In an input dialogue, I have 4 prompts that each uses the pop-up menu option. I need the item number for each. If I save this item number, is it possible to have the popup menu already on this item number the next time I open the input dialogue. I'm thinking something similar to
PopupMenu MyList mode=2
It's a bit annoying to have to reselect everything from the start each time I need the function.
In case you refer to the DoPrompt command, it should be sufficient to set the corresponding variable to the 'default' value (variable, string, or index), see
DoPromptcommand, it should be sufficient to set the corresponding variable to the 'default' value (variable, string, or index), seeHJ
July 1, 2017 at 02:48 pm - Permalink
