Use of Hold in DoNewGlobalFit
This function is not utilizing the hold functionality like I thought...when I use print getdimlabel(coefwave,1,-1), though, it returns Hold. The fit functions are included at the bottom. They might have a typo...I was trying to use hold to test them.
function ngf(base0,base1,templist,cfstr0,cfvar0,cfstr1,cfvar1,cfstr2,cfvar2,cfstr3,cfvar3,cfstr4,cfvar4) // base0 and base1 are the basenames of the two data sets (without temperature) string base0, base1, templist string cfstr0 variable cfvar0 string cfstr1 variable cfvar1 string cfstr2 variable cfvar2 string cfstr3 variable cfvar3 string cfstr4 variable cfvar4 variable i, numdatapts // name of data make/o/n=(2,2)/t datasets DataSets[0][0]=base0+"_"+stringfromlist(i,templist) DataSets[1][0]=base1+"_"+stringfromlist(i,templist) DataSets[0][1]="_calculated_" DataSets[1][1]="_calculated_" // extract number of points in data wave wave sampledataset = $datasets[0][0] numdatapts = numpnts(sampledataset) // format: [row][column] // a row for each data set // # columns: (max # of coefficients used by any fit functions) + 4 make/o/n=(2,8) CoefDataSetLinkage // fit functions make/o/t/n=2 fitfuncnames fitfuncnames[0]="sigma1ff" fitfuncnames[1]="eps1ff" // column 0: contains index in the fitfuncnames where the name of a fitting function will be found CoefDataSetLinkage[0][0]=0 // column 1: point # within concatenated data set where this data set begins CoefDataSetLinkage[0][1]=0 // column 2: point # where a given data set ends (this number is not used...) CoefDataSetLinkage[0][2]=numdatapts-1 // column 3: how many fit coefficents are used by the fit function for the corresponding data set CoefDataSetLinkage[0][3]=4 // column 4: index to the master coefficient wave CoefDataSetLinkage[0][4]=0 CoefDataSetLinkage[0][5]=1 CoefDataSetLinkage[0][6]=2 CoefDataSetLinkage[0][7]=3 // column 0: contains index in the fitfuncnames where the name of a fitting function will be found CoefDataSetLinkage[1][0]=0 // column 1: point # within concatenated data set where this data set begins CoefDataSetLinkage[1][1]=numdatapts // column 2: point # where a given data set ends (this number is not used...) CoefDataSetLinkage[1][2]=2*numdatapts-1 // column 3: how many fit coefficents are used by the fit function for the corresponding data set CoefDataSetLinkage[1][3]=4 // column 4: index to the master coefficient wave CoefDataSetLinkage[1][4]=4 CoefDataSetLinkage[1][5]=1 CoefDataSetLinkage[1][6]=2 CoefDataSetLinkage[1][7]=3 // coefwave contains initial guesses // inidices established in coefdatasetlinkage are repeated here // i.e. the length of coefwave will be the total number of variables, not just the number // used by any particular fit function make/o/n=(5,2) coefwave setdimlabel 1, -1, Hold, coefwave coefwave[0][0]=cfvar0 coefwave[1][0]=cfvar1 coefwave[2][0]=cfvar2 coefwave[3][0]=cfvar3 coefwave[4][0]=cfvar4 // set coefwave[n][1]=0 to not hold n, 1 to hold n coefwave[][1]=1 // coefnames provides strings for the variable names // same index convention as coefwave and coefdatasetlinkage make/o/t/n=5 coefnames coefnames[0]=cfstr0 coefnames[1]=cfstr1 coefnames[2]=cfstr2 coefnames[3]=cfstr3 coefnames[4]=cfstr4 donewglobalfit(FitFuncNames, DataSets, CoefDataSetLinkage, CoefWave, CoefNames, $"",NewGFOptionAPPEND_RESULTS, 200, 1) end function eps1ff(w,x) : FitFunc wave w variable x //CurveFitDialog/ These comments were created by the Curve Fitting dialog. Altering them will //CurveFitDialog/ make the function less convenient to work with in the Curve Fitting dialog. //CurveFitDialog/ Independent Variables 1 //CurveFitDialog/ x //CurveFitDialog/ Coefficients 4 //CurveFitDialog/ w[0] = eps_inf //CurveFitDialog/ w[1] = sj1 //CurveFitDialog/ w[2] = fj1 //CurveFitDialog/ w[3] = gj1 // return real(8.854*4*pi*2*pi*x*(w[0]-1+w[1]*(2*pi*w[2])^2 / ((2*pi*w[2])^2-(2*pi*x)^2-sqrt(-1)*w[3]*x*(2*pi)^2)+ w[4]*(2*pi*w[5])^2 / ((2*pi*w[5])^2-(2*pi*x)^2-sqrt(-1)*w[6]*x*(2*pi)^2) ) / (100*4* pi * sqrt(-1))) return real(w[0]-1+w[1]*(2*pi*w[2])^2 / ((2*pi*w[2])^2-(2*pi*x)^2-sqrt(-1)*w[3]*x*(2*pi)^2)) end function sigma1ff(w,x) : FitFunc wave w variable x //CurveFitDialog/ These comments were created by the Curve Fitting dialog. Altering them will //CurveFitDialog/ make the function less convenient to work with in the Curve Fitting dialog. //CurveFitDialog/ Independent Variables 1 //CurveFitDialog/ x //CurveFitDialog/ Coefficients 4 //CurveFitDialog/ w[0] = sigma0 //CurveFitDialog/ w[1] = sj1 //CurveFitDialog/ w[2] = fj1 //CurveFitDialog/ w[3] = gj1 return real( 8.854*4*pi*2*pi*x *(w[0]+w[1]*(2*pi*w[2])^2 / ((2*pi*w[2])^2-(2*pi*x)^2-sqrt(-1)*w[3]*x*(2*pi)^2))) end
I realized I hadn't identified the column I wanted, but labeled used Hold as a dimlabel for all columns. Donewglobalfit probably pulled the first column, saw that none of the numbers were 1, and didn't hold anything. I replaced the setdimlabel line as:
March 29, 2017 at 11:39 am - Permalink
I did not use DoNewGlobalFit in past. So I find it very interesting when I get to know it.
After reading the whole help document about DoNewGlobalFit I understand what id dones.
Now what makes me puzzled is how the global parameters are linked!
Is it fitted in the first data and then holded as constant for other data?
Thanks
March 30, 2017 at 04:06 am - Permalink
March 30, 2017 at 04:36 pm - Permalink
