Design a panel with simultaneously display function?
I try to design a panel to deal with data processing.
My data form is 2D waves, so I need to recale the axis and normalize.......
Ideally, there would be panel with some bottoms to process my datas and most importmently it shoud display my 2D waves simultaneously .
But my problem is :how do I insert a box that displaying my wave simultaneously in grey scale to the panel?
Just like the plot function in the "Data Browser" that can display the wave you choose, but I still X and Y axis.
My poor English is not good enough to express my thoughts........
Please help me, thanks a lot.
The first is to create a graph displaying your waves and then add a control bar to the graph. You can put controls on the control bar that change properties of the graph. For more information, execute the following command at the Igor Pro command line:
DisplayHelpTopic "Controls in Graphs"To get an idea of how to do this, you might want to look at some of our example experiments, which can be accessed using the following menu items:
The second possibility is to embed a graph subwindow in another window, most likely a panel. This approach would be most similar to the Data Browser. You can read more about how to do this by executing:
DisplayHelpTopic "Embedding and Subwindows"andDisplayHelpTopic "Control Panels".November 18, 2009 at 09:20 am - Permalink
November 19, 2009 at 01:09 pm - Permalink
Your suggestions are really what I want.
Thank you~~
November 19, 2009 at 07:22 pm - Permalink
I would like to embed a image subwindow in my panel. But I don't really understand how to code.
It seems to use "Display/W=(0.5,0.14,0.9,0.7)/HOST=# sam" --> refered to the help docuement.
Is there any accesst to see the "CWT demo experiment" original codes? I'd like to learn from the example.
Thanks.
November 21, 2009 at 01:08 am - Permalink
Thanks.[/quote]
Sure! Just open the CWT demo experiment, and choose the "Procedure" item from Igor's "Windows" menu.
Search for "Display", and take a look around.
November 21, 2009 at 11:09 am - Permalink
November 21, 2009 at 07:20 pm - Permalink
