Particle Analysis Problem
I have two waves
Wave: ZD
Type: Double Float 64 bit
Rows: 960 Start: 0 Delta: 0.258 Units:
Columns: 1281 Start: 0 Delta: 0.258 Units:
Wave: TipROI
Type: Unsigned Byte 8 bit
I have used copy commands to get the following and renamed the input and ROI wave.
When I run this it produces
Wave: M_ImageThresh
But the type is double instead of binary which causes the Image AnalyzeParticles to throw an error because of the wrong type. I commented it out as part of trouble shooting.
Function WMAnalyzeParticles2(ZD,TipRoi) Wave ZD,TipRoi ImageThreshold /M=2/i /R=TipRoi ZD Wave M_ImageThresh //ImageAnalyzeParticles/D=ZD /W/E/A=4/R=TipRoi stats M_ImageThresh End
This works fine with WMAnalyzeParticles(ZD)
Function WMAnalyzeParticles(inWave) Wave inWave ImageThreshold /M=0/i /T=(Wavemax(inWave)-2) inWave Wave M_ImageThresh ImageAnalyzeParticles/D=inWave /m=3 /W/E/A=4 stats M_ImageThresh End
Where am I going wrong?
November 9, 2016 at 09:23 am - Permalink
