Use of Hold in DoNewGlobalFit
I've included the full code in case anyone wants to utilize it...it's a bit long, but it should be straightforward for anyone familiar with the DoNewGlobalFit functionality.
This function is not utilizing the hold functionality like I thought...when I use print getdimlabel(coefwave,1,-1), though, it returns Hold. The fit functions are included at the bottom. They might have a typo...I was trying to use hold to test them.
function ngf(base0,base1,templist,cfstr0,cfvar0,cfstr1,cfvar1,cfstr2,cfvar2,cfstr3,cfvar3,cfstr4,cfvar4)
// base0 and base1 are the basenames of the two data sets (without temperature)
string base0, base1, templist
string cfstr0
variable cfvar0
string cfstr1
variable cfvar1
string cfstr2
variable cfvar2
string cfstr3
variable cfvar3
string cfstr4
variable cfvar4
variable i, numdatapts
// name of data
    make/o/n=(2,2)/t datasets
    DataSets[0][0]=base0+"_"+stringfromlist(i,templist)
    DataSets[1][0]=base1+"_"+stringfromlist(i,templist)
    DataSets[0][1]="_calculated_"
    DataSets[1][1]="_calculated_"
// extract number of points in data wave
wave sampledataset = $datasets[0][0]
numdatapts = numpnts(sampledataset)
// format: [row][column]
// a row for each data set
// # columns: (max # of coefficients used by any fit functions) + 4
    make/o/n=(2,8) CoefDataSetLinkage
// fit functions
    make/o/t/n=2 fitfuncnames
    fitfuncnames[0]="sigma1ff"
    fitfuncnames[1]="eps1ff"
// column 0: contains index in the fitfuncnames where the name of a fitting function will be found
    CoefDataSetLinkage[0][0]=0
// column 1: point # within concatenated data set where this data set begins
    CoefDataSetLinkage[0][1]=0
// column 2: point # where a given data set ends (this number is not used...)
    CoefDataSetLinkage[0][2]=numdatapts-1
// column 3: how many fit coefficents are used by the fit function for the corresponding data set
    CoefDataSetLinkage[0][3]=4
// column 4: index to the master coefficient wave
    CoefDataSetLinkage[0][4]=0
    CoefDataSetLinkage[0][5]=1
    CoefDataSetLinkage[0][6]=2
    CoefDataSetLinkage[0][7]=3
    CoefDataSetLinkage[1][0]=0
    CoefDataSetLinkage[1][1]=numdatapts
    CoefDataSetLinkage[1][2]=2*numdatapts-1
    CoefDataSetLinkage[1][3]=4
    CoefDataSetLinkage[1][4]=4
    CoefDataSetLinkage[1][5]=1
    CoefDataSetLinkage[1][6]=2
    CoefDataSetLinkage[1][7]=3
// coefwave contains initial guesses
// inidices established in coefdatasetlinkage are repeated here
// i.e. the length of coefwave will be the total number of variables, not just the number
// used by any particular fit function
    make/o/n=(5,2) coefwave
    setdimlabel 1, -1, Hold, coefwave
    coefwave[0][0]=cfvar0
    coefwave[1][0]=cfvar1
    coefwave[2][0]=cfvar2
    coefwave[3][0]=cfvar3
    coefwave[4][0]=cfvar4
// set coefwave[n][1]=0 to not hold n, 1 to hold n
    coefwave[][1]=1
// coefnames provides strings for the variable names
// same index convention as coefwave and coefdatasetlinkage
    make/o/t/n=5 coefnames
    coefnames[0]=cfstr0
    coefnames[1]=cfstr1
    coefnames[2]=cfstr2
    coefnames[3]=cfstr3
    coefnames[4]=cfstr4
donewglobalfit(FitFuncNames, DataSets, CoefDataSetLinkage, CoefWave, CoefNames, $"",NewGFOptionAPPEND_RESULTS, 200, 1)
function eps1ff(w,x) : FitFunc
    wave w
    variable x
    //CurveFitDialog/ x
    //CurveFitDialog/ Coefficients 4
    //CurveFitDialog/ w[0] = eps_inf
    //CurveFitDialog/ w[1] = sj1
    //CurveFitDialog/ w[2] = fj1
    //CurveFitDialog/ w[3] = gj1
//  return real(8.854*4*pi*2*pi*x*(w[0]-1+w[1]*(2*pi*w[2])^2 / ((2*pi*w[2])^2-(2*pi*x)^2-sqrt(-1)*w[3]*x*(2*pi)^2)+ w[4]*(2*pi*w[5])^2 / ((2*pi*w[5])^2-(2*pi*x)^2-sqrt(-1)*w[6]*x*(2*pi)^2)  )  / (100*4* pi * sqrt(-1)))
       return real(w[0]-1+w[1]*(2*pi*w[2])^2 / ((2*pi*w[2])^2-(2*pi*x)^2-sqrt(-1)*w[3]*x*(2*pi)^2))
function sigma1ff(w,x) : FitFunc
    wave w
    variable x
    //CurveFitDialog/ x
    //CurveFitDialog/ w[0] = sigma0
    return real( 8.854*4*pi*2*pi*x *(w[0]+w[1]*(2*pi*w[2])^2 / ((2*pi*w[2])^2-(2*pi*x)^2-sqrt(-1)*w[3]*x*(2*pi)^2)))
I think I solved my problem...it was due to a misinterpretation of "dimindex" in setdimlabel.
I realized I hadn't identified the column I wanted, but labeled used Hold as a dimlabel for all columns. Donewglobalfit probably pulled the first column, saw that none of the numbers were 1, and didn't hold anything. I replaced the setdimlabel line as:
setdimlabel 1, 1, Hold, coefwave
great!
I did not use DoNewGlobalFit in past. So I find it very interesting when I get to know it.
After reading the whole help document about DoNewGlobalFit I understand what id dones.
Now what makes me puzzled is how the global parameters are linked!
Is it fitted in the first data and then holded as constant for other data?
Thanks
Global Fit combines all your data sets into one big one, then runs your fit functions with appropriate subsets of the coefficients. When making those subsets, any global coefficients are used over again for each data/ fit function combination, so that only one coefficient is fitted.
