Querying XOP error codes
thomas_braun
<br />
#define OLD_IGOR 1 + FIRST_XOP_ERR<br />
#define UNHANDLED_CPP_EXCEPTION 2 + FIRST_XOP_ERR<br />
...<br />
...<br />
Now when I test the XOP I wanted to check some of these errors.
But the exact numeric values are unexpected.
For example
is 196610.My questions:
- Is the exact number always constant or does it depend on the number of custom XOPs I've installed? (I'd expect the latter)
- Is there a way to translate the error code values reliably and with standard tools?
- Any suggestions as alternative testing methods?
Thomas
It depends on the order of loading XOPs.
I'm not sure, but I believe that, if you AND with 0xFFFF and add FIRST_XOP_ERR, you will get your error code. This is an implementation detail and subject to change.
Also, if you pass the code (e.g, 196610, which is 0x30002) to GetErrMessage, you should get your error string.
August 31, 2016 at 08:03 pm - Permalink
September 1, 2016 at 04:11 pm - Permalink
