=browserName
    SetDrawLayer ProgBack
    SetDrawEnv fstyle= 1
    DrawText 18,75,"File:"
    DrawText 18,103,"Selected Group:"
    DrawText 18,130,"Selected Dataset:"
    TitleBox FilePath,pos={55,57},size={706,21}
    left = isMacintosh ? 150 : 125
    TitleBox GroupPath,pos={left,86},size={658,20}
    TitleBox Dataset,pos={left,113},size={13,21}
    CheckBox UseHyperSelection,pos={15,155},size={110,14},title="Use Hyperselection",value= 0
    CheckBox UseHyperSelection,help={"For experts only. Allows loading a subset of a dataset."}
    SetVariable HyperSelectionWave,pos={140,155},size={390,16},title="Hyper Selection Wave:"
    SetVariable HyperSelectionWave,help={"Enter full path to wave containing hyperselection information. See HDF5LoadData /SLAB keyword help."}
    CheckBox LoadGroupsRecursively,pos={15,181},size={137,14},title="Load Groups Recursively",value=loadGroupsRecursively
    CheckBox LoadGroupsRecursively,proc=HDF5BrowserPrefCheckboxProc,help={"When checked, the Load Group button loads subgroups."}
    Button CreateFile,pos={15,8},size={125,20},proc=HDF5Browser#CreateFileButtonProc,title="Create HDF5 File"
    Button OpenFile,pos={159,8},size={125,20},proc=HDF5Browser#OpenFileButtonProc,title="Open HDF5 File"
    Button CloseFile,pos={296,8},size={125,20},proc=HDF5Browser#CloseFileButtonProc,title="Close HDF5 File"
    Button Help,pos={435,8},size={50,20},proc=HDF5Browser#HelpButtonProc,title="Help"
    CheckBox ReadOnly,pos={186,32},size={68,14},title="Read Only",proc=HDF5BrowserPrefCheckboxProc,value=readOnly
    // Start Preview
    Button Graph,pos={556,27},size={90,20},proc=HDF5Browser#GraphButtonProc,title="Show Graph"
    Button Graph help={"Shows or hides a graph which displays the last dataset or attribute that you selected."}
    Button Table,pos={672,27},size={90,20},proc=HDF5Browser#TableButtonProc,title="Show Table"
    Button Table help={"Shows or hides a table which displays the last dataset or attribute that you selected."}
    Button Dump,pos={556,59},size={90,20},proc=HDF5Browser#DumpButtonProc,title="Show Dump"
    Button Dump help={"Shows or hides a window which displays a dump of the last dataset or attribute that you selected."}
    CheckBox ShowAttributesInDump,pos={653,71},size={100,14},title="Show Attributes In Dump"
    CheckBox ShowAttributesInDump help={"Check to display the dataset's attributes in the dump window."}
    CheckBox ShowDataInDump,pos={653,56},size={114,14},title="Show Data In Dump"
    CheckBox ShowDataInDump,help={"Check to display data in the dump window. For large datasets this can take a long time."}
    GroupBox PreviewOptions,pos={543,5},size={258,87},title="Preview Options"
    // End Preview
    TitleBox GroupsTitle,pos={15,230},size={50,16},disable=2,title="Groups",fSize=14
    TitleBox GroupsTitle,frame=0,fStyle=1
    ListBox GroupsList,pos={15,250},size={306,170}, mode=2, proc=HDF5Browser#ListBoxActionProc
    ListBox GroupsList,fSize=14
    Button LoadGroup,pos={80,224},size={100,20},proc=HDF5Browser#LoadGroupButtonProc,title="Load Group"
    Button LoadGroup,help={"Loads the currently selected group into the current data folder."}
    Button SaveDataFolder,pos={194,224},size={120,20},proc=HDF5Browser#SaveDataFolderButtonProc,title="Save Data Folder"
    Button SaveDataFolder,help={"Saves a data folder in the currently selected group. Available if the current HDF5 file is open for read/write."}
    TitleBox GroupAttributesTitle,pos={15,435},size={111,16},disable=2,title="Group Attributes"
    TitleBox GroupAttributesTitle,fSize=14,frame=0,fStyle=1
    ListBox GroupAttributesList,pos={15,455},size={306,109}, mode=2, proc=HDF5Browser#ListBoxActionProc
    ListBox GroupAttributesList, widths={175,40,80,120,1000}, userColumnResize= 1   // userColumnResize requires Igor Pro 5.02.
    ListBox GroupAttributesList,fSize=14
    TitleBox DatasetsTitle,pos={341,230},size={62,16},disable=2,title="Datasets"
    TitleBox DatasetsTitle,fSize=14,frame=0,fStyle=1
    ListBox DatasetsList,pos={341,250},size={459,170}, mode=2, proc=HDF5Browser#ListBoxActionProc
    ListBox DatasetsList, widths={175,40,80,120,1000}, userColumnResize= 1  // userColumnResize requires Igor Pro 5.02.
    ListBox DatasetsList,fSize=14
    TitleBox DatasetAttributesTitle,pos={341,435},size={123,16},disable=2,title="Dataset Attributes"
    TitleBox DatasetAttributesTitle,fSize=14,frame=0,fStyle=1
    ListBox DatasetAttributesList,pos={341,455},size={459,109}, mode=2, proc=HDF5Browser#ListBoxActionProc
    ListBox DatasetAttributesList, widths={175,40,80,120,1000}, userColumnResize= 1 // userColumnResize requires Igor Pro 5.02.
    ListBox DatasetAttributesList,fSize=14
    Button LoadDataset,pos={415,224},size={100,20},proc=HDF5Browser#LoadDatasetButtonProc,title="Load Dataset"
    Button LoadDataset,help={"Loads the currently selected dataset into the current data folder."}
    Button SaveWaves,pos={529,224},size={100,20},proc=HDF5Browser#SaveWavesButtonProc,title="Save Waves"
    Button SaveWaves,help={"Saves waves in the currently selected group. Available if the current HDF5 file is open for read/write."}
    CheckBox Transpose2DDatasets,pos={189,181},size={130,14},title="Transpose 2D Datasets",value=transpose2DDatasets
    CheckBox Transpose2DDatasets,proc=HDF5BrowserPrefCheckboxProc,help={"When checked, 2D datasets are transposed so that Igor image plots will match HDFView."}
    PopupMenu Members,pos={342,194},size={216,24},title="Members"
    PopupMenu Members,mode=1,value= #"\"Load All Members\""
    PopupMenu Members proc=HDF5Browser#MembersPopupProc
    PopupMenu Members,help={"Choose the compound member to preview or load."}
    // Load Dataset Options
    PopupMenu DisplayInTable,pos={565,123},size={200,24},title="Table:"
    PopupMenu DisplayInTable,mode=2,value= #"\"No Table;Display in New Table;Append to Top Table\""
    PopupMenu DisplayInGraph,pos={563,154},size={203,24},title="Graph:"
    PopupMenu DisplayInGraph,mode=2,value= #"\"No Graph;Display in New Graph;Append to Top Graph\""
    GroupBox LoadDatasetOptions,pos={542,100},size={258,87},title="Load Dataset Options"
    HDF5ResizeBrowser(browserName)      // Needed because we used preferred browser size.
