Image Rotate
pczjrh
Why can't I use this format for rotating a bunch of images by the same angle
Function RotateLotsOfImages(wave1,wave2,...) Wave wave1,wave2 Variable Angle prompt Angle, "Angle of rotation: " doPrompt "Image Rotate" if (V_Flag) return -1 endif ImageRotate/A=Angle/E=0 wave1 Duplicate/O M_RotatedImage wave1 ImageRotate/A=Angle/E=0 wave2 Duplicate/O M_RotatedImage wave2 ... end Function
I have tried converting the variable to a number with str2num(Angle), but that doesn't work. The help file for ImageRotate doesn't give much help on this one.
Thanks for the help,
Jason.
there is no need to use
str2num
here, because 'angle' is already a number. Also theDuplicate
operation is redundant, use the /O flag instead:January 20, 2010 at 07:13 am - Permalink
Thanks very much for the help.
Best Wishes,
Jason.
January 20, 2010 at 08:12 am - Permalink
January 22, 2010 at 10:23 am - Permalink
