I want to create two waves of data (XPixelLocation, YPixelLocation) to create a trace on an image that is four sided polygon, that appears and remains "closed". These waves need five points each (I think), where point 0 and 4 have the same values of X and Y (always). Now I want to edit the wave points (preferably by using GraphWaveEdit) by clicking on the vertices of the polygon (when I do this, the first and last point don't remain together, resulting in an "open" polygon). How do I get xPixelLocation[4] (and Y[4]) to be dependent on XPixelLocation[0] (and Y[0]). It appears I can't make single positions in a wave dependent. Can someone point me in the write direction.
Variable Num := CheckEndpoint(wbox_y)The dependency function ensures that the first & last points of the box wave are the same:
This works for me in IP7. It should also work in IP6
October 7, 2016 at 01:42 pm - Permalink
Thanks so much, that solved my problem. I made one modification for my conditions.
October 7, 2016 at 01:58 pm - Permalink