    SetWindow kwTopWin,hook=HDF5BrowserPanelHook
EndMacro
Function HDF5BrowserPrefCheckboxProc(ctrlName,checked) : CheckBoxControl
    String ctrlName
    Variable checked
    STRUCT HDF5BrowserPrefs prefs
    HDF5BrowserLoadPackagePrefs(prefs)
    strswitch(ctrlName)
        case "ReadOnly":
            prefs.readOnly = checked
            break
        case "LoadGroupsRecursively":
            prefs.loadGroupsRecursively = checked
            break
        case "Transpose2DDatasets":
            prefs.transpose2DDatasets = checked
            break
        case "SaveGroupsRecursively":
            prefs.saveGroupsRecursively = checked
            break
        case "IncludeIgorAttributes":
            prefs.includeIgorAttributes = checked
            break
    endswitch
    HDF5BrowserSavePackagePrefs(prefs)
Function CreateNewHDF5Browser()
    if (Exists("HDF5LoadData") != 4)
        String message
        message = "The HDF5XOP is not activated. Please see the HDF5XOP Help file for instructions."
        DoAlert 0, message
        DisplayHelpTopic "HDF5XOP"
        return -1
    String browserName = UniqueName("HDF5Browser", 9, 0)
    CreateHDF5BrowserGlobals(browserName)
    AttachListWaves(bd)
    SetButtonStates(bd)
Static Function IsHDF5Browser(name)
    String name         // Name of a window
    if (WinType(name) != 7)
        return 0                // Not a control panel window
    String data = GetUserData(name, "", "HDF5BrowserName")  // HDF5BrowserName property is set by CreateHDF5BrowserPanel
    if (CmpStr(data,name) == 0)         // Is this an HDF5Browser?
        return 1
Function/S HDF5GetIndexedBrowserName(index)
    Variable index
    if (index < 0)
        return ""               // Bad index
    String panelName
    Variable i = 0
    do
        panelName = WinName(i, 64)
        if (strlen(panelName) == 0)
            break
        if (IsHDF5Browser(panelName))       // Is this an HDF5Browser?
            if (index == 0)
                return panelName
            index -= 1
        i += 1
    while(1)
    return ""       // No HDF5 browser with that index
Function/S HDF5GetTopBrowserName()
    String browserName = HDF5GetIndexedBrowserName(0)
    return browserName
Function HDF5AreAnyBrowsersOpen()
        return 1
// FixCloseHDF5FileButtons()
// If experiment was saved with an HDF5 file open, it is no longer open but the panel's Open
// and Close buttons will be out-of-sync. This fixes that.
static Function FixCloseHDF5FileButtons()
    String browserName
    Variable index = 0
    do
        browserName = HDF5GetIndexedBrowserName(index)
        if (strlen(browserName) == 0)
            break
            FileWasClosed(bd)
        index += 1
    while(1)
static Function AfterFileOpenHook(refNum,file,pathName,type,creator,kind)
    Variable refNum,kind
    String file,pathName,type,creator
    // DoAlert 0, "AfterFileOpenHook"       // For debugging
    switch (kind)
        case 1:                                     // Packed experiment
        case 2:                                     // Unpacked experiment
            FixCloseHDF5FileButtons()       // If experiment was saved with an HDF5 file open, it is no longer open
        break
    endswitch
// ************* Start of HDF5 Browser Display Routines ***************
static Function WaveRank(w)
    Wave w
    Variable dimension
    for(dimension=3; dimension>=0; dimension-=1)
        if (DimSize(w, dimension) > 0)
            return dimension+1
// *** DISPLAY IN DUMP WINDOW ***
Function HDF5BrowserDumpIsVisible() // Returns true if dump window exists and is visible.
                                    // Returns false if it does not exist or is invisible.
    DoWindow  HDF5DumpNotebook
    if (V_flag == 0)
        return 0                    // Does not exist
    String name
    Variable index = 0
    do
        name = WinName(index, 16, 1)
        if (strlen(name) == 0)
            return 0                // Did not find HDF5DumpNotebook among visible notebooks.
        if (CmpStr(name, "HDF5DumpNotebook") == 0)
            return 1                // Found HDF5DumpNotebook among visible notebooks
        index += 1
    while(1)
    return 0                        // This will never execute.
Function HDF5BrowserDumpHook(infoStr)
    String infoStr
    strswitch(event)
            break
        case "resize":
            SetPrefWindowCoords("HDF5DumpNotebook")
            break
    endswitch
Function HDF5CreateDumpWindow()
    if (V_flag == 0)
        GetPrefWindowCoords("HDF5DumpNotebook", left, top, right, bottom)
        if (right > left)                                           // Were prefs ever set?
            NewNotebook /F=0 /N=HDF5DumpNotebook/K=1 /W=(left, top, right, bottom)
            NewNotebook/F=0/N=HDF5DumpNotebook/K=1
        SetWindow HDF5DumpNotebook,hook=HDF5BrowserDumpHook
        if (NumType(FontSizeHeight("Courier New", 12, 0)) == 0)     // Courier New exists?
            Notebook HDF5DumpNotebook font="Courier New", fSize=12
        Notebook HDF5DumpNotebook text="A dump will appear here when you click a dataset.\r"
// CleanupDump(dump)
// Removes nulls, converts \n to CR, etc. Dump of NASA strings can contain lots of such "garbage".
// For an example, see the attribute /StructMetadata.O_GLOSDS in the NASA sample file MISRAERO.h5.
static Function/S CleanupDump(dump)
    String dump
    // Convert literal string "\000" to "". Null characters are represented in dump by "\000"
    dump = ReplaceString("\\000", dump, "", 1)
    // Convert literal string "\r\n" to CR
    dump = ReplaceString("\\r\\n", dump, "\r", 1)
    // Convert literal string "\r" to CR
    dump = ReplaceString("\\r", dump, "\r", 1)
    // Convert literal string "\n" to CR
    dump = ReplaceString("\\n", dump, "\r", 1)
    // Convert literal string "\t" to tab
    dump = ReplaceString("\\t", dump, "\t", 1)
    // Convert CRLF to CR
    dump = ReplaceString("\r\n", dump, "\r", 1)
    // Convert LF to CR
    dump = ReplaceString("\n", dump, "\r", 1)
    return dump
Function HDF5DisplayDumpOfSelectedGroup(bd)
    String path = SelectedGroupPath(bd)
    if (strlen(path) == 0)
        return -1
    ControlInfo /W=$bd.browserName ShowAttributesInDump
    Variable showAttributes = V_value
    HDF5Dump /Q /H=1 /ATTR=(showAttributes) /G=path bd.fullPath                 // This sets S_HDF5Dump.
    S_HDF5Dump = CleanupDump(S_HDF5Dump)
    Notebook HDF5DumpNotebook selection={startOfFile, endOfFile}
    Notebook HDF5DumpNotebook text=S_HDF5Dump
    Notebook HDF5DumpNotebook selection={startOfFile, startOfFile}, findText={"",1}
static Function DisplayDumpOfSelectedDataset(bd)
        return -1
    ControlInfo /W=$bd.browserName ShowDataInDump
    Variable showData = V_value
    HDF5Dump /Q /ATTR=(showAttributes) /H=(!showData) /D=datasetPath bd.fullPath            // This sets S_HDF5Dump.
static Function DisplayDumpOfSelectedAttribute(bd, isGroupAttribute)
    String path = SelectedAttributePath(bd, isGroupAttribute)
        return -1
    HDF5Dump /Q /A=path bd.fullPath                 // This sets S_HDF5Dump.
// *** DISPLAY IN GRAPH ***
Function HDF5BrowserGraphIsVisible()        // Returns true if dump window exists and is visible.
    DoWindow  HDF5BrowserGraph
    if (V_flag == 0)
    // Graphs are always visible so we don't need to check that.
    return 1                        // This will never execute.
