Making shortcut for the menu that include sub-menues
Hi, I am trying to make a customized menu.
I have menus with submenues.
I understand how to make a short cut for the submenues, but still I cannot find way to make a shortcut for the menu.
For Instance,
Menu 1
Menu 2
Submenu 2.1
Submenu2.2
In this case, I understand how to make shortcut for menu1 and submenues, but not for Menu2.
Is there any way to make a shortcut for Menu2?
Could you please post a minimal example and OS info (win or mac). I'm not sure whether you are talking about mnemonic keystrokes or accelerators.
HJ
I am using mac and I am trying to customize the menu as follows
menu "My functions"
"Menu1/1", Function1()
Submenu "Submenu1"
"Submenu1-1 /S1", Sub1-1()
"Submenu1-2", Sub1-2()
I would like to add shortcut to "Submenu1" by putting "/2" but it doesn't work
Is there any way to make a shortcut to the submenu?
[quote=HJDrescher]Could you please post a minimal example and OS info (win or mac). I'm not sure whether you are talking about mnemonic keystrokes or accelerators.
HJ[/quote]
As a test I created this code:
menu "My functions"
Submenu "Submenu1"
"Submenu1-1 /S1", Sub1_1()
"Submenu1-2 /S2", Sub1_2()
function function1()
function Sub1_1()
function Sub1_2()
And got the result you requested, I think. See Image.
Menu Test.png (75.48 KB)
Thanks for your input and apology for the confusion.
I meat that can I put the short cut for "submenu1" instead of "submenu1-1" or "Submenu1-2"
[quote=hegedus]Hi,
menu "My functions"
Submenu "Submenu1"
function Sub1_1()
function Sub1_2()
And got the result you requested, I think. See Image.[/quote]
I am not sure that request makes sense from an user interface perspective. The submenu heading does [not] have a function attached to to execute. It serves as an organizational heading.
What action are you going to initiate with a shortcut to a submenu?
I guess you want mnemonic keystrokes: 'alt-y', 's' would open the user defined menu and submenu1 on WINDOWS.
menu "M&y functions"
Submenu "&Submenu1"
function Sub1_1()
function Sub1_2()
To cite the manual:
Note: The mnemonic keystroke is not supported on Macintosh. For this reason, if you care about cross-platform compatibility, you should not use ampersands in your menu items.
On Macintosh, if you use a single ampersand in a menu item, it does not appear in the menu item. If you use a double-ampersand, it appears as a single ampersand.
@WM: Igor8 ?
HJ
I am trying to make a more convenient Interface by selecting menus by shortcuts to enable to choose the submenus.
[quote=hegedus]I am not sure that request makes sense from an user interface perspective. The submenu heading does [not] have a function attached to to execute. It serves as an organizational heading.
Andy[/quote]
Thanks! This is what I want to make, but sadly it seems not to be available in Mac...
Thank you so much otherwise I may keep trying to find some way...
[quote=HJDrescher]I guess you want mnemonic keystrokes: 'alt-y', 's' would open the user defined menu and submenu1 on WINDOWS.
Submenu "&Submenu1"
function Sub1_1()
function Sub1_2()
To cite the manual:
@WM: Igor8 ?
HJ[/quote]