Function HDF5BrowserGraphHook(infoStr)
    String infoStr
    strswitch(event)
            break
        case "resize":
            SetPrefWindowCoords("HDF5BrowserGraph")
            break
    endswitch
Function HDF5CreateBrowserGraph()
    if (V_flag == 0)
        GetPrefWindowCoords("HDF5BrowserGraph", left, top, right, bottom)
            Display /K=1 /W=(left, top, right, bottom)
            Display /K=1
        DoWindow/C HDF5BrowserGraph
        SetWindow HDF5BrowserGraph,hook=HDF5BrowserGraphHook
static Function SetImageLayer(ctrlName,varNum,varStr,varName) : SetVariableControl
    String ctrlName
    Variable varNum
    String varStr
    String varName
    NVAR imageLayer = root:Packages:HDF5Browser:imageLayer
    ModifyImage /W=HDF5BrowserGraph BrowserWave, plane=varNum
static Function DisplayGraphOfSelectedData(bd, isAttribute, objectType, listOfWavesLoaded)      // The data is already loaded into waves specified by listOfWavesLoaded
    Variable isAttribute
    Variable objectType             // Host object type of attribute. 1=group, 2=dataset
    String listOfWavesLoaded
    String firstWaveLoaded = StringFromList(0, listOfWavesLoaded)
    Wave browserWave = root:Packages:HDF5Browser:$firstWaveLoaded
    Variable newDataIsText = WaveType(browserWave) == 0
    Variable oldRank = 0, newRank = 0
    if (strlen(TraceNameList("HDF5BrowserGraph", ";", 1)) > 0)
        oldRank = 1
    if (strlen(ImageNameList("HDF5BrowserGraph", ";")) > 0)
        oldRank = 2
    newRank = WaveRank(browserWave) // Will be zero for zero-point wave
    String savedDataFolder = SetBrowserDataFolder("")                   // browserWave goes in master HDF5Browser data folder
    Variable displayedDimensionalityChanged = (oldRank <= 1) != (newRank <= 1)  // Switching between 1D and >1D ?
    Variable index, browserWaveIsDisplayed
    String waveLoaded, nameOfGraphWave
    // Remove any waves in graph not in listOfWavesLoaded or all waves if dimensionality changed
    index = 0
    do
        if (oldRank == 1)
            Wave/Z graphWave = WaveRefIndexed("HDF5BrowserGraph", index, 1)
            if (!WaveExists(graphWave))
                break
            nameOfGraphWave = NameOfWave(graphWave)
            nameOfGraphWave = StringFromList(index, ImageNameList("HDF5BrowserGraph", ";" ))
            if (strlen(nameOfGraphWave) == 0)
                break
        Variable waveIsInListOfLoadedWaves = WhichListItem(nameOfGraphWave, listOfWavesLoaded) >= 0
        if (displayedDimensionalityChanged || !waveIsInListOfLoadedWaves)
            if (oldRank == 1)
                RemoveFromGraph /W=HDF5BrowserGraph $nameOfGraphWave
            if (oldRank > 1)
                RemoveImage /W=HDF5BrowserGraph $nameOfGraphWave
            index -= 1
        if (!waveIsInListOfLoadedWaves)
            KillWaves/Z $nameOfGraphWave
        index += 1
    while(1)
    // Append any waves to graph in listOfWavesLoaded
    index = 0
    do
        waveLoaded = StringFromList(index, listOfWavesLoaded)
        if (strlen(waveLoaded) == 0)
            break
        Wave browserWave = root:Packages:HDF5Browser:$waveLoaded
        Variable browserWaveType = WaveType(browserWave)
        nameOfGraphWave = waveLoaded
        CheckDisplayed /W=HDF5BrowserGraph browserWave
        browserWaveIsDisplayed = V_flag
        if (!newDataIsText)
            if (browserWaveType != 0)               // When loading compound data we can get a mix of numeric and non-numeric.
                if (browserWaveIsDisplayed == 0)
                    if (newRank <= 1)
                        AppendToGraph /W=HDF5BrowserGraph browserWave
                        if (displayedDimensionalityChanged)
                            SetAxis/A left
                        AppendImage /W=HDF5BrowserGraph browserWave
                            SetAxis/A/R left                                    // Reverse left axis like NewImage does.
                if (newRank >= 2)
                    NVAR formalImageType = root:Packages:HDF5Browser:formalImageType
                    switch (formalImageType)                            // browserPalette would be created by HDF5LoadImage
                        case 0:                                             // Not a formal image.
                        case 1:                                             // No palette wave loaded.
                            ModifyImage /W=HDF5BrowserGraph $nameOfGraphWave ctab= {*,*,Grays,0}
                            break
                        case 2:                                             // Palette wave was loaded.
                            Wave browserPalette = root:Packages:HDF5Browser:browserPalette
                            ModifyImage /W=HDF5BrowserGraph $nameOfGraphWave, cindex=browserPalette
                            break
                    endswitch
        if (newDataIsText)                      // Display a snippet of the text wave.
            if (browserWaveType == 0)       // When loading compound data we can get a mix of numeric and non-numeric.
                String text
                Wave/T w = root:Packages:HDF5Browser:$nameOfGraphWave
                if (numpnts(w) > 0)
                    text = CleanupDump(w[0])
                    text = ""
                if ( (strlen(text) > 256) || (numpnts(w)>1) )
                    text = "A snippet of the text:\r\r" + text[0,255]
                TextBox/C/N=browserTextbox/W=HDF5BrowserGraph/A=LT text
            TextBox/K/N=browserTextbox/W=HDF5BrowserGraph
        index += 1
    while(1)
    // Show Image Layer control if displaying a stack of images
    Variable numDims = WaveDims(browserWave)
    Variable isStack = 0
    if (!newDataIsText && newRank>2)
        if (DimSize(browserWave,2) == 3)
            // Igor assumes that this is an RGB wave using direct color.
            if (numDims > 3)
                isStack = 1         // This is a stack of RGB images.
            isStack = 1         // This is a stack of indexed color images.
    if (isStack)
        Variable/G root:Packages:HDF5Browser:imageLayer = 0
        Variable dim, numLayers
        numLayers = 1
        for(dim=2; dim<numDims; dim+=1)
            numLayers *= DimSize(browserWave, dim)
        ControlBar/W=HDF5BrowserGraph 25
        SetVariable ImageLayer win=HDF5BrowserGraph, title="Layer",size={100,20},format="%d"
        SetVariable ImageLayer win=HDF5BrowserGraph, proc=HDF5Browser#SetImageLayer
        SetVariable ImageLayer win=HDF5BrowserGraph, value=imageLayer, limits={0,numLayers-1,1}
        KillControl/W=HDF5BrowserGraph ImageLayer
        ControlBar/W=HDF5BrowserGraph 0
    String title = "HDF5 Preview - "
    if (isAttribute)
        title += SelectedAttributeName(bd, objectType==1)
        title += SelectedDatasetName(bd)
    title = title[0,39]             // Unfortunately titles are limited to 40 characters.
    DoWindow /T HDF5BrowserGraph, title
// *** DISPLAY IN TABLE ***
Function HDF5BrowserTableIsVisible()        // Returns true if dump window exists and is visible.
    DoWindow  HDF5BrowserTable
    if (V_flag == 0)
    // Tables are always visible so we don't need to check that.
Function HDF5BrowserTableHook(infoStr)
    String infoStr
    strswitch(event)
            break
        case "resize":
            SetPrefWindowCoords("HDF5BrowserTable")
            break
    endswitch
Function HDF5CreateBrowserTable()
    if (V_flag == 0)
        GetPrefWindowCoords("HDF5BrowserTable", left, top, right, bottom)
            Edit /K=1 /W=(left, top, right, bottom)
            Edit /K=1
        DoWindow/C HDF5BrowserTable
        SetWindow HDF5BrowserTable,hook=HDF5BrowserTableHook
static Function DisplayTableOfSelectedData(bd, isAttribute, objectType, listOfWavesLoaded)      // The data is already loaded into waves listed by listOfWavesLoaded
    String waveLoaded
    Variable index
    // Remove any waves in table not in listOfWavesLoaded
    index = 0
    do
        Wave/Z tableWave = WaveRefIndexed("HDF5BrowserTable", index, 3)
        if (!WaveExists(tableWave))
            break
        String nameOfTableWave = NameOfWave(tableWave)
        if (WhichListItem(nameOfTableWave, listOfWavesLoaded) < 0)
            RemoveFromTable /W=HDF5BrowserTable tableWave
            KillWaves/Z tableWave
            index -= 1
        index += 1
    while(1)
    // Append any waves to table in listOfWavesLoaded
    index = 0
    do
            break
        CheckDisplayed /W=HDF5BrowserTable browserWave
        if (V_flag == 0)
            AppendToTable /W=HDF5BrowserTable browserWave
        index += 1
    while(1)
    if (isAttribute)
    DoWindow /T HDF5BrowserTable, title
static Function RemoveFromGraphAndTable(w)
    Wave w
    String name = NameOfWave(w)
        CheckDisplayed /W=HDF5BrowserGraph w
        if (V_flag != 0)
            Variable isImage = strlen(ImageNameList("HDF5BrowserGraph", ";")) > 0
            if (isImage)
        CheckDisplayed /W=HDF5BrowserTable w
        if (V_flag != 0)
            RemoveFromTable /W=HDF5BrowserTable w
//  KillConflictingBrowserWaves(new_class_str, enumMode)
//  "Conflicting" means that a wave is text and we are going
// to use the same name to load a numeric wave or vice versa.
// This function removes conflicting waves from the browser graph
// and table and then kills them.
static Function KillConflictingBrowserWaves(new_class_str, enumMode)
    String new_class_str                // Class of data we are about to load.
    Variable enumMode
    String browserDF = "root:Packages:HDF5Browser"
    Variable numWaves = CountObjects(browserDF, 1)
    Variable i
    for(i=0; i<numWaves; i+=1)
        String name = GetIndexedObjName(browserDF, 1, i)
        if (strlen(name)>=11 && CmpStr(name[0,11],"browserWave")==0)    // Is this a browser display wave?
            Wave w = $(browserDF + ":" + name)
            Variable oldDataIsText
            oldDataIsText = WaveType(w) == 0
            newDataIsText = 0
            strswitch(new_class_str)
                case "H5T_STRING":
                    newDataIsText = 1
                    break
                case "H5T_ENUM":
                    if (enumMode == 1)
                        newDataIsText = 1
                    break
                    // If we are loading all members of a compound dataset
                    // at this point we need to know the class of the compound
                    // member corresponding to the current wave. However, this
                    // is very complicated to do and I decided not to attempt it.
                    // The result is that, if we have an existing brower_<member>
                    // wave whose type is string and we try to load a numeric wave
                    // with the same name, HDF5LoadWave will get a "Can't overwrite
                    // text with numeric and vice versa" error.
                    break
            endswitch
            if (newDataIsText != oldDataIsText)
                KillWaves w
                // Printf "Killed %s\r", name
static Function LoadSelectedDataForDisplay(bd, isAttribute, objectType, listOfWavesLoaded, errorMessage)
    String &listOfWavesLoaded       // Output: List of waves loaded.
    String &errorMessage                // Output: Error message or ""
    Variable err = 0
    errorMessage = ""
    Wave/Z browserWave = root:Packages:HDF5Browser:browserWave
    String path
    if (isAttribute)
        if (objectType == 1)
        return -1
    String attributeName = ""
    if (isAttribute)
        attributeName = SelectedAttributeName(bd, objectType==1)
            return -1
    if (isAttribute)
        HDF5AttributeInfo(bd.fileID, path, objectType, attributeName, 0, di)
        HDF5DatasetInfo(bd.fileID, path, 0, di)
    String datatype_class_str = di.datatype_class_str
    InitHDF5DatatypeInfo(dti)                   // Sets input fields.
    Variable isCompound = 0
    Variable compMode = 0
    String memberName = ""
    if (!isAttribute)           // We support viewing members only for datasets, not for attributes.
    if (compMode != 0)          // Are we loading a member of a compound datatype?
        err = HDF5TypeInfo(bd.fileID, path, "", memberName, 1, dti)
        if (err != 0)
            return err
        datatype_class_str = dti.type_class_str
        // If array, we need to know about the base datatype of the array
        if (CmpStr(datatype_class_str, "H5T_ARRAY") == 0)
            if (isAttribute)
                HDF5AttributeInfo(bd.fileID, path, objectType, attributeName, 2, di)        // 2 means get info on base datatype of array
                HDF5DatasetInfo(bd.fileID, path, 2, di) // 2 means get info on base datatype of array
    err = HDF5CheckDataClass(datatype_class_str, errorMessage)
    if (err != 0)
        if (WaveExists(browserWave))
            Redimension/N=(0) browserWave       // Don't leave browserWave around which a user might
        endif                                               // think goes with the selected item in the control panel
        return err
    if (!isAttribute && !isCompound)
        HDF5LoadData /Z /O /N=tempClassAttribute /A="CLASS" /Q /VAR=1 bd.fileID, path
        if (V_flag == 0)
                isFormalImage = 1
    Variable enumMode = 1                       // 0: Load enum into numeric wave; 1: load enum into text wave.
    // If browserWave exists and we are switching from a text wave to a numeric wave
    // or vice-versa then we must remove browserWave from the graph and table and
    // kill it. Otherwise we will get an error when HDF5LoadData tries to overwrite
    // a text wave with numeric or vice versa.
    KillConflictingBrowserWaves(datatype_class_str, enumMode)   // Also removes them from graph and table.
    savedDataFolder = SetBrowserDataFolder("")                  // browser waves go in master HDF5Browser data folder
    if (isFormalImage)
        String browserPaletteName = "browserPalette"
        HDF5LoadImage /O /N=browserWave /PALN=browserPaletteName /Q bd.fileID, path
        Variable/G formalImageType = 1      // Means formal image with no palette
        listOfWavesLoaded = StringFromList(0, S_waveNames)  // We count only the image as loaded, not the palette.
        if (WhichListItem(browserPaletteName, S_waveNames) >= 0)
            formalImageType = 2                 // Means formal image with palette
        KillWaves/Z browserPalette
        // Note that when loading all members of a compound dataset this
        // will create a family of waves named browserWave_<member>.
        // Also when loading a VLEN dataset it will create a family of
        // waves named browserWave<digit>. Otherwise it just creates
        // one wave named browserWave.
        HDF5LoadData /O /IGOR=-1 /N=browserWave /COMP={compMode,memberName} /TRAN=(transpose2D) /A=attributeName /TYPE=(objectType) /ENUM=(enumMode) /SLAB=slabWave /Q /VAR=0 bd.fileID, path
        Variable/G formalImageType = 0      // Not a formal image
        listOfWavesLoaded = S_waveNames
    errorMessage = GetRTErrMessage()
    err = GetRTError(1)
    return err
Function HDF5DisplaySelectedDataset(bd)
    String listOfWavesLoaded = ""
    Variable needToLoadData = HDF5BrowserGraphIsVisible() || HDF5BrowserTableIsVisible()
    if (needToLoadData)
        String errorMessage
        if (LoadSelectedDataForDisplay(bd, 0, 2, listOfWavesLoaded, errorMessage) != 0)
            DoAlert 0, errorMessage
            return -1
        DisplayGraphOfSelectedData(bd, 0, 1, listOfWavesLoaded)
        DisplayTableOfSelectedData(bd, 0, 1, listOfWavesLoaded)
Function HDF5DisplaySelectedAttribute(bd,  isGroupAttribute)
    Variable objectType = isGroupAttribute ? 1:2
    if (needToLoadData)
        String errorMessage
        if (LoadSelectedDataForDisplay(bd, 1, objectType, listOfWavesLoaded, errorMessage))
            return -1
        DisplayGraphOfSelectedData(bd, 1, objectType, listOfWavesLoaded)
        DisplayTableOfSelectedData(bd, 1, objectType, listOfWavesLoaded)
// ************* End of HDF5 Browser Display Routines ***************
// ************* Start of HDF5 Browser Resize Routines ***************
static Function MinWindowSize(winName,minwidth,minheight)
    String winName
    Variable minwidth,minheight
    GetWindow $winName wsize
    Variable width= max(V_right-V_left,minwidth)
    Variable height= max(V_bottom-V_top,minheight)
    MoveWindow/W=$winName V_left, V_top, V_left+width, V_top+height
Function PositionControlRelative(panelName, control, masterControl, xMode, yMode, dx, dy)
    String panelName
    String control, masterControl       // Positions control relative to masterControl.
    Variable xMode      // 0 = relative to master left, 1 = relative to master right, 2 = do not set x position.
    Variable yMode      // 0 = relative to master top, 1 = relative to master bottom, 2 = do not set y position.
    Variable dx, dy
    ControlInfo/W=$panelName $masterControl
    Variable masterLeft = V_left, masterTop = V_top
    Variable masterRight = masterLeft+V_width, masterBottom=masterTop+V_height
    ControlInfo/W=$panelName $control
    Variable controlLeft = V_left, controlTop = V_top
    Variable left, top
    switch(xMode)
        case 0:
            left = masterLeft + dx
            break
        case 1:
            left = masterRight + dx
            break
        case 2:
            left = controlLeft
            break
    endswitch
    switch(yMode)
        case 0:
            top = masterTop + dy
            break
        case 1:
            top = masterBottom + dy
            break
        case 2:
            top = controlTop
            break
    endswitch
    ModifyControl $control, win=$panelName, pos={left, top}
Function OffsetControls(panelName, controlList, dx, dy)
    String panelName
    String controlList  // Semicolon-separated list of control names
    Variable dx, dy
    String name
    Variable index = 0
    do
        name = StringFromList(index, controlList)
            break
        ControlInfo/W=$panelName $name
        ModifyControl $name, win=$panelName, pos={V_left+dx,V_top+dy}
        index += 1
    while(1)
Function HDF5ResizeBrowser(browserName)
    String browserName
    Variable statusCode= 0
    String win = browserName
    GetWindow $browserName wsizeDC
    Variable winLeft=V_left, winTop=V_top, winRight=V_right, winBottom=V_bottom
    Variable winWidth = winRight - winLeft, winHeight = winBottom - winTop
    if (winWidth<600 || winHeight<500)
        return 0                        // Too small.
    // Set preferred browser window size. We would like to also do this
    // when the browser is moved without resizing but we get no message
    // from Igor when a window is moved.
    Variable leftBorder=15, hSpaceBetweenLists=20, rightBorder=15
    Variable listsTop, vSpaceBetweenLists = 30, bottomBorder = 10
    ControlInfo/W=$browserName GroupsList
    listsTop = V_top
    Variable hSpaceForLists = winRight - winLeft - leftBorder - hSpaceBetweenLists - rightBorder
    Variable vSpaceForLists = winBottom - listsTop - vSpaceBetweenLists - bottomBorder
    Variable groupListsWidth = .4 * hSpaceForLists
    Variable datasetListsWidth = .6 * hSpaceForLists
    Variable groupListsHeight = .65 * vSpaceForLists
    Variable attributeListsHeight = .35 * vSpaceForLists
    Variable left, top
    // Set Groups list coordinates
    left = leftBorder
    top = listsTop
    ListBox GroupsList, win=$browserName, pos={left, top}, size={groupListsWidth, groupListsHeight}
    // Set Group Attributes list coordinates
    left = leftBorder
    top = listsTop + groupListsHeight + vSpaceBetweenLists
    ListBox GroupAttributesList, win=$browserName, pos={left, top}, size={groupListsWidth, attributeListsHeight}
    top -= 20
    TitleBox GroupAttributesTitle, win=$browserName, pos={left, top}
    // Remember where DatasetsList is. it is used to position other control.
    ControlInfo/W=$browserName DatasetsList
    Variable oldDatasetsListRight = V_Left + V_Width
    // Set Datasets list coordinates
    left = leftBorder + groupListsWidth + hSpaceBetweenLists
    top = listsTop
    ListBox DatasetsList, win=$browserName, pos={left, top}, size={datasetListsWidth, groupListsHeight}
    // Determine how DatasetsList right edge changed. This is used to position other control.
    Variable changeInDatsetsListRight = (V_Left + V_Width) - oldDatasetsListRight
    // Set Datasets Title
    top -= 20
    TitleBox DatasetsTitle, win=$browserName, pos={left, top}
    // Set Load Dataset Button
    PositionControlRelative(browserName, "LoadDataset", "DatasetsTitle", 1, 2, 20, 0)
    // Set Save Waves Button
    PositionControlRelative(browserName, "SaveWaves", "LoadDataset", 1, 2, 20, 0)
    // Set Members popup menu
    PositionControlRelative(browserName, "Members", "DatasetsTitle", 0, 2, 0, 0)
    // Set Dataset Attributes list coordinates
    ListBox DatasetAttributesList, win=$browserName, pos={left, top}, size={datasetListsWidth, attributeListsHeight}
    top -= 20
    TitleBox DatasetAttributesTitle, win=$browserName, pos={left, top}
    // Set Preview Options
    String list = "PreviewOptions;Graph;Table;Dump;ShowAttributesInDump;ShowDataInDump;"
    OffsetControls(browserName, list, changeInDatsetsListRight, 0)
    // Set Load Dataset Options
    list = "LoadDatasetOptions;DisplayInTable;DisplayInGraph;"
    statusCode=1
    return statusCode   // 0 if nothing done, else 1 or 2
// ************* End of HDF5 Browser Resize Routines ***************
// ************* Start of HDF5 Browser Prefs Routines ***************
// HDF5 Browser preferences are stored on disk in the Packages directory
// in Igor's preferences directory. They are temporarily loaded into an
// HDF5BrowserPrefs data structure but are not stored permanently in memory.
// When a preference value has to be changed, the prefs data structure
// is loaded into memory, the value is changed and the data structure is
// immediately written back out to disk.
// To see where prefs data is changed, search for HDF5BrowserSavePackagePrefs.
static StrConstant kPackageName = "HDF5Browser" // NOTE: Package name must be distinctive!
static Constant kCurrentPrefsVersion = 100          // Changes to hundreds digit means incompatible prefs
static StrConstant kPrefFileName = "Preferences.bin"
static Constant kPrefRecordID = 0
Structure HDF5BrowserPrefs
    uint32 prefsVersion         // Preferences structure version number. 100 means 1.00.
    // Preview graph location in points. 0 means default.
    float graphLeft
    float graphTop
    float graphRight
    float graphBottom
    // Preview table location in points. 0 means default.
    float tableLeft
    float tableTop
    float tableRight
    float tableBottom
    // Dump notebook location in points. 0 means default.
    float dumpLeft
    float dumpTop
    float dumpRight
    float dumpBottom
    // Save Waves and Save Data Folder panel location in pixels. 0 means default.
    float savePanelLeft
    float savePanelTop
    float savePanelRight
    float savePanelBottom
    // HDF5 browser location in points. 0 means default.
    float browserLeft
    float browserTop
    float browserRight
    float browserBottom
    // Overall prefs
    uchar readOnly                      // Open file read only
    uchar reservedOverall[15]
    // Load prefs
    uchar loadGroupsRecursively     // Controls Load Group button
    uchar transpose2DDatasets       // Controls Load Dataset and Load Group buttons
    uchar reservedLoad[14]
    // Save prefs
    uchar saveGroupsRecursively     // Affects Save Data Folder
    uchar includeIgorAttributes     // Affects Save Waves and Save Data Folder
    uchar reservedSave[14]
    uint32 reserved[100]    // Reserved for future use
EndStructure
Function HDF5BrowserLoadPackagePrefs(prefs)
    STRUCT HDF5BrowserPrefs &prefs
    Variable i
    // This loads preferences from disk if they exist on disk.
    LoadPackagePreferences kPackageName, kPrefFileName, kPrefRecordID, prefs
    // If prefs not loaded or not valid, initialize them.
    if (V_flag!=0 || prefs.prefsVersion!=kCurrentPrefsVersion)
        prefs.prefsVersion = kCurrentPrefsVersion
        prefs.graphLeft = 0
        prefs.graphTop = 0
        prefs.graphRight = 0
        prefs.graphBottom = 0
        prefs.tableLeft = 0
        prefs.tableTop = 0
        prefs.tableRight = 0
        prefs.tableBottom = 0
        prefs.dumpLeft = 0
        prefs.dumpTop = 0
        prefs.dumpRight = 0
        prefs.dumpBottom = 0
        prefs.savePanelLeft = 0
        prefs.savePanelTop = 0
        prefs.savePanelRight = 0
        prefs.savePanelBottom = 0
        prefs.browserLeft = 0
        prefs.browserTop = 0
        prefs.browserRight = 0
        prefs.browserBottom = 0
        // Overall prefs
        prefs.readOnly = 1
        for(i=0; i<15; i+=1)
            prefs.reservedOverall[i] = 0
        // Load prefs
        prefs.loadGroupsRecursively = 1
        prefs.transpose2DDatasets = 0
        for(i=0; i<14; i+=1)
            prefs.reservedLoad[i] = 0
        // Save prefs
        prefs.saveGroupsRecursively = 1
        prefs.includeIgorAttributes = 1
            prefs.reservedSave[i] = 0
        for(i=0; i<100; i+=1)
            prefs.reserved[i] = 0
        HDF5BrowserSavePackagePrefs(prefs)      // Create default prefs file.
Function HDF5BrowserSavePackagePrefs(prefs)
    SavePackagePreferences kPackageName, kPrefFileName, kPrefRecordID, prefs
static Function GetPrefWindowCoords(windowName, left, top, right, bottom)
    String windowName
    Variable &left, &top, &right, &bottom
    strswitch(windowName)
        case "HDF5BrowserGraph":
            left = prefs.graphLeft
            top = prefs.graphTop
            right = prefs.graphRight
            bottom = prefs.graphBottom
            break
        case "HDF5BrowserTable":
            left = prefs.tableLeft
            top = prefs.tableTop
            right = prefs.tableRight
            bottom = prefs.tableBottom
            break
        case "HDF5DumpNotebook":
            left = prefs.dumpLeft
            top = prefs.dumpTop
            right = prefs.dumpRight
            bottom = prefs.dumpBottom
            break
        case "HDF5SaveWavesPanel":
        case "HDF5SaveDataFolderPanel":
            left = prefs.savePanelLeft
            top = prefs.savePanelTop
            right = prefs.savePanelRight
            bottom = prefs.savePanelBottom
            break
        default:        // We want to get preferred coords for a new HDF5 browser.
            left = prefs.browserLeft
            top = prefs.browserTop
            right = prefs.browserRight
            bottom = prefs.browserBottom
            break
    endswitch
#if (Exists("PanelResolution") != 3)                // Igor7 has a PanelResolution function that Igor6 lacks
Static Function PanelResolution(wName)          // For compatibility with Igor 7
    String wName
    return 72
#endif
static Function SetPrefWindowCoords(windowName)
    String windowName
    GetWindow $windowName wSize
    // NewPanel uses device coordinates. We therefore need to scale from
    // points (returned by GetWindow) to device units for windows created
    // by NewPanel.
    Variable scale = PanelResolution(windowName) / 72
            prefs.graphLeft = V_Left
            prefs.graphTop = V_Top
            prefs.graphRight = V_Right
            prefs.graphBottom = V_Bottom
            break
            prefs.tableLeft = V_left
            prefs.tableTop = V_top
            prefs.tableRight = V_Right
            prefs.tableBottom = V_Bottom
            break
            prefs.dumpLeft = V_left
            prefs.dumpTop = V_top
            prefs.dumpRight = V_Right
            prefs.dumpBottom = V_Bottom
            break
            prefs.savePanelLeft = V_left * scale
            prefs.savePanelTop = V_top * scale
            prefs.savePanelRight = V_Right * scale
            prefs.savePanelBottom = V_Bottom * scale
            break
        default:        // We want to set preferred coords for a new HDF5 browser.
            prefs.browserLeft = V_left * scale
            prefs.browserTop = V_top * scale
            prefs.browserRight = V_Right * scale
            prefs.browserBottom = V_Bottom * scale
            break
    endswitch
static Function GetPrefBrowserSettings(readOnly, loadGroupsRecursively, transpose2DDatasets)
    Variable &readOnly
    Variable &loadGroupsRecursively
    Variable &transpose2DDatasets
    readOnly = prefs.readOnly
    loadGroupsRecursively = prefs.loadGroupsRecursively
    transpose2DDatasets = prefs.transpose2DDatasets
// ************* End of HDF5 Browser Prefs Routines ***************
// ************* Start of HDF5 Utility Routines ***************
Function HDF5CheckDataClass(dataClassStr, errorMessage)
    String dataClassStr
    Variable err = 0
    errorMessage = ""
    strswitch(dataClassStr)
        case "H5T_TIME":
            errorMessage = "HDF5XOP does not support data of class H5T_TIME."
            err = -1
            break
    endswitch
    return err
Function HDF5MakeHyperslabWave(path, numRows)
    String path         // Path to wave. e.g., "root:slab"
    Variable numRows
    Make /O /N=(numRows,4) $path
    Wave slab = $path
    slab = 1                                // Set all elements to 1.
    Variable row
    String dimLabel
    for(row=0; row<numRows; row+=1)
        sprintf dimLabel, "Dimension %d", row       // HR, 060206: Fixed setting of row dimension labels.
        SetDimLabel 0, row, $dimLabel, slab
    SetDimLabel 1, 0, Start, slab
    SetDimLabel 1, 1, Stride, slab
    SetDimLabel 1, 2, Count, slab
    SetDimLabel 1, 3, Block, slab
Constant kHDF5DataInfoVersion = 1000        // 1000 means 1.000.
Structure HDF5DataInfo                      // Use with HDF5DatasetInfo and HDF5AttributeInfo functions
    // Input fields (inputs to HDF5 XOP)
    uint32 version                          // Must be set to kHDF5DataInfoVersion
    char structName[16]                 // Must be "HDF5DataInfo".
    // Output fields (outputs from HDF5 XOP)
    double datatype_class;                  // e.g., H5T_INTEGER, H5T_FLOAT.
    char datatype_class_str[32];            // String with class spelled out. e.g., "H5T_INTEGER", "H5T_FLOAT".
    double datatype_size;                   // Size in bytes of one element.
    double datatype_sign;                   // H5T_SGN_NONE (unsigned), H5T_SGN_2 (signed), H5T_SGN_ERROR (this type does not have a sign, i.e., it is not an integer type).
    double datatype_order;                  // H5T_ORDER_LE, H5T_ORDER_BE, H5T_ORDER_VAX
    char datatype_str[64];                  // Human-readable string, e.g., "16-bit unsigned integer"
    double dataspace_type;                  // H5S_NO_CLASS, H5S_SCALAR, H5S_SIMPLE
    double ndims;                           // Zero for H5S_SCALAR. Number of dimensions in the dataset for H5S_SIMPLE.
    double dims[H5S_MAX_RANK];          // Size of each dimension.
    double maxdims[H5S_MAX_RANK];       // Maximum size of each dimension.
EndStructure
Function InitHDF5DataInfo(di)               // Sets input fields.
    // HDF5XOP uses these fields to make sure the structure passed in to it is compatible.
    di.version = kHDF5DataInfoVersion
    di.structName = "HDF5DataInfo"
//  HDF5DatasetRank(locationID, name)
//  Returns rank or zero in event of error.
Function HDF5DatasetRank(locationID, name)
    Variable locationID
    String name
    Variable err = HDF5DatasetInfo(locationID, name, 1, di)
    if (err != 0)
    return rank
//  HDF5AttributeRank(locationID, name)
Function HDF5AttributeRank(locationID, objectName, objectType, attributeName)
    Variable locationID
    String objectName
    Variable objectType
    Variable err = HDF5AttributeInfo(locationID, objectName, objectType, attributeName, 1, di)
    if (err != 0)
    Variable rank = di.ndims
    return rank
Constant kHDF5DatatypeInfoVersion = 1000        // 1000 means 1.000.
Structure  HDF5DatatypeInfo                         // Use with HDF5TypeInfo functions
    uint32 version                  // Structure version. Used for backward compatibility.
    char structName[32]         // Must be "HDF5DatatypeInfo". Used to prevent passing wrong structure to XFUNC.
    double type_class               // e.g., H5T_INTEGER, H5T_FLOAT.
    char type_class_str[32]         // String with class spelled out. e.g., "H5T_INTEGER", "H5T_FLOAT".
    double size                     // Size in bytes of one element.
    double sign                     // H5T_SGN_NONE (unsigned), H5T_SGN_2 (signed), H5T_SGN_ERROR (this type does not have a sign, i.e., it is not an integer type).
    double order                    // H5T_ORDER_LE, H5T_ORDER_BE, H5T_ORDER_VAX, H5T_ORDER_ERROR (this type does not have an order).
    double cset                     // H5T_CSET_ASCII, H5T_CSET_UTF8, H5T_CSET_ERROR
    double strpad                   // H5T_str_t: H5T_STR_ERROR, H5T_STR_NULLTERM, H5T_STR_NULLPAD, H5T_STR_SPACEPAD
    double nmembers             // For enum or compound datatypes only, number of members.
    String names                    // For enum or compound datatypes only, semicolon-separated list of enum names.
    int32 values[100]               // For enum datatype only, list of enum values. For compound datatype, list of classes.
    String opaque_tag               // For opaque datatypes only, tag name.
EndStructure
Function InitHDF5DatatypeInfo(dti)          // Sets input fields.
    STRUCT HDF5DatatypeInfo &dti
    dti.version = kHDF5DatatypeInfoVersion
    dti.structName = "HDF5DatatypeInfo"
// ************* End of HDF5 Utility Routines ***************
// ************* Start of HDF5 Save Routines ***************
static Function StringsAreEqual(str1, str2) // Case sensitive
    String str1, str2
    Variable len1=strlen(str1), len2=strlen(str2)
    if (len1 != len2)
    Variable i
    for(i=0; i<len1; i+=1)
        if (char2num(str1[i]) != char2num(str2[i]))
    return 1
static Function/S GetUnquotedLeafName(path)
    String path         // Path to data folder or wave
    String name
    name = ParseFilePath(0, path, ":", 1, 0)        // Just the name without path.
    // Remove single quotes if present
    if (CmpStr(name[0],"'") == 0)
        Variable len = strlen(name)
        name = name[1,len-2]
    return name
static Function HaveObjectNameConflict(listOfObjectsInGroup, listOfObjectsToBeSaved, conflictingObjectName)
    String listOfObjectsInGroup         // Semicolon-separated list of all types of objects in selected group or list of datasets in selected group.
    String listOfObjectsToBeSaved       // Semicolon-separated list of names of objects about to be saved in the HDF5 file.
    String &conflictingObjectName
    conflictingObjectName = ""
    Variable i, j
    Variable numObjectsInList, numObjectsToBeSaved
    numObjectsInList = ItemsInList(listOfObjectsInGroup)
    numObjectsToBeSaved = ItemsInList(listOfObjectsToBeSaved)
    for(i=0; i<numObjectsToBeSaved; i+=1)
        String objectToBeSavedName = StringFromList(i, listOfObjectsToBeSaved)
        objectToBeSavedName = GetUnquotedLeafName(objectToBeSavedName)      // Just the name without path.
        if (CmpStr(objectToBeSavedName, "root") == 0)
            objectToBeSavedName = IgorInfo(1)       // Use name of current experiment instead of "root".
        for(j=0; j<numObjectsInList; j+=1)
            String groupObjectName = StringFromList(j, listOfObjectsInGroup)
            if (StringsAreEqual(groupObjectName,objectToBeSavedName))
                conflictingObjectName = groupObjectName
                return 1
static Function SaveButtonProc(ctrlName) : ButtonControl
    String ctrlName
    String panelName = WinName(0, 64)
    String message
    String list = WS_SelectedObjectsList(panelName, "SelectorList")
    if (strlen(list) == 0)
        strswitch(panelName)
                DoAlert 0, "You must select one or more waves to save first."
                break
                DoAlert 0, "You must select a data folder to save first."
                break
        endswitch
        return -1
        return -1                               // HDF5 Browser was killed.
    SetHDF5BrowserData(browserName, bd)
    // Get list of all types of objects in the selected group (including named datasets and links)
    HDF5ListGroup /TYPE=15 bd.fileID, bd.groupPath
    String listOfObjectsInSelectedGroup = S_HDF5ListGroup
    Variable haveConflict
    String conflictingObjectName
    haveConflict = HaveObjectNameConflict(listOfObjectsInSelectedGroup,list,conflictingObjectName)
    if (haveConflict)
        sprintf message, "The name '%s' is in use.\r\rOverwrite objects with conflicting names?", conflictingObjectName
        DoAlert 1, message
        if (V_flag != 1)
            return -1
    ControlInfo /W=$panelName IncludeIgorAttributes
    Variable igorAttributesMask = V_value ? -1 : 0
    Variable varMode = V_value ? 1 : 0
    String groupPath = SelectedGroupPath(bd)    // Currently selected group
    String newGroupPath = ""                            // Name of group we created, if any.
    Variable index = 0
    do
        String item = StringFromList(index, list)
        if (strlen(item) == 0)
            break                                   // No more waves
                Wave w = $item
                String datasetPath = HDF5GetObjectFullPath(groupPath, NameOfWave(w))
                HDF5SaveData /IGOR=(igorAttributesMask) /O w, bd.fileID, datasetPath
                break
                String dfName = ParseFilePath(0, item, ":", 1, 0)       // Just the data folder name without path.
                if (CmpStr(item, "root") == 0)
                    dfName = IgorInfo(1)        // Use name of current experiment instead of "root".
                newGroupPath = HDF5GetObjectFullPath(groupPath, dfName)
                ControlInfo/W=$panelName SaveGroupsRecursively
                if (V_value)
                    HDF5SaveGroup /IGOR=(igorAttributesMask) /VAR=(varMode) /O /R /T=dfName $item, bd.fileID, groupPath
                    HDF5SaveGroup /IGOR=(igorAttributesMask) /VAR=(varMode) /O /T=dfName $item, bd.fileID, groupPath
                break
        endswitch
        if (V_flag != 0)
            break                                   // Save error.
        index += 1
    while(1)
            FillDatasetsList(bd)
            FillDatasetAttributesList(bd)
            SetButtonStates(bd)             // Needed to set Load Dataset button if we go from 0 datasets to >0 datasets.
            break
            if (strlen(newGroupPath) > 0)
                FillLists(bd)
            break
    endswitch
static Function DoneButtonProc(ctrlName) : ButtonControl
    String ctrlName
    DoWindow/K $panelName
static Function GetPrefSavePanelSettings(saveGroupsRecursively, includeIgorAttributes)
    Variable &saveGroupsRecursively
    Variable &includeIgorAttributes
    saveGroupsRecursively = prefs.saveGroupsRecursively
    includeIgorAttributes = prefs.includeIgorAttributes
static Function SetPrefSavePanelSettings(panelName)
    String panelName
            ControlInfo/W=$panelName IncludeIgorAttributes
            prefs.includeIgorAttributes = V_value
            break
            prefs.saveGroupsRecursively = V_value
            break
    endswitch
static Function SetSaveButtonState(panelName)
    String panelName
    String selection = WS_SelectedObjectsList(panelName, "SelectorList")
    Variable code = strlen(selection) > 0 ? 0:2
    Button Save, win=$panelName, disable=code
Function HDF5SaveWavesPanelHook(infoStr)
    String infoStr
    String panelName = "HDF5SaveWavesPanel"
    strswitch(event)
            break
        case "resize":
            SetPrefWindowCoords(panelName)
            break
    endswitch
Function HDF5SaveDataFolderPanelHook(infoStr)
    String infoStr
    String panelName = "HDF5SaveDataFolderPanel"
    strswitch(event)
            break
        case "resize":
            break
    endswitch
static Function DisplaySaveWavesPanel()
    DoWindow/F $panelName
    if (V_flag == 0)
        GetPrefWindowCoords(panelName, left, top, right, bottom)    // See if prefs set.
            left = 200
            top = 100
            right = 584
            bottom = 632
        Variable recursive, includeIgorAttributes
        GetPrefSavePanelSettings(recursive, includeIgorAttributes)
        Variable showWhat = WMWS_Waves
        NewPanel /W=(left,top,right,bottom) /N=$panelName /K=1 as "Save Waves as HDF5 Datasets"
        TitleBox ListTitle,pos={20,16},size={163,16},title="Select Wave(s) to Save as Datasets"
        TitleBox ListTitle,fSize=14,frame=0,fStyle=1
        ListBox SelectorList,pos={16,48},size={350,390},mode=4  // Multiple disjoint selection allowed.
        MakeListIntoWaveSelector(panelName, "SelectorList", content=showWhat)
        WS_SetNotificationProc(panelName, "SelectorList", "SelectorNotification", isExtendedProc=1)
        Button Save,pos={46,457},size={100,20},proc=HDF5Browser#SaveButtonProc,title="Save"
        Button Done,pos={226,457},size={100,20},proc=HDF5Browser#DoneButtonProc,title="Done"
        CheckBox IncludeIgorAttributes,pos={36,488},size={121,14},title="Include Igor Attributes"
        CheckBox IncludeIgorAttributes,proc=HDF5BrowserPrefCheckboxProc,help={"When checked, attributes are written so that wave properties can be recreated when loading back into Igor."}
        CheckBox IncludeIgorAttributes,value=includeIgorAttributes
        SetWindow kwTopWin,hook=HDF5SaveWavesPanelHook
static Function DisplaySaveDataFolderPanel()
    if (V_flag == 0)
            left = 200
            top = 100
            right = 584
            bottom = 632
        Variable showWhat = WMWS_DataFolders
        NewPanel /W=(left,top,right,bottom) /N=$panelName /K=1 as "Save Data Folder as HDF5 Group"
        TitleBox ListTitle,pos={20,16},size={163,16},title="Select Data Folder to Save as Group"
        ListBox SelectorList,pos={16,48},size={350,390},mode=1      // Single selection only.
        CheckBox SaveGroupsRecursively,pos={44,485},size={66,14},title="Save Groups Recursive",value=recursive
        CheckBox SaveGroupsRecursively,proc=HDF5BrowserPrefCheckboxProc,help={"When checked, sub-data folders are recursively saved."}
        CheckBox IncludeIgorAttributes,pos={44,507},size={121,14},title="Include Igor Attributes"
        SetWindow kwTopWin,hook=HDF5SaveDataFolderPanelHook
Function SelectorNotification(SelectedItem, EventCode, panelName, controlName)
    String SelectedItem
    Variable EventCode
    String panelName
    String controlName
    // Printf "Panel=%s, Control=%s, Event code=%d, selection=\"%s\"\r", panelName, controlName, eventCode, selectedItem
    switch(eventCode)
        case WMWS_DoubleClick:
                break
        case WMWS_FolderOpened:             // Selection is emptied when folder is opened.
        case WMWS_FolderClosed:             // Selection is emptied when folder is opened.
        case WMWS_SelectionChanged:
        case WMWS_SelectionChangedShift:
            break
    endswitch
static Function SaveWavesButtonProc(ctrlName) : ButtonControl
    String ctrlName
    DoWindow/K HDF5SaveDataFolderPanel  // One save panel open at a time.
static Function SaveDataFolderButtonProc(ctrlName) : ButtonControl
    String ctrlName
    DoWindow/K HDF5SaveWavesPanel   // One save panel open at a time.
static Function CloseSavePanels()
static Function HDF5SaveWavesPanelIsVisible()
    DoWindow HDF5SaveWavesPanel
    return V_flag
static Function HDF5SaveDFPanelIsVisible()
    DoWindow HDF5SaveDataFolderPanel
    return V_flag
// ************* End of HDF5 Save Routines ***************
I want to implement it into my own code what are the things that I need to change.
That huge code-dump is WaveMetrics code that ships with Igor.
You have not explained to us what your aim is. Why do you need to change it at all? It's good code, I know the author well and he writes good code.
To improve your chances of getting an answer, here are some tips:
http://stackoverflow.com/help/how-to-ask
dear johnweeks,
I had posted my problems regarding not able to call the HDF5 Load/ Open Group/Load Data due to some simple errors which i had posted previously but due to lack of community support I had to start looking around for my self then I had hit a technical snag and IGOR threw me the Errors iin  the HDF5 Browser code so now i think that i shall change some features of the browser code for my own.
Here is the Link for my previous question:https://www.wavemetrics.com/forum/general/hdf5-issues-when-trying-open-and-load-it-through-program
ps No offense.
Please take no offense in this, but your above post comes over as somewhat aggressive. I would recommend you have a good look at the link John posted. In short:
- You are not explaining what you want to do exactly.
- You are not explaining what 'is not working' for you.
- Instead you just post dumps of code and many posts in a row without the patience to wait for answers.
How do you expect that anybody can help you this way? If you want help, please make everybody's life easier in providing the necessary (and not unnecessary) information to help in the first place. And please note that many users do not get paid and are not ready to answer any question 24/7. I have some experience in programming with HDF5 files and have read your last post. But I saw no way of helping you, short of recreating the type of data you are using and writing a test environment for testing every case what might be wrong without reading your mind. I hope there will be a way to solve your problems, which we are all interested in (and that's what the forum is for).
In reply to by chozo
well I had clearly stated that "I just want to load HDF5 files in IGOR through a computer program written in IGOR" . I never asked for an analysis code so why do I need to post a set of information pertaining to data and recreating testing environment. open and loading a specific type of file consists of every possible case if browser can do it, then HDF5LoadData call,HDF5OpenGroup,HDF5OpenFile shall satisfy the same purpose, isn't it?
ps: no offense.
